Wes Gardner
Vectorworks, Inc Employee
  • Content Count
    1,382
Everything posted by Wes Gardner
  1. This seems to happen when walls on the two stories have slightly different "end conditions." In other words, one wall runs a bit longer than the other is a condition that I've found messes things up...
  2. @Kristin Proeger, you are correct. This is an issue that needs to be resolved. Wes
  3. @alex.fitch, you can also use the "Favorites" concept to organize details. The Resource Manager is an EXTREMELY powerful tool in Vectorworks. I suggest that everyone in your firm learn its abilities inside and out. Wes Favorites Files.mp4
  4. @phanlien.arc@gmail.com, check out this short video. Once you have created a 3D shape (in this video a cube). To trigger the Automatic Working Plane, FIRST choose a 2D tool - a line or a rectangle or a polygon. THEN mouse over a face and it should glow blue. Then you can draw on it. Wes Automatic Working Plane.mp4
  5. @studiovarey, it looks like to me that the bricks really ARE in front of the wall which will give you the illusion in elevation view that they are correctly placed. HOWEVER, maybe take a look in Top/Plan view and see where they are located? Wes
  6. @Boh - I just tried a couple of Structural Members as columns and a Framing Member as a beam. I mirrored one of the columns and it seemed to stay oriented correctly...I'll keep trying to see what's up... In Solibri In Vectorworks
  7. @Boh...I believe Solibri still offers a free download for both Mac and PC. Solibri Model Viewer as opposed to the "industrial strength" Solibri Model Checker. If I recall correctly there were some issues with mirroring objects (or it might have been if you rotate objects) hmmmm.... Wes
  8. @elepp, you are absolutely correct! In fact, when I type "Stone" in mtextur's search I get hundreds...pretty cool! Wes
  9. @SLD, aside from what ships with the program, I believe being a Vectorworks Service Select member gets you some additional content, you can buy textures from a number of 3rd party developers, you can modify what ships with the program and of course, you can create your own from any image either from the web or your camera.
  10. @taoist, as mentioned above, materials won't help with the stacked components scenario. Also, some objects like doors and windows are not "material-aware" yet. Wes
  11. @Mark Aceto, Vectorworks does have an "Overhead" door that simulates a segmented or solid garage-style door (it draws the dashed "overhead" lines for you)...no coiling door however... Wes
  12. @domer1322, short answer - no. Longer answer - nope. You're doing the right thing by building one wall on top of another. Inserting doors/windows becomes a challenge. Wes
  13. @LeeElston, that is certainly one method...you could also create an "All Stories" layer. Don't place it in any story and set the elevation at 0'-0" and then model the steel full height. This layer can then be left "on" for any plan view. Wes
  14. @Mark Aceto, I've not actually done it with SM or FM, last time I modeled trusses was to "proof out" what the truss company had sent me as far as fitment (I assumed their calcs were correct) and I just simply modeled the trusses using extrudes. In your case, where you might model one and then modify it for other projects, you might get some "milage" out of doing as you've suggested. Maybe try one and see how much time you have in it??? Wes
  15. @KrisM, in the Advanced Properties button in the OIP, you might get some mileage out of "limiting" the depth of the section cut to an inch or so... Wes
  16. @Mark Aceto, short answer - nope! I think it's either Structural Member as you've suggested or a simple extrude. Wes
  17. @SLD, I believe it depends on what "flavor" of Vectorworks you purchased (Architect, Landmark, Spotlight, Designer). This is what Designer's looks like. You CAN and SHOULD create your own Wes
  18. @shakira, if you just want 2D "linework" people, I've got some... Wes 2D Outline people v2018.vwx People Colored Silohettes v2018.vwx
  19. Hi All, Yes, sketch out ALL the "knowns" in section FIRST. This will help you when creating your Levels as well as where to create story "breaks"...I created a few a couple of years back - they are in the Model Set-Up thread. They are called "Model Set up Worksheets"...there are a couple that are specific to residential and a couple of types of commercial construction. And if you're using stories, ALWAYS make sure your Level names match the names of your bounding conditions in your wall styles! Wes
  20. 600 DPI...yes, it'll take a while... Wes
  21. Just FYI, there are two "flavors" of InteriorCAD, one is called XS and is suited for designers/architects and is fairly reasonably priced, the other "full blown" version is suited for the production of cabinets in a shop.
  22. Here's a tutorial on the Slab Drainage tool...it was written for 2017 but is still pertinent I believe. Here's a couple of practice files too... Wes Slab Drainage Tool.pdf Sloped Slabs.vwx Slab Drainage Demo.vwx
  23. @VWVSpass, this lesson from Vectorworks University might help https://university.vectorworks.net/mod/scorm/player.php?a=58&currentorg=articulate_rise&scoid=116 Wes
  24. @drelARCH, I believe you could rename items and save the file as a template file Wes
  25. @drelARCH, you can rename the Default Levels by going to Tools > Organization > Stories > Default Story Levels. The name of any component that is then bound must match a Level's name. This is covered pretty thoroughly in "Model Set-Up" Wes
