Wes Gardner
Vectorworks, Inc Employee
  • Content Count
    1,267
Posts posted by Wes Gardner
  1. For sections, in the OIP, down near the bottom is the Attributes button for that viewport. I believe, for 2019, there was an option added wit ha check box to "Add Profile Line".  This is what you see in the image below, I have it placed in a class called "2D Profile Line" and can control its lineweight or toggle it off.  This might be what you are seeing in your sections.  It does NOT always work under all conditions.
    Wes
  2. For me, I'd use the "Create Section Viewport" command and set the section cut line outside and looking at the building.  This will generate an elevation that is COORDINATED within the set.  The markers for that elevation can then be shown "automatically" in any of your plan views by going to the elevation on the sheet layer, making it active, going to the OIP, scroll down to the bottom and find "Section Line Instances".  Select the "Viewports" tab and then place check marks next to the plan viewports you wish to have your elevation or section markers appear in.
    Seems you've discovered some of the issues with modeling/meshes/etc. and how to limit the view and/or turn off classes in the viewports to decrease rendering time.
  3. Hi Victor,
    I did a quick one with NURBS curves...I'm sure there're other ways but I'm pretty comfortable with NURBS modeling from elsewhere. I just modeled the entire ramp at some percentage...the real one would probably end up being three separate segments???? Or you could play with the rail curves maybe and get the correct percentage of slope and THEN run the LOFT command.
    • Either way Create NURBS curves for the outer "rails" ( I used your polygonal curves - MODIFY > CNVERT > Convert to NURBS
    • Create a NURBS curve for the Profile curve (I just used a straight line but in reality it would have some crown I suspect)
    • From the 3D Modeling ToolSet - LOFT  > 2 RAIL
    • Shell command for thickness
    I originally tried the NURBS roadway but....
    The sub-D tool might also help in this...
    There're some helpful videos, etc. floating around and Vectorworks HELP can point you to some of the modeling tools and their capabilities if you need help with modeling.
    Wes
    Ramp NURBS.vwx
  4. @ lgoodkind,
    So far, you're right...dunno if you can tell from the image below, but it seems that the initial hip roof that the tool creates has the desired clipping but once you ask it to create a gable end, it doesn't know what to do...I'll keep looking for options and/or submit a bug/enhancement request.
    Wes
  5. Hi All,
    Let’s look at a little more Working Plane magic.  First to invoke the WP, I use the shift key and the number 1.  I’m not sure where I learned that, but it works...in the video, that’s what I do to set the WP on the Ground Plane – just do Shift 1 and click in white space the WP will be set on the GP.
     The next sequence describes how you can set the Automatic Working Plane...the trick here is that you MUST select a 2D tool FIRST, then as you mouse over faces, you’ll get the AWP snapping to those faces.
    The next sequence, I take those funny looking nodes and change the axis of the WP.  To do that, just click on the edge of the pink WP and you should get those nodes.  When you go back to Top/Plan view, the WP disappears.
    A helpful modelling trick might be, if you need to return to some sort of wacky, off-axis plane, create a Saved View and that’ll let you return to that view.
    That’s all for now, Enjoy
    Wes
  6. Here's a bit about the Working Plane...you can invoke the WP by hitting Shift 1.  You can see it snaps to the various faces.  If you go to Top/Plan view and back again, it'll be gone until you hit Shift 1 again. It works kinda like the C-Plane in Rhino.  There's also the Ground Plane which is at Z=0 of the layer. You'll see it right at the beginning of the video over to the left.
    Some AutoCAD folks have had troubles with multiple Design Layers (that equate to their singular Model Space).  You can also go to Vectorworks HELP to discover more...  Oh yeah, there's something called  Unified View.  If you are modeling it should always be ON.  In fact, I don't ever have the icon showing so I don't accidently turn it off - it's left over from years ago, but some folks find a use for it...
  7. Hi All,
    Just a quick note regarding this workflow.  Since the release of 2019 and the advent of the Data Tag tool, this issue may go away entirely as the Data Tag tool can be used in place of the Space Label.  The Data Tag can (and should) be used in Annotation space in your viewports and with a little customizing, can look exactly how you need/want it to as well as be located in the appropriate place(s).
    Enjoy
    Wes
  8. This doesn't really "clean up" anything, but you can turn it into a hybrid symbol so that you only see 2D linework in top/plan, front, side or rear view (and a "cut view" as well) if you have 2019, but the full 3D object in any other view.
    Here's a link to Vectorworks HELP..
    http://app-help.vectorworks.net/2019/eng/index.htm#t=VW2019_Guide%2FSymbols%2FCustomizing_Detail_Levels_for_2D_and_3D_Components_of_Symbol.htm&rhsearch=2D graphic 3d&rhhlterm=2D graphic 3d&rhsyns=
    • Like 1
  9. @Phileas, yep that's the way the Curtain Wall tool was programmed - to simulate how curtain walls are typically built (with the verticals running continuous and the horizontals broken by the verts...) no way I know to change that (although I have asked for a "Make Horizontals Continuous" button"
    Dunno if you'll get any joy from the Railing/Fence Tool??
    As a workaround, you may be able to do just verticals with the Curtain Wall tool and then go back and "place" horizontally modeled objects on the wall.
    Wes
    • Like 1
  10. The Structural Member tool should be located in the Building Shell toolset - it has some anomalies but if it's a simple system you're after, this might work for you.
    The Framing Member tool is located in the Detailing toolset - you'll need to set it up for steel shapes but for me, it's kind of the "old reliable"
    Pick your poison 🙂
    I DO wish we were a little more consistent throughout our tools...
    Wes
  11. Here's what I found with steel shapes using the three options, Structural Member Tool, Framing Member Tool, Wide Flange - 3D.
    Seems if you use the Structural Member tool, you can adjust the scale, mapping, etc. of the texture right there in the OIP's Render tab.
    The Framing Member tool does not allow editing of the texture from the OIP
    The Wide Flange- 3D tool , the sttel shape (or whatever) has to be placed in a class for it to "take" a texture
    Each one offers a "challenge"
  12. Hi Russ,
    Check out Vectorworks Help, there's a section on editing...dunno if you can infer anything from that regarding building a custom one...I built one that gives the spot elevation for the top of a slab so it can't be too hard...
    I'll ask around and see if a video or tutorial has been made that specifically targets making custom tags.
    See the attached file, it might get you started...
    Got to the Resource Manager and edit the tag.  At the bottom choose "Edit Tag Layout" Select the "EL" and in the OIP, choose "Define Tag Field".  This is where the magic happens.  It's similar to "Link Text to Record"...  take a look at the "Data Source" and "Function" drop-downs...
    Hope this helps
    Wes
    Spot Elevation for Slab.vwx
