Wes Gardner
Vectorworks, Inc Employee
  • Content Count
    1,276
Posts posted by Wes Gardner
  1. @NickMac, yeah, go ahead and tear into that file and see what makes it tick...it's one of the training files from the two posts up at the top of this section "No Stories, No Problem" and "Model Set Up" - I'd recommend a quick read through No Stories, No Problem just for shucks and grins.
    Good luck
    Wes
  2. @NickMac, check out this file...go to the Resource Browser and find the door style - right click and select Edit.  In the dialog, those items with the bent arrow are "locked up" in the style, those with an icon of a couple of slider controls are set up to be "by instance".  In this example you can see that WIDTH and HEIGHT are set up by instance so that once the door is placed in a wall in your file, you'll be able to adjust those parameters but NOT the parameters that at set "by Style".  Go to the "Leaf" tab and you'll see that things like the number of muntins is locked up in the style, so is the width of the Top rail and the L/R stile as I want those to be consistent throughout this project.  In the ID Tag, the label needs to be adjustable so that you can label doors separately, it's set up "by Instance". Clicking on one of those icons toggles it from "by Style" to "by Instance".  Try going back to the Resource Manager and setting parameters by either style or instance and then go to your file and check out the implications of your changes.
    Let me know if you have difficulties.
    Wes
    Door Test.vwx
  3. You may have to go to Document Preferences and check the box that says "Auto display detail levels for design layers" and change the settings so that your 1/4" scale design layers will display a "High" level of detail which includes the sash lines below.  See if that helps.
    Wes
    • Like 3
    • Love 1
  4. @Robert Darden, here's your model back...I switched the exterior wall style from being a Level Bound wall style to a Layer Bound wall style.  That wall style will now respond to LAYER WALL HEIGHT as defined in your design layers.  You can go through and switch out the other ones.  As you've defined it, this project does NOT use stories.  You will find that you can build a perfectly fine model WITHOUT stories.  Just make sure your wall styles are set up to be LAYER bound.  It also appears that some of your doors appear in wireframe, that's because they have no fill.  Simply choose a white fill or some other color from the Attributes palette.
    My advice is to read the tutorials at the top of this section so that you'll have a firm understanding of the difference between the two model set up schemes.
    Wes
    2019 6th Ave wg.vwx
  5. @Robert Darden, you're in luck... There are two tutorials pinned at the top of this section - Model Set Up and No Stories, No Problem. - one explains the use of stories, the other does not require stories when setting up a model.   When you say you used to be able to...the behavior you're experiencing is a wall style set up to use Layer Wall Height - this is called a Layer Bound wall style.  What you may have done is grabbed a Level Bound wall style from the Resource Manager.  These won't work unless you've set up stories/levels for the various wall components to "look for."  Best advice - read the two tutorials.  I'd also suggest building a Layer Bound model first (one without stories) and get familiar with controlling individual wall component heights by using offsets (and by using the Component button in the OIP)
    Wes
  6. @Tom W., the last part of your question first - the framer creates extruded elements for studs, plates, blocking, etc. Therefore, they can be edited as any extruded element, relocated either by grabbing and dragging or by using the Move command. They can be duplicated, deleted, shortened or lengthened as mentioned using the editing function.  The Wall Framer is a very old tool and has not received much love in the recent past and was never designed to be able to create a twin-stud wall or wet wall or any of those types of configurations.  There may be some workarounds that you could explore but nothing "out of the box" comes to mind.  For example, you may be able to create two walls, an inner and an outer and have the framer frame both of those -
    Wes
    Double Wall Framing.vwx
  7. @Mitchell (the other one), my suggestion is Door Styles.  For any given project, you can create a style and "lock up" (By Style) those components that are common for that project.  As an example, the height might be the same throughout so that all the head heights align but the door size would be allowed to "float" (By Instance) so that you can have different width doors.  The texture, etc can also be "by style" so they remain constant.  Since these are resources, they can be shared and reused (with any necessary tweaks) for the next project.
    Wes
    Example Door.vwx
    • Like 1
  8. @trashcan, I got lucky that day when I was shooting that sequence...now, when I try to reproduce it, I get what you get...hmmm.  In my opinion, if you have it set to Overall, when you drop a texture on a wall, it should do just that...bug!
    Wes
    • Like 1
  9. @Ride, the plan view is just the ordinary Top/Plan view.  The viewports are just the standard hidden line produced from "Create Section Viewport"
    I must admit, there ARE limitations with what I call our conceptual cabinet tool(s) ... some configurations just aren't possible.
    Here's the file if you'd like to have a look at the setup.
    Wes
    Kitchen 2020.vwx
  10. @Ride This is about as good as I can get them to look - base cabinets with solid lines, top cabinets with dashed lines and countertop dashed for reference.  Data Tag provides the tagging. Sorry, the image export washes out some of the line weight. These are just our conceptual cabinets...I'm not up to speed with interiorCAD.
    Wes
  11. Looking at the model, that particular wall is Wall Style TPS30 EX - it is set with a Top Bounding of Piano [Story Above].  In this model there is no Story Above for the wall style's level to "see" or to bind to.  It appears that you've used "Fit Walls to Objects Above"?  My Italian just isn't good enough to go through how the walls are set to interface with the roof system.  This may be the reason the interior component isn't working properly.
    My advice is to NOT use Stories and just set the whole model up using Layer bound walls styles.
    Wes
  12. @alfresco, please review and compare the file I've attached regarding your Story set up to your file.  You also need to look at the bounding set up in your wall style (the 6" Generic one). In the Component for the wall, where do you want it to be bound?  Furthermore, and I realize this is REALLY unclear, you change the height/bounding of walls either by changing where the top/bottom is bound to OR by changing the height of the various levels in the Story set-up in the Org palette - you DO NOT change the height of level bound walls in the OIP (this really should be greyed out but...).  You might want to thoroughly review the model set up document posted at the top of the Architecture section where it goes through some of the "rules" for level bound walls, etc.
    Wes
    2020BakerrMay18 wg.vwx
