Content Count
1,382 -
Community Reputation
334 SpectacularAbout Wes Gardner
Rank
1000 Club
Personal Information
Occupation
Architect
Hobbies
Tennis, sailing, boat design
Location
United States
Recent Profile Visitors
Could very well be a bug...at first I thought the yellow/green band was your fascia
Hey All, I usually just enter the Profile editor and move the profile to where the green and red lines cross...sometimes you have to flip the profile...no biggie...the concept is that the profile is extruded along the path at the CENTER of its BOUNDING BOX... Wes
Looks like it's "hard coded" into the Dimension tool...hmmmm
Is it possible to disable certain RM libraries?
Wes Gardner replied to Andy Broomell's topic in General Discussion
I don't think there's a way to selectively turn off the library parts Wes -
You can also make adjustments on a "per wall" basis - go to the Components button in the OIP, click on a component and enter an offset - positive numbers will extend the component up and negative numbers will extend the component down...build a simple model to see the capabilities! Wes
@zoeageorg looks like both of those are pretty complete packages - good luck! Wes
Dan Menitoff started following Wes Gardner
Regarding a mouse, I just have a typical wireless logitech (yeah, I went wireless last year while living on the boat)...you can turn off the detent for the wheel/scroll if you want...sometimes I incline my mouse surface side-to-side with the low side being outboard...it doesn't take much incline to releave the tension in your wrist (for anyone with wrist pain, try that first....)...it fits my hand nicely...I also use the Space Commander or whatever that thing's called by 3D Connexion...but mostly when I'm drawing in Rhino....for Vectorworks, pretty typical mouse set up... Wes
Try some lettering left-handed...my drawings were always smuged ... 😞 Wes
Hi All, In many of my projects, I set the Layer Wall Height to the most common height used on that particular floor and then set up my Layer Bound wall style to look for "Layer Wall Height". In the attached example, it's 12'-4" Wes
Here's mine...sheet layer DPI is 600
@bmaad..I think you can do it on the fly...However, the additional level will only be available in that story...you'd need to create another one in any additional stories...However, in your case, it seems you only need to add the additional level to just one story Wes
@bmaad...one of the things that I don't like about the implementation of the stories concept is how the OIP can lie to you. Wit hone of the dropped walls selected, you can see how the OIP is telling you the bounding condition...That unfortunately is NOT the bounding condition for that particular wall...it's the bounding condition for the wall style. However, if you click on the Components button in the OIP, you'll see that particular wall has the bottom bounding set at one of the "Offset" levels which are intended to give it that 3 foot offset. The good news with stories is that it's very reliable when using this offset strategy - your walls and their components will always offset to the correct height/elevation. Wes
@bmaad...I think the KISS principle works here...stories DO offer superior change management if you're anticipating a bunch of floor-to-floor changes (this would be relevant to the larger building scenario you mention) as the stories/floors above will be moved up/down automatically. In the non-story scenario, you'll need to adjust each layer's height if a change is encountered. So with that said, I'll go with "it really depends on the project" as to whether or not to use stories. Even if you're anticipating working with IFC, your non-story layers can be manually mapped to IFC stories, that's why I contend that you can build a perfectly fine model without stories. There really is no "down side." Just be sure to select the correct wall style if you are going the non-story route. If you choose the story route, both wall styles will work in your model simultaneously if you want them to. Wes
@Moni, I'd start by looking at "No Stories, No Problem." Download the example files. One of the "tricks" in Vectorworks is understanding wall styles and how they can be automated to "look for" height information. This can be accomplished by the No Stories, No Problem concept of using Layer Elevation (for the wall bottom) and Layer Wall Height for the top. The more complex version uses Levels to further automate the process but often times the bounding concept seems overly burdensome. The two types of wall styles I call "Layer Bound" and "Level Bound." In the Resource Manager, they call them "Fixed Height" and "Story Bounded." I don't like that terminology... So read and understand the No Stories, No Prob document first, then compare it to the Model Set Up doc. then maybe build a simple model...Typically I tell people that the only reason to use stories is if you are going to be working with IFC files, or are anticipating a lot of floor-to-floor changes as storeis does automate these processes somewhat. Wes
Hidden line render mode issues with window IDs & surface hatches
Wes Gardner replied to EvelyneB's topic in Architecture
@EvelyneB, I passed your file on to Tech Support....they should have an answer for you. Wes- 12 replies
- 2
- hiddenline
- window tag
(and 1 more)
Tagged with:
