Katie,
Now my door is transparent, except for the stiles & rail, which are the rendered texture I picked in the object info/rendering section.
Also, you noted above "if the fill color is set to white, then parts of the door/window will render gray." What should the fill color be set to for both the class (i.e. "Door - Main") and the style? What should the render tab in object info be set to?
Where can I find instructions on using styles for rendering class components? I haven't had much luck w/ the help menu.
Thank you.
