149 -
Reputation
12 GoodPersonal Information
Occupation
Architect
Homepage
www.talihardonag.com
Location
United States
Recent Profile Visitors
5,508 profile views
Does the worksheet tabs have Format>Cell>Font ? ahh - sorry, different issue? Can the redline font and size be determined by text style in the class?
Windows in Wall have Class greyed and are not selectable
taliho replied to taliho's topic in General Discussion
Thanks, Will do -
I pulled up a backup file and Im working from that for now, but still need the problem file to work -
Yes - Since it crashed a couple of times this morning...... -
taliho posted a topic in General Discussion
HI- Odd thing this morning.... I am trying to copy a window in a wall to another wall. The window is not copying, instead the whole wall is. When I manage to highlight a window - it jumps in the wall, duplicating itself The window object class in OIP is greyed. Another weird thing is that all my plumbing fixtures are in class Plumbing-fixtures, but when that is the selected class 'Active only' not all the symbols appear I checked backup files and this wasn't happening in earlier files from days ago Thanks Tali TEST Windows.vwx -
Matt - thanks, that did the trick. 🤦♀️
Hello- I used the View > Create Interior Elevation Viewport. 3 of the walls came through perfectly - One of the walls, see attached, 'Kitchen Cabinets' are only displaying partial height in this viewport. The same view direction from a different location in the room 'Kitchen Wall' shows the entire wall with cabinetry At some point the whole wall was visible and I was able to add dimensions for the cabinetry This 'block' persists when I go from this Interior Elevation to 'Elevation in Place', however, it is not there when I'm viewing the whole house model Any thoughts or ideas what may be causing this? Elevation not showing full height.pdf
3D dragger suddenly appeared...... how to remove?
Thanks - found it...... -
Hi- This showed up in my files a few days ago - . I think it's the 3D dragger. It does impact my workflow, as I can't select or edit objects as I could last week..... It shows up when I open older documents that didn't have it before, so it's something in the Vectorworks setup, not in a specific document. It shows up in design layers and in viewport annotations - how can I disable it from popping up on my drawings? it is probably something very basic that is eluding me..... Thanks Screenshot 2025-01-25 at 11.51.30 AM.pdf
Thanks - I'll look into Blender Tali
Hi - I've imported an .STL model into 2025. Is it possible to edit it? Covert to Solids creates a very complex mesh. Older threads say its not quite doable natively, I'm hoping there is an update Thanks Tali
@VIRTUALENVIRONS - Yes, I tried to get a pad as part of the geometry, so at least I was successful in that.... I could only get 1 file (there seem to be 4 downloads) and attempting to print now. Thanks for all the manipulations to get to my goal! @Tom W. - suggests a very simple step, and it seems to do exactly what I need.! THANKS! The model is printing now, will let you know if I got it right... Thank you all for all the help!
@VIRTUALENVIRONS - i have some pads on the terrain. feel free to delete those for the purpose of my query... its the large terrain model I am attempting to 'clip' or 'trim' @zoomer- do i need to recreate the DTM in smaller sections? if I can split the work I've already done into 2-3 sections, I can achieve separate pieces to print...? also struggling with why the existing pad can update to model with the terrain, but the proposed does not. This is my first attempt at site modeling - I have had a 'boring' existence for 40 years with only 'flatland' projects...😀 Thanks
Thanks. I'm showing the area I want to 3D print today in the square lower left (PS - for just the terrain - is the file size reasonable?) Tali DYER 3D clip terrain VW.vwx
Hi I have created the terrain for the entire site. Now I would like to export STL for 3D printing - but only a smaller area of the site. Is there a way to do this? This would be an area that may have a few iterations over the course of the project, and so I would like to work on that area alone, larger scale, more detail... and then slot it back into the full terrain model I've followed some previous threads from '22 but it doesn't seem to apply to what I need. Thanks Tali
