Tali Hardonag
    151
Reputation
13 Good
1 Follower
Personal Information
  • Occupation
    Architect
  • Homepage
    www.talihardonag.com
  • Location
    United States
Recent Profile Visitors
5,684 profile views
  1. @Steven Kenzer - Thanks for pointing out the Maloof Chair. My husband has built 3 rocking chairs - about 4 months each. (Plans for the chairs are available for purchase.) Visiting Maloof home and studio is inspiring. https://www.malooffoundation.org
  2. I am having similar issues. AI Vis worked great in 2025, but its 'dead' now I have just installed update 4.1 and the results are no different. i'm adding my request here for help and suggestions.....
  3. Does the worksheet tabs have Format>Cell>Font ? ahh - sorry, different issue? Can the redline font and size be determined by text style in the class?
  4. I pulled up a backup file and Im working from that for now, but still need the problem file to work
  5. HI- Odd thing this morning.... I am trying to copy a window in a wall to another wall. The window is not copying, instead the whole wall is. When I manage to highlight a window - it jumps in the wall, duplicating itself The window object class in OIP is greyed. Another weird thing is that all my plumbing fixtures are in class Plumbing-fixtures, but when that is the selected class 'Active only' not all the symbols appear I checked backup files and this wasn't happening in earlier files from days ago Thanks Tali TEST Windows.vwx
  6. Hello- I used the View > Create Interior Elevation Viewport. 3 of the walls came through perfectly - One of the walls, see attached, 'Kitchen Cabinets' are only displaying partial height in this viewport. The same view direction from a different location in the room 'Kitchen Wall' shows the entire wall with cabinetry At some point the whole wall was visible and I was able to add dimensions for the cabinetry This 'block' persists when I go from this Interior Elevation to 'Elevation in Place', however, it is not there when I'm viewing the whole house model Any thoughts or ideas what may be causing this? Elevation not showing full height.pdf
  7. Hi- This showed up in my files a few days ago - . I think it's the 3D dragger. It does impact my workflow, as I can't select or edit objects as I could last week..... It shows up when I open older documents that didn't have it before, so it's something in the Vectorworks setup, not in a specific document. It shows up in design layers and in viewport annotations - how can I disable it from popping up on my drawings? it is probably something very basic that is eluding me..... Thanks Screenshot 2025-01-25 at 11.51.30 AM.pdf
  8. Hi - I've imported an .STL model into 2025. Is it possible to edit it? Covert to Solids creates a very complex mesh. Older threads say its not quite doable natively, I'm hoping there is an update Thanks Tali
  9. @VIRTUALENVIRONS - Yes, I tried to get a pad as part of the geometry, so at least I was successful in that.... I could only get 1 file (there seem to be 4 downloads) and attempting to print now. Thanks for all the manipulations to get to my goal! @Tom W. - suggests a very simple step, and it seems to do exactly what I need.! THANKS! The model is printing now, will let you know if I got it right... Thank you all for all the help!
  10. @VIRTUALENVIRONS - i have some pads on the terrain. feel free to delete those for the purpose of my query... its the large terrain model I am attempting to 'clip' or 'trim' @zoomer- do i need to recreate the DTM in smaller sections? if I can split the work I've already done into 2-3 sections, I can achieve separate pieces to print...? also struggling with why the existing pad can update to model with the terrain, but the proposed does not. This is my first attempt at site modeling - I have had a 'boring' existence for 40 years with only 'flatland' projects...😀 Thanks
