That's odd. It seems to work fine for me viewing in adobe acrobat 7.0 I was also able to make a large document fairly quickly w cutepdf. I also heard that adobe 8.0 acrobat solves the large format printing of docs, although I haven't bought it yet. Here's some more info on cute pdf:
"To create PDF files:
To use CutePDF Writer, open the file that you would like to print to PDF. Select the Print option (usually found under File > Print), and select "CutePDF Writer" from the list of available printers (DO NOT select Print to File option) to print. You will be prompted to select the destination directory and filename for your output file.
Please note that some applications, such as NotePad, will automatically print to your default printer when you select the Print option. If you want to create PDF file, you may need to change your printer selection within that application before printing the file. This can typically be done from Page Setup.
But you probably already done all that. Try visiting their website. Make sure you have enough ram and disk space, which is usually not a problem.
One last thing, make sure you have the latest acrobast reader version. And check the settings to make it backward compatible to around version 4.
Let me know if any of that works for you.
Cheers
Tim
This is such a waste of time, isn't it? Nemetcheck should work on making their product first - as robust as possible, THEN add features. I've had constant problems with it. But what do you do? It's like swimming slightly more than halfway across a river when you realize you don't want to deal with the problems anymore. Do you stay the course and try to complete your swim, or turn around, swim back, and try another, better CAD product. Tough and frustating call.
