Russel
    26
Reputation
0 Neutral
Personal Information
  • Occupation
    Conference Production Manager
  • Homepage
    www.clearproductions.co.uk
  • Hobbies
    Power Kiting, Music, books and anything techy
  • Location
    West Mids, UK
  1. Thought I'd update this post with a link to a solution, just incase anbody wants a solution. Link to Auto numbering post in general discussions section
  2. Many thanks will give it a go. Glad you posted it, as I could't find it when I did aa search.
  3. Just use the save for web function in Illustrator to save as a png direct
  4. I don't agree with a free version, but I do think that the cost of updates could be looked at also, loose the dongle please. I dread to think what it would cost me to replace it if it was stolen or lost, I have no choice but to take it with me as i work away a lot.
  5. Hi, I'm currently drafting stand layouts for an exhibition, is there a way of auto numbering each stand. I have a work sheet that gives a stand count, But I have to go in an puta syand number on each stand. Thanks in advance
  6. try the videoscreen 4 plugin from Landru design. saves so much time, you can create a screen in seconds, with an image.....best plugin I've got for spotlight
  7. Hi, Was wondering if anybody could shed any light on this little problem. I am currently invovled with draft exhibtion stand layouts for a project. now i have created a symbol for each stand, and i can create a work sheet that keeps track of stand counts for the various layouts, but at the moment I am numbering each stand manually in the relevant viewport. is there a way to actually get the stand to auto label itself when it is inserted on the drawing. many thanks
  8. Thanks Ray, You got me thinking and I've just turned off compatability mode, and Hey now really strange,but suddenly VW2008 works without using compatabilily mode!on this amchine and now saves the files again.
  9. because VW2008 wouldn't run in normal mode
  10. HI, Have just ditched Vista for Windoz 7!! and VW2008 has stoped saving files. I am running it in compatability mode for XP with SP3. The starnge thing is when I save a file sometimes it does actually save the file but I get the following error about a corrupt file. sometime the file is there sometimes it's not, however if I export to VW12 or anyother format there is no issue and I can open the files again as normal, but they still will not save. Has anybody else come across this? Thanks in advance
  11. Had a quick play and here's a sample file to look at. My texture image was n't very hi res but I think it will give you an idea of how to go.
  12. I don't know if it will be of much help, but in Lightwave I created a sharks tooth gauze in the followning way. 1 created a sharks tooth gauze texture. 2 applied this to the object 3 used the same texture for bump and transparency maps. not sure if VW will let you create textures in the same way will have a look and see what can be done.
  13. Has any body got any LED battens or fixture symbols that can actually be used as lamps in a 3d render. Or how do you go about creating from scatch?
  14. Cheers, I have had a play and drawn a basic stand but, it's not height adjustable. but gradually getting there
