211 -
Everything posted by Asemblance
Mojave 2019 SP3.1 Text Editing Very Slow
Asemblance replied to Asemblance's question in Troubleshooting
@jblock This occurred again earlier and I remembered your previous comment about undocking the OIP. Which seems to possibly have worked? I'll do a bit more testing. But can you explain to me ~why~ this works?? Surely where the OIP is/how it is docked should have no impact on performance.. Is this a known bug?? Thanks, A -
Thanks @Nicolas Goutte that makes sense. Time for a bit of a file clearance then!
Hi All, This is hopefully a very quick question with an obvious answer I'm overlooking.. Autosave options in Vectorworks are pretty straightforwards. I have it set to update every 15 minutes to 'a backup folder in the same place as the original file'. Great; it creates a folder called 'VW Backup' and I can see all the autosaved .vwx files in there. But what are the '.bak. files which seem to be littering the folder where the main .vwx files are saved? Do I need to keep these? Should I keep deleting them? I've never really understood what they are. Thanks!
Pier - Thanks for your suggestion. What gives you the impression it would be corrupted preferences? Is this an issue you suffered from before? -
I haven't had the issue since first posting last month. Until now. I'm having a very similar feeling issue, this time selecting a piece of wall. Its quite a heavy file but smaller than most I am currently working on, and runs fine generally. I took a couple of videos (links below) to try and illustrate the issue. First video, all fine. Feels normal, responsive. Second video. Exact same file, taken about 2 minutes later. All I had done was select the piece of wall shown on screen. Vectorworks then took CPU usage up to about 103%, and became completely unresponsive for 5 minutes. (Note - in the video you can't see the spinning loading cursor, screen recorder doesn't record it. But it was spinning away the whole time). This is the same issue I was having with selecting/editing certain blocks of text in my previous post. This issue seems to arise quite erratically on certain bits of certain files.. Has happened a few times in this file this afternoon, very difficult to get work done like this. Vid 1 - Vid 2 - -
@Miguel Barrera Just stumbled across this and was exactly what I was after, works great thanks!
Hi jblock, Currently object info palette is docked - Thanks I'll try undocking. Is having a docked OIP a known bug that could cause these issues then? -
Hi All, I've just taken the plunge to Mojave, and straight off the bat have run into a major issue. Editing text in sheet view is absolutely crippling my system. I'm working in the same file as I was prior to updating to Mojave, on the same system, on the same SP3.1 Vectorworks. The only change is the system update, and it is severely slower since the update. Is this a known issue? I can record some footage showing the slowdown if it helps. Thanks A
Sorry to see you go Jim, you will be missed! Thanks for the help over the years.
Window Object Glazing Control
Asemblance replied to Asemblance's question in Wishlist - Feature and Content Requests
Hi @timcrossley - Unfortunately not! Although I haven't actually checked since 2019 was released if this has provided any additional functionality which would help.. -
Thanks Mihail good to hear this is being resolved!
- 5 replies
- curtain wall
- ifc
(and 3 more)
Tagged with:
Unable to Install Updates 2019 on Windows 10
@omarkadry - I do have administrator privileges, and have been running the updater with administrator privileges in regular mode. However in safe mode, the problem is not that the launcher wont start, but that I cannot connect to the internet in order to complete the update download.. I have circumnavigated this problem now, by rebooting in safe mode and physically connecting to the internet with an ethernet cable. I was then able to run the updater successfully. But it is worth mentioning that 1) I often don't have access to a physical wired connection, and 2) some laptops dont even have an ethernet port to connect with. So its not an ideal workaround!- 5 replies
- windows 10
- 2019
(and 1 more)
Tagged with:
Thanks for your responses @Tim C., @omarkadry - I can't see a log in the location you mentioned. I think the problem is more that the updater is failing to launch/is being stopped by Windows from launching entirely. I will try the update again and see if the log appears.- 5 replies
- windows 10
- 2019
(and 1 more)
Tagged with:
Hi All, I'm having some real problems installing the service packs for vwx 2019 on my Windows 10 laptop. I've had issued with previous vwx installs and updates on this laptop, but always got around them previously by downloading the update, rebooting into safe mode and installing from there. However with the new updater, I am unable to take this approach, as I can't run the updater to download the update.. And I can't run the updater in safe mode, as then I lose my ability to connect to the internet (even with 'safe mode with networking' selected). Does anybody else suffer from this problem? How can I get around it? I'm stuck on SP0. Thanks, A
- 5 replies
- windows 10
- 2019
(and 1 more)
Tagged with:
Hi All, Control over drawing issues and revisions has got better over the last few years with the Title Block Manager, particularly with 2019 making it less easy to accidentally add to 'all sheets', but there are still odd holes. In the instance shown in the below screenshot I would like to be able to remove/delete the highlighted 'T2' duplicate issue (which is not the last issue) without deleting all and re-adding them. I just want to click on the one in question, and click delete. Is there some reason this is technically difficult to achieve?? It seems like an obvious addition.. There are files we have where some of our staff accidentally issued 'all' before they got to grips with 2018 properly, which means we have a legacy issue of hundreds of these incorrect drawing issues which need removing.
Also finding this to be the case @zoomer - More hangups the longer I'm in a file in 2019, or with more than one drawing open (on High Sierra). Even doing simple tasks like switching between sheets, or going into or out of a viewport. Memory leak perhaps?
P.S. I remember since a while ago in vwx settings it was recommended that 'Good Performance and Compatibility' was somehow better for system speed than using 'Best Performance'. Is this still true?
We've been doing some testing on some live projects, with the hopes to move things onto 2019. However disappointingly, we're finding 2019 seems to be significantly slower, with a lot of 'hangups' in between actions. In particular I've been noticing this going through and editing sheets. Doing the same actions in identical files on vwx 2018 (Sp4) is smoother and faster. This is quite the opposite from what we were hoping for! Has anybody else found this?
All of the above. It would be great if somehow a 'follow me' type tool could be implemented for stairs. This would be especially great with any curved spaces. I'm imagining a polygon as the object the stair follows, with straight segments and curved segments wherever the user wants them. The tool would guide the staircase to essentially follow the drawn object, ensuring a minimum tread depth occurs, and widening treads where curves occur. Once its got the geometry of the curve/stepped wall/whatever correct in 2D plan, you can then worry about adjusting heights of treads and numbers of stairs etc. Once this is dealt with, some way to customise treads either as a group, or individually (with a 'reset' button incase we screw things up..).
Hi All, Is there a definitive list of new tools introduced in Vwx 2019? Specifically tools with 'buttons' which should be in the default workspace? I know there is a checkbox on immigration of workspaces from 2018 to add new tools, but for some reason this doesn't seem to have worked for me. Rather than setting up all my shortcuts and other settings again, I'd rather just manually add the new tools in their appropriate locations.
Hi All, Having a problem exporting from a vectorworks 2018 model file sheet layer, where the resulting dwg seems to be scaled to 350% (exactly). I'm hoping this is something obvious we've overlooked our end, any suggestions?? Thanks, A
Teaser Tuesday - Class and Layer Filters - Vectorworks 2019
Asemblance replied to PVA - Admin's topic in News You Need
Hallelujah! Looks even better than I was hoping. -
Hi All, Having a bit of a nightmare at the moment exporting an IFC file for our QS on a BIM project from 3D Vectorworks Model. I have been using various wall types, which are largely generic at this stage. Currently 5 core types, 3 of which are generic walls (3 different thicknesses but no buildup shown), 2 of which are curtain walling types. The QS is trying to break down the building into different wall types to put costs against them. They have told us that the IFC Data they would expect to see in the model (which they would use to read these varying wall types) is not appearing when they open our IFC file. Looking at the model in Solbri, I can see that a lot of fields I would expect to be filled in are blank, and the walls are not searchable/sub-dividable by type. Has anyone successfully used wall types in IFC exports? Have I missed a key step where IFC data is added to each wall type? i.e. 'Wall type code', allowing all wall types to be differentiated in the model. Can anyone explain the 'IFC' menu under 'Data' in each wall type? Where on the below screenshot should we be inputting information? The 'global' vs 'single instance' toggle buttons in the IFC data panel don't work how I would expect them to. I would expect this to allow you to set, say, all instances of the wall type in question to have the same 'type' or 'name'. However clicking on the toggle appears to make data disapear, and clear the field. (I can't explain this very well - please try it yourself if you are reading this and hopefully what I'm saying will make sense!) Any advice much appreciated. Thanks, A
- 1
- ifc
- wall types
(and 2 more)
Tagged with:
Door Height linked to Story Level
Asemblance posted a question in Wishlist - Feature and Content Requests
The height of a door in a wall is currently pretty dumb. It would be much better if this could be set by story level, i.e. door height = FFL. -
Wall Tool Inside Outside Left Right Marker
Hi All, It would be useful if it was much clearer which side of a wall is inside/outside/left/right. Whenever replacing a wall with a new wall style for instance, I've been adopting the trial an error approach. I know the wall when selected shows a tiny arrow on one end, but often this is obscured or out of view. Also (more importantly), this is not displayed if you have more than one piece of wall selected. So the typical workflow of selecting a bunch of walls to update/replace, guess a side to align, get it wrong, undo, redo, select opposite side align. Whilst I'm on it, a marker showing 'inside' and 'outside' of window objects when selected would also be handy.
