Molly Sasso
    3
Reputation
0 Neutral
Personal Information
  • Occupation
    Quality Assurance Specialist
  • Homepage
    http://nemetschek.net
  • Location
    Columbia, Maryland
Recent Profile Visitors
  1. I found what causes the appending of the "_VW12", "_VW12_VW12", "_VW12_VW12_VW12"? etc. Open a VW file created in a previous version of VW in VW2008, you will get the dialog "This file was created with an older version...." at the bottom of the dialog is a Settings button. Select the Settings button, you will get another dialog "Keep the original file name with the:" and you can select from "Original File" or "New File" if you choose "New File" and then attempt to Batch Convert you will get the appending "_VW12", "_VW12_VW12", "_VW12_VW12_VW12"? etc. So as a work around for now, only choose "Original File".
  2. Petri, Can you email me: The Batch Conversion Log? Several of the files that failed during the conversion? Molly Sasso Quality Assurance Specialist msasso@nemetschek.net
  3. Hi, I'm trying to reproduce this problem. I have several questions and items that I would like to obtain from you when you have some time. Can you email me the Batch Conversion Log that is created when this problem occurs. What are the options you have turned on for Batch Convert? Include Subfolders? Convert in Place? Convert layer links into viewports? Convert Referenced Layers into Referenced Viewports? Molly Sasso msasso@nemetschek.net
