ASL
16 -
Reputation
0 Neutral-
I was under the impression that one of the huge benefits announced during the VectorFest tour to promote VW2008, was that when using DLVP (design layer viewport) referencing, one no longer had to clean up the classes in consultant files, because they were not supposed to get 'imported' during a mere DLVP referencing process. Unfortunately, I have not found this to be true.... all the consultant classes are still importing. Am I doing something wrong? Or was this feature not programmed into VW2008 afterall?
VW crashing EVERYTIME I try to add a VPDL reference
ASL replied to ASL's topic in General Discussion
It appears the root of the problem seems to have been caused by a 'circularly referenced SYMBOL'. Now that that symbol has been deleted and all files in the project have been purged, the program is no longer crashing, at least for now. -
file size getting huge / VW crashing / verification process taking 3-5minut
In my particular case, the root of the problem seems to have been caused by a 'circularly referenced SYMBOL'. Islandmon, you seemed to be on the right track with your initial comment, but in the end it was not a circularly referenced file (using DLVP), but rather that one symbol. Now that that symbol has been deleted and all files in the project have been purged, my largest file size is 1.5MB and the program is no longer crashing a dozen times a day. So, my advice, certainly use referenced symbols, but don't let any loops develop. -
VW2008 is crashing on me EVERY single time when I try to do a 'true' reference (view port design layer reference). Does anyone have any suggestions what might be causing this? And more importantly any suggestions on what might fix this? Thanks in advance!!!!
Patrick, at the bottom right of your window a little bar appears that first says 'Reading File' and then switches to 'Verifying File'. -
In an effort to try and track down why all my file sizes on a project just exploded, I am trying to pin-point the potential problem: Typically all of our project files use referenced symbols, i.e. we have a file in which all symbols for the project get drawn and made into symbols and then each and every file in the project uses these symbols via reference symbols. This seemed to be working great until this afternoon, when all files which used to be around 1MB grew to around 8MB. I have now set up one test file in the project, which does not use any reference symbols and it has stayed at apx. 900KB. What experience are others having with referenced symbols? And if you are not using referenced symbols how do you work with symbols?
In trying to 'save' a file, which kept causing VW to crash, I decided to reference said file into a blank document and then to delete the reference, but asking for the objects to be 'imported into current document'. This caused apx. 3000 design layers to develop (whereas there used to only be one) and each class to duplicate anywhere from 10 to 20 times. What could be causing this? I tried this again with a much simpler file and it only added one additional design layer and half a dozen classes, but why would this be happening at all?
Typically I set up a Template file, off of which all project files get created. In VW2008, the template file extension .sta was causing said file to open in Photoshop CS3 rather than in VW. Thus I have simply created a regular .vwx file, which merely has the project classes, the title block and a sample viewport in it. Now, all of a sudden, when I do a 'Save As' on this file (without adding any references or any other data), it all of a sudden jumps from a 208KB file size to a 7MB file size. What could be causing this?
My understanding per the thread to a previous of my questions, one could do the circular referencing once one had installed SP2. (I copied the reply from that post, since I didn't know how to create a direct link to it). Re: Work Flow Question - Design Layer References Prior to VW2008 SP2, you could not have circular file references - you will get a message stating: 'The selected file cannot be referenced, because that would cause a cycle of design layer viewport style references'. In VW2008 SP2, you can now have circular file references. However, you cannot have circular data references; if this happens, you will get a message notifying you of circular data. Having said this, I am not sure that the setup you described above is circular. Furthermore, all this applies to DLVPs. -
All of a sudden all our files are starting to have large file sizes... they used to be around 1MB each, now they are all of a sudden around 8MB (sure we have added some information, but certainly not 8-fold). This may, or may not be the root of the problem, but now the 'File Verification' process during the opening of the files is taking around 3-5 minutes. And after all that it crashes VW (I'll include the crash report below). The only other change I noticed prior to every file, which has references going both ways (e.g. Plan has Structural Grid file referenced in and Structural Grid file has Plan files referenced in), crashing is that upon opening it was telling me that Reference Links would have to be broken, but they appeared to be file upon opening the file. HELP, I have a project deadline on January 2nd and can't open 3/4 of the project files. This is a nightmare!!! Here's the crash report: Date/Time: 2007-12-28 16:07:14.799 -0500 OS Version: 10.4.11 (Build 8S2167) Report Version: 4 Command: VectorWorks Path: /Applications/VectorWorks 2008/VectorWorks 2008.app/Contents/MacOS/VectorWorks Parent: WindowServer [60] Version: 13.0.1 (82099) (???) PID: 213 Thread: 0 Exception: EXC_BAD_ACCESS (0x0001) Codes: KERN_INVALID_ADDRESS (0x0001) at 0x024d0fff Thread 0 Crashed: 0 net.nemetschek.vectorworks 0x0079d691 IwObject::operator delete(void*) + 10883 1 net.nemetschek.vectorworks 0x00c72b09 IwSolutionArray::Dump() const + 789613 2 net.nemetschek.vectorworks 0x00c727d8 IwSolutionArray::Dump() const + 788796 3 net.nemetschek.vectorworks 0x004bcd46 start + 4958222 4 net.nemetschek.vectorworks 0x002637b2 start + 2495098 5 net.nemetschek.vectorworks 0x00263c59 start + 2496289 6 net.nemetschek.vectorworks 0x000fa83f start + 1016583 7 net.nemetschek.vectorworks 0x0005acfc start + 362436 8 net.nemetschek.vectorworks 0x000a1356 start + 650782 9 net.nemetschek.vectorworks 0x0005ae35 start + 362749 10 net.nemetschek.vectorworks 0x000b411a start + 728034 11 net.nemetschek.vectorworks 0x000b39ae start + 726134 12 net.nemetschek.vectorworks 0x0005a99f start + 361575 13 net.nemetschek.vectorworks 0x0000263a start + 258 14 net.nemetschek.vectorworks 0x00002561 start + 41 Thread 1: 0 libSystem.B.dylib 0x900248c7 semaphore_wait_signal_trap + 7 1 libGLProgrammability.dylib 0x941a7f84 glvmDoWork + 150 2 libSystem.B.dylib 0x90024227 _pthread_body + 84 Thread 2: 0 libSystem.B.dylib 0x900248c7 semaphore_wait_signal_trap + 7 1 com.apple.ColorSync 0x915a96cf pthreadSemaphoreWait(t_pthreadSemaphore*) + 35 2 com.apple.ColorSync 0x915c3de0 CMMConvTask(void*) + 60 3 libSystem.B.dylib 0x90024227 _pthread_body + 84 Thread 3: 0 libSystem.B.dylib 0x9000520a syscall + 10 1 com.apple.OpenTransport 0x9a1b2086 CarbonSelectThreadFunc + 222 2 libSystem.B.dylib 0x90024227 _pthread_body + 84 Thread 4: 0 libSystem.B.dylib 0x900248c7 semaphore_wait_signal_trap + 7 1 com.apple.OpenTransport 0x9a1ae09d CarbonOperationThreadFunc + 176 2 libSystem.B.dylib 0x90024227 _pthread_body + 84 Thread 5: 0 libSystem.B.dylib 0x900248c7 semaphore_wait_signal_trap + 7 1 com.apple.OpenTransport 0x9a1b94d2 WaitForSyncDone + 107 2 com.apple.OpenTransport 0x9a1c0986 RecvData + 999 3 com.apple.OpenTransport 0x9a1c0cdd OTRcvUData + 61 4 net.nemetschek.vectorworks 0x01550379 haspregnew + 9003 5 net.nemetschek.vectorworks 0x013983df hasp + 8861 6 net.nemetschek.vectorworks 0x013987fe hasp + 9916 7 net.nemetschek.vectorworks 0x01398a93 hasp + 10577 8 ...ple.CoreServices.CarbonCore 0x90cb8c68 PrivateMPEntryPoint + 51 9 libSystem.B.dylib 0x90024227 _pthread_body + 84 Thread 6: 0 libSystem.B.dylib 0x901101bf semaphore_timedwait_trap + 7 1 net.nemetschek.vectorworks 0x00c53c98 IwSolutionArray::Dump() const + 663036 2 net.nemetschek.vectorworks 0x01397b55 hasp + 6675 3 net.nemetschek.vectorworks 0x01397c5b hasp + 6937 4 ...ple.CoreServices.CarbonCore 0x90cb8c68 PrivateMPEntryPoint + 51 5 libSystem.B.dylib 0x90024227 _pthread_body + 84 Thread 7: 0 libSystem.B.dylib 0x90026d5c kevent + 12 1 ...ple.CoreServices.CarbonCore 0x90cb8c68 PrivateMPEntryPoint + 51 2 libSystem.B.dylib 0x90024227 _pthread_body + 84 Thread 8: 0 libSystem.B.dylib 0x900248c7 semaphore_wait_signal_trap + 7 1 ...ple.CoreServices.CarbonCore 0x90cb8e0d MPWaitOnQueue + 198 2 com.apple.DesktopServices 0x9271e953 TNodeSyncTask::SyncTaskProc(void*) + 143 3 ...ple.CoreServices.CarbonCore 0x90cb8c68 PrivateMPEntryPoint + 51 4 libSystem.B.dylib 0x90024227 _pthread_body + 84 Thread 0 crashed with X86 Thread State (32-bit): eax: 0x024d0ee5 ebx: 0x00c72a4b ecx: 0x00006a80 edx: 0x022cf2e8 edi: 0x2d3e39d1 esi: 0x00000000 ebp: 0xbffff788 esp: 0xbffff778 ss: 0x0000001f efl: 0x00010203 eip: 0x0079d691 cs: 0x00000017 ds: 0x0000001f es: 0x0000001f fs: 0x00000000 gs: 0x00000037 Binary Images Description: 0x1000 - 0x1d2efff net.nemetschek.vectorworks 13.0.1 (82099) (???) /Applications/VectorWorks 2008/VectorWorks 2008.app/Contents/MacOS/VectorWorks 0x274c000 - 0x2767fff GLRendererFloat /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat 0x3008000 - 0x385ffff libRenderWorks.dylib /Applications/VectorWorks 2008/VectorWorks 2008.app/Contents/MacOS/libRenderWorks.dylib 0x1830b000 - 0x1847cfff GLEngine /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine 0x184aa000 - 0x186dffff com.apple.ATIRadeonX2000GLDriver 1.5.14 (5.1.4) /System/Library/Extensions/ATIRadeonX2000GLDriver.bundle/Contents/MacOS/ATIRadeonX2000GLDriver 0x1a0d6000 - 0x1a0d8fff com.apple.PDFImporter 1.6 (???) /System/Library/Components/PDFImporter.component/Contents/MacOS/PDFImporter 0x1a1a4000 - 0x1a1e0fff com.apple.QuickTimeFireWireDV.component 7.3.1 /System/Library/QuickTime/QuickTimeFireWireDV.component/Contents/MacOS/QuickTimeFireWireDV 0x1a1ec000 - 0x1a206fff com.apple.AppleIntermediateCodec 1.2 (145) /Library/QuickTime/AppleIntermediateCodec.component/Contents/MacOS/AppleIntermediateCodec 0x1a20b000 - 0x1a210fff com.apple.AppleMPEG2Codec 1.0 (211) /Library/QuickTime/AppleMPEG2Codec.component/Contents/MacOS/AppleMPEG2Codec 0x1a216000 - 0x1a22ffff com.apple.applepixletvideo 1.2.9 (1.2d9) /System/Library/QuickTime/ApplePixletVideo.component/Contents/MacOS/ApplePixletVideo 0x1a259000 - 0x1a25cfff com.yourcompany.Plug-InSupport ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/Plug-In Support.vwlibrary/Contents/MacOS/Plug-In Support 0x1a262000 - 0x1a263fff com.apple.textencoding.unicode 2.1 /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings 0x1a36e000 - 0x1a3bafff net.nemetschek.vectorworks.aligndistribute ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/AlignDistribute.vwlibrary/Contents/MacOS/AlignDistribute 0x1a3fb000 - 0x1a3fbfff com.apple.URLMount.AFPPlugin 1.1.6 /System/Library/Filesystems/URLMount/afp.URLMounter/Contents/MacOS/afp 0x1a505000 - 0x1a5b5fff net.nemetschek.vectorworks.ColorPalettes ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/ColorPalettes.vwlibrary/Contents/MacOS/ColorPalettes 0x1a65c000 - 0x1a7ddfff net.nemetschek.vectorworks.DTM6InterfaceLibrary ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/DTM6InterfaceLibrary.vwlibrary/Contents/MacOS/DTM6InterfaceLibrary 0x1a910000 - 0x1aca9fff net.nemetschek.vectorworks.DWG Library ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/DWG Library.vwlibrary/Contents/MacOS/DWG Library 0x1b32f000 - 0x1b37bfff net.nemetschek.vectorworks.editshader ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/EditShader.vwlibrary/Contents/MacOS/EditShader 0x1b3bd000 - 0x1b41efff net.nemetschek.VectorWorks.ExtendedProperties ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/ExtendedProperties.vwlibrary/Contents/MacOS/ExtendedProperties 0x1b48b000 - 0x1b63afff >net.nemetschek.vectorworks.GeometryLib ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/GeometryLib.vwlibrary/Contents/MacOS/GeometryLib 0x1b77a000 - 0x1b9dcfff net.nemetschek.vectorworks.IFCLibrary ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/IFCLibrary.vwlibrary/Contents/MacOS/IFCLibrary 0x1bc9b000 - 0x1bce1fff net.nemetschek.vectorworks.PDFUtilityLib ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/PDFUtilityLib.vwlibrary/Contents/MacOS/PDFUtilityLib 0x1bd27000 - 0x1bde1fff DL61ACE /Applications/VectorWorks 2008/VectorWorks 2008.app/Contents/Frameworks/DL61ACE.framework/Versions/A/DL61ACE 0x1be33000 - 0x1c041fff DL61AGM /Applications/VectorWorks 2008/VectorWorks 2008.app/Contents/Frameworks/DL61AGM.framework/Versions/A/DL61AGM 0x1c20f000 - 0x1c23ffff DL61ARE /Applications/VectorWorks 2008/VectorWorks 2008.app/Contents/Frameworks/DL61ARE.framework/Versions/A/DL61ARE 0x1c272000 - 0x1c28cfff DL61BIB /Applications/VectorWorks 2008/VectorWorks 2008.app/Contents/Frameworks/DL61BIB.framework/Versions/A/DL61BIB 0x1c2b6000 - 0x1c2d6fff DL61BIBUtils /Applications/VectorWorks 2008/VectorWorks 2008.app/Contents/Frameworks/DL61BIBUtils.framework/Versions/A/DL61BIBUtils 0x1c304000 - 0x1c5a1fff DL61CoolType /Applications/VectorWorks 2008/VectorWorks 2008.app/Contents/Frameworks/DL61CoolType.framework/Versions/A/DL61CoolType 0x1c6fa000 - 0x1c7a9fff DL61JP2K /Applications/VectorWorks 2008/VectorWorks 2008.app/Contents/Frameworks/DL61JP2K.framework/Versions/A/DL61JP2K 0x1c7d5000 - 0x1ccd8fff DL61PDFL /Applications/VectorWorks 2008/VectorWorks 2008.app/Contents/Frameworks/DL61PDFL.framework/Versions/A/DL61PDFL 0x1d006000 - 0x1d0a1fff DL61XMP /Applications/VectorWorks 2008/VectorWorks 2008.app/Contents/Frameworks/DL61XMP.framework/Versions/A/DL61XMP 0x1d124000 - 0x1d212fff net.nemetschek.vectorworks.Plant Library ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/Plant Library.vwlibrary/Contents/MacOS/Plant Library 0x1d2e5000 - 0x1d31bfff net.nemetschek.vectorworks.rendersettings ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/RenderSettings.vwlibrary/Contents/MacOS/RenderSettings 0x1d352000 - 0x1d3a5fff net.nemetschek.vectorworks.TrueType ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/TrueType.vwlibrary/Contents/MacOS/TrueType 0x1d3f1000 - 0x1d559fff net.nemetschek.vectorworks.VectorScriptEditor ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/VectorScriptEditor.vwlibrary/Contents/MacOS/VectorScriptEditor 0x1d7a9000 - 0x1d7f7fff net.nemetschek.vectorworks.VSSharedLibrary ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/VS Shared Library.vwlibrary/Contents/MacOS/VS Shared Library 0x1d841000 - 0x1d87dfff net.nemetschek.vectorworks.vwlibrary ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/VWLibrary.vwlibrary/Contents/MacOS/VWLibrary 0x1d8ba000 - 0x1d955fff net.nemetschek.vectorworks.VCOM Provider Library ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/Workspaces.vwlibrary/Contents/MacOS/Workspaces 0x1da02000 - 0x1dc21fff net.nemetschek.vectorworks.xmllibrary ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/XML Library.vwlibrary/Contents/MacOS/XML Library 0x1de2d000 - 0x1de36fff com.yourcompany.PDFPage ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/PDFPage.vwobject/Contents/MacOS/PDFPage 0x1de89000 - 0x1debafff net.nemetschek.vectorworks.SectionLine ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/SectionLine.vwobject/Contents/MacOS/SectionLine 0x1defc000 - 0x1defcfff com.apple.URLMount.AFPGeneralUI 1.1.6 /System/Library/Filesystems/URLMount/afp.URLMounter/Contents/Resources/AFPGeneralUI.bundle/Contents/MacOS/AFPGeneralUI 0x1e005000 - 0x1e11ffff net.nemetschek.vectorworks.Callout ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/Callout.vwobject/Contents/MacOS/Callout 0x1e227000 - 0x1e27dfff net.nemetschek.vectorworks.ceilinggrid ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/CeilingGrid.vwobject/Contents/MacOS/CeilingGrid 0x1e2cd000 - 0x1e345fff com.yourcompany.ChainDimension ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/ChainDimension.vwobject/Contents/MacOS/ChainDimension 0x1e3a5000 - 0x1e3f3fff com.yourcompany.DesignLayerViewport ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/DesignLayerViewport.vwobject/Contents/MacOS/DesignLayerViewport 0x1e439000 - 0x1e5acfff net.nemetschek.vectorworks.DTM6 Object Snapshot ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/DTM6 Object Snapshot.vwobject/Contents/MacOS/DTM6 Object Snapshot 0x1e6ce000 - 0x1e843fff net.nemetschek.vectorworks.DTM6 Object ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/DTM6 Object.vwobject/Contents/MacOS/DTM6 Object 0x1e967000 - 0x1e9b6fff net.nemetschek.vectorworks.extrudealongpath ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/ExtrudeAlongPath.vwobject/Contents/MacOS/ExtrudeAlongPath 0x1e9fc000 - 0x1eabdfff net.nemetschek.vectorworks.FramingMember ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/FramingMember.vwobject/Contents/MacOS/FramingMember 0x1eb62000 - 0x1ec57fff net.nemetschek.vectorworks.General Notes ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/General Notes.vwobject/Contents/MacOS/General Notes 0x1ed3f000 - 0x1ed8efff net.nemetschek.vectoworks.helixspiral ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/HelixSpiral.vwobject/Contents/MacOS/HelixSpiral 0x1edd4000 - 0x1ef0ffff net.nemetschek.vectorworks.HumanFigure ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/HumanFigure.vwobject/Contents/MacOS/HumanFigure 0x1eff7000 - 0x1f10efff net.nemetschek.vectorworks.IFCEntity ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/IFCEntity.vwobject/Contents/MacOS/IFCEntity 0x1f268000 - 0x1f350fff net.nemetschek.vectorworks.Keynote Legend ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/Keynote Legend.vwobject/Contents/MacOS/Keynote Legend 0x1f431000 - 0x1f51bfff net.nemetschek.vectorworks.Plant Object ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/Plant Object.vwobject/Contents/MacOS/Plant Object 0x1f5e8000 - 0x1f6f6fff net.nemetschek.vectorworks.Space ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/Space.vwobject/Contents/MacOS/Space 0x1f7f1000 - 0x1f859fff net.nemetschek.vectorworks.TaperedExtrude ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/TaperedExtrude.vwobject/Contents/MacOS/TaperedExtrude 0x1f8ab000 - 0x1f8fbfff net.nemetschek.vectorworks.TextAlongPath ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/TextAlongPath.vwobject/Contents/MacOS/TextAlongPath 0x1f942000 - 0x1f993fff net.nemetschek.vectorworks.TexturedProp ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/Textured Prop.vwobject/Contents/MacOS/Textured Prop 0x20205000 - 0x20245fff net.nemetschek.vectorworks.movepage ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/MovePage.vwplugin/Contents/MacOS/MovePage 0x20283000 - 0x2037ffff net.nemetschek.vectorworks.delMeTool ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/Callout Tool.vwplugin/Contents/MacOS/Callout Tool 0x20470000 - 0x204c8fff net.nemetschek.vectorworks.eyedropper ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/Eyedropper Tool.vwplugin/Contents/MacOS/Eyedropper Tool 0x20511000 - 0x20550fff net.nemetschek.vectorworks.Trim ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/Trim Tool.vwplugin/Contents/MacOS/Trim Tool 0x2058d000 - 0x205fafff net.nemetschek.vectorworks.offsettool ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/Offset Tool.vwplugin/Contents/MacOS/Offset Tool 0x20652000 - 0x20692fff net.nemetschek.vectorworks.Shear ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/Shear.vwplugin/Contents/MacOS/Shear 0x206d0000 - 0x20711fff net.nemetschek.vectorworks.resize ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/Resize.vwplugin/Contents/MacOS/Resize 0x2074f000 - 0x20867fff net.nemetschek.vectorworks.Space Tool ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/Space Tool.vwplugin/Contents/MacOS/Space Tool 0x20971000 - 0x209b5fff net.nemetschek.vectorworks.duplicatesymbolinwall ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/Duplicate Symbol In Wall.vwplugin/Contents/MacOS/Duplicate Symbol In Wall 0x209f5000 - 0x20a34fff net.nemetschek.vectorworks.TapeMeasureTool ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/TapeMeasureTool.vwplugin/Contents/MacOS/TapeMeasureTool 0x20a71000 - 0x20ab2fff net.nemetschek.vectorworks.protractortool ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/Protractor Tool.vwplugin/Contents/MacOS/Protractor Tool 0x20af0000 - 0x20bedfff net.nemetschek.vectorworks.General Notes Tool ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/General Notes Tool.vwplugin/Contents/MacOS/General Notes Tool 0x20e05000 - 0x20e68fff net.nemetschek.vectorworks.IFCImport ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/IFCImport.vwplugin/Contents/MacOS/IFCImport 0x21005000 - 0x210b8fff net.nemetschek.vectorworks.Export3DSMenu ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/3DS Import.vwplugin/Contents/MacOS/3DS Import 0x2117e000 - 0x21257fff net.nemetschek.vectorworks.SU2VW ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/SU2VW.vwplugin/Contents/MacOS/SU2VW 0x213a9000 - 0x215c1fff Xerces /Applications/VectorWorks 2008/VectorWorks 2008.app/Contents/Frameworks/Xerces.framework/Versions/A/Xerces 0x21809000 - 0x21b29fff SketchUpReader /Applications/VectorWorks 2008/VectorWorks 2008.app/Contents/Frameworks/SketchUpReader.framework/Versions/A/SketchUpReader 0x21dd4000 - 0x21e87fff net.nemetschek.vectorworks.Export3DSMenu ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/3DS Export.vwplugin/Contents/MacOS/3DS Export 0x21f4d000 - 0x21f7efff net.nemetschek.vectorworks.fittoobjects ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/Fit To Objects.vwplugin/Contents/MacOS/Fit To Objects 0x21fb1000 - 0x21ffffff net.nemetschek.vectorworks.SunPosition ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/SunPosition.vwplugin/Contents/MacOS/SunPosition 0x22048000 - 0x22087fff net.nemetschek.vectorworks.alignlayerviews ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/AlignLayerViews.vwplugin/Contents/MacOS/AlignLayerViews 0x220c4000 - 0x22135fff net.nemetschek.vectorworks.extrudealongpathmenu ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/ExtrudeAlongPathMenu.vwplugin/Contents/MacOS/ExtrudeAlongPathMenu 0x2218e000 - 0x221e2fff net.nemetschek.vectorworks.TaperedExtrudeMenu ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/TaperedExtrudeMenu.vwplugin/Contents/MacOS/TaperedExtrudeMenu 0x22229000 - 0x22279fff net.nemetschek.vectorworks.helixspiralmenu ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/HelixSpiralMenu.vwplugin/Contents/MacOS/HelixSpiralMenu 0x222bf000 - 0x22319fff net.nemetschek.vectorworks.exportquicktimemovie ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/Export Quicktime Movie.vwplugin/Contents/MacOS/Export Quicktime Movie 0x2236c000 - 0x223b8fff net.nemetschek.vectorworks.obitanimator ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/Orbit Animator.vwplugin/Contents/MacOS/Orbit Animator 0x22401000 - 0x22478fff net.nemetschek.vectorworks.pathanimator ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/Path Animator.vwplugin/Contents/MacOS/Path Animator 0x224db000 - 0x2252afff net.nemetschek.vectorworks.roofer ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/Roofer.vwplugin/Contents/MacOS/Roofer 0x22572000 - 0x2261afff net.nemetschek.vectorworks.FitWallsToRoof ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/FitWallsToRoof.vwplugin/Contents/MacOS/FitWallsToRoof 0x226b0000 - 0x227bdfff net.nemetschek.vectorworks.Space Menu ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/Space Menu.vwplugin/Contents/MacOS/Space Menu 0x228b9000 - 0x2299efff >net.nemetschek.vectorworks.RoofFramer ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/RoofFramer.vwplugin/Contents/MacOS/RoofFramer 0x22a8d000 - 0x22acbfff net.nemetschek.vectorworks.purge ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/Purge.vwplugin/Contents/MacOS/Purge 0x22b04000 - 0x22cb8fff net.nemetschek.vectorworks.WorkspaceEditor ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/Workspace Editor.vwplugin/Contents/MacOS/Workspace Editor 0x22f4a000 - 0x22fcffff net.nemetschek.vectorworks.checkspelling ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/CheckSpelling.vwplugin/Contents/MacOS/CheckSpelling 0x23029000 - 0x23076fff net.nemetschek.vectorworks.TrueTypeToPolyline ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/TrueType To Polyline.vwplugin/Contents/MacOS/TrueType To Polyline 0x230bf000 - 0x2312ffff com.yourcompany.TextAlongPathMenu ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/TextAlongPathMenu.vwplugin/Contents/MacOS/TextAlongPathMenu 0x23188000 - 0x232b7fff net.nemetschek.vectorworks.Notes Manager Menu ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/Notes Manager Menu.vwplugin/Contents/MacOS/Notes Manager Menu 0x233db000 - 0x234f9fff net.nemetschek.vectorworks.IFCMenu ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/IFCMenu.vwplugin/Contents/MacOS/IFCMenu 0x23659000 - 0x237ecfff net.nemetschek.vectorworks.DTM6 Menu ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/DTM6 Menu.vwplugin/Contents/MacOS/DTM6 Menu 0x2391c000 - 0x2394efff net.nemetschek.vectorworks.guides ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/Guides.vwplugin/Contents/MacOS/Guides 0x23981000 - 0x239e4fff net.nemetschek.vectorworks.IFCExport ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/IFCExport.vwplugin/Contents/MacOS/IFCExport 0x89030000 - 0x890cffff com.apple.QuickTimeImporters.component 7.3.1 /System/Library/QuickTime/QuickTimeImporters.component/Contents/MacOS/QuickTimeImporters 0x8ef5d000 - 0x8ef99fff com.apple.CoreMediaIOServicesPrivate 1.2 /System/Library/PrivateFrameworks/CoreMediaIOServicesPrivate.framework/Versions/A/CoreMediaIOServicesPrivate 0x8efc2000 - 0x8efe5fff com.apple.CoreMediaPrivate 1.2 /System/Library/PrivateFrameworks/CoreMediaPrivate.framework/Versions/A/CoreMediaPrivate 0x8eff4000 - 0x8eff8fff com.apple.CoreMediaAuthoringPrivate 1.1 /System/Library/PrivateFrameworks/CoreMediaAuthoringPrivate.framework/Versions/A/CoreMediaAuthoringPrivate 0x8fe00000 - 0x8fe4afff dyld 46.16 /usr/lib/dyld 0x90000000 - 0x90171fff libSystem.B.dylib /usr/lib/libSystem.B.dylib 0x901c1000 - 0x901c3fff libmathCommon.A.dylib /usr/lib/system/libmathCommon.A.dylib 0x901c5000 - 0x90202fff com.apple.CoreText 1.1.3 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText 0x90229000 - 0x902fffff ATS /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS 0x90420000 - 0x904a6fff com.apple.QTKit 7.3.1 /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit 0x9080b000 - 0x908d3fff com.apple.CoreFoundation 6.4.8 (368.31) /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x90911000 - 0x90911fff com.apple.CoreServices 10.4 (???) /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices 0x90913000 - 0x90a07fff libicucore.A.dylib /usr/lib/libicucore.A.dylib 0x90a57000 - 0x90ad6fff libobjc.A.dylib /usr/lib/libobjc.A.dylib 0x90aff000 - 0x90b63fff libstdc++.6.dylib /usr/lib/libstdc++.6.dylib 0x90bd2000 - 0x90bd9fff libgcc_s.1.dylib /usr/lib/libgcc_s.1.dylib 0x90bde000 - 0x90c51fff com.apple.framework.IOKit 1.4.8 (???) /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit 0x90c66000 - 0x90c78fff libauto.dylib /usr/lib/libauto.dylib 0x90c7e000 - 0x90f24fff com.apple.CoreServices.CarbonCore 682.28 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore 0x90f67000 - 0x90fcffff com.apple.CoreServices.OSServices 4.1 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices 0x91008000 - 0x91047fff com.apple.CFNetwork 129.22 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork 0x9105a000 - 0x9106afff com.apple.WebServices 1.1.3 (1.1.0) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/WebServicesCore.framework/Versions/A/WebServicesCore 0x91075000 - 0x910f4fff com.apple.SearchKit 1.0.7 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit 0x9112e000 - 0x9114cfff com.apple.Metadata 10.4.4 (121.36) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata 0x91158000 - 0x91166fff libz.1.dylib /usr/lib/libz.1.dylib 0x91169000 - 0x91308fff com.apple.security 4.5.2 (29774) /System/Library/Frameworks/Security.framework/Versions/A/Security 0x91406000 - 0x9140efff com.apple.DiskArbitration 2.1.2 /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration 0x91415000 - 0x9141cfff libbsm.dylib /usr/lib/libbsm.dylib 0x91420000 - 0x91446fff com.apple.SystemConfiguration 1.8.6 /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration 0x91458000 - 0x914cefff com.apple.audio.CoreAudio 3.0.5 /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio 0x9151f000 - 0x9151ffff com.apple.ApplicationServices 10.4 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices 0x91521000 - 0x9154dfff com.apple.AE 314 (313) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE 0x91560000 - 0x91634fff com.apple.ColorSync 4.4.9 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync 0x9166f000 - 0x916e2fff com.apple.print.framework.PrintCore 4.6 (177.13) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore 0x91710000 - 0x917b9fff com.apple.QD 3.10.25 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD 0x917df000 - 0x9182afff com.apple.HIServices 1.5.2 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices 0x91849000 - 0x9185ffff com.apple.LangAnalysis 1.6.3 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis 0x9186b000 - 0x91886fff com.apple.FindByContent 1.5 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/FindByContent.framework/Versions/A/FindByContent 0x91891000 - 0x918cefff com.apple.LaunchServices 182 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices 0x918e2000 - 0x918eefff com.apple.speech.synthesis.framework 3.5 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis 0x918f5000 - 0x91935fff com.apple.ImageIO.framework 1.5.6 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO 0x91948000 - 0x919fafff libcrypto.0.9.7.dylib /usr/lib/libcrypto.0.9.7.dylib 0x91a40000 - 0x91a56fff libcups.2.dylib /usr/lib/libcups.2.dylib 0x91a5b000 - 0x91a79fff libJPEG.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib 0x91a7e000 - 0x91addfff libJP2.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib 0x91aef000 - 0x91af3fff libGIF.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib 0x91af5000 - 0x91b7dfff libRaw.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRaw.dylib 0x91b81000 - 0x91bbefff libTIFF.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib 0x91bc4000 - 0x91bdefff libPng.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib 0x91be3000 - 0x91be5fff libRadiance.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib 0x91be7000 - 0x91cc5fff libxml2.2.dylib /usr/lib/libxml2.2.dylib 0x91ce2000 - 0x91ce2fff com.apple.Accelerate 1.3.1 (Accelerate 1.3.1) /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate 0x91ce4000 - 0x91d72fff com.apple.vImage 2.5 /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage 0x91d79000 - 0x91d79fff com.apple.Accelerate.vecLib 3.3.1 (vecLib 3.3.1) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib 0x91d7b000 - 0x91dd4fff libvMisc.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib 0x91ddd000 - 0x91e01fff libvDSP.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib 0x91e09000 - 0x92212fff libBLAS.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib 0x9224c000 - 0x92600fff libLAPACK.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib 0x9262d000 - 0x9271afff libiconv.2.dylib /usr/lib/libiconv.2.dylib 0x9271c000 - 0x92799fff com.apple.DesktopServices 1.3.6 /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv 0x927da000 - 0x92a0afff com.apple.Foundation 6.4.9 (567.36) /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x92b16000 - 0x92b20fff com.apple.framework.AppleTalk 1.2.0 (???) /System/Library/Frameworks/AppleTalk.framework/Versions/A/AppleTalk 0x92b24000 - 0x92b40fff libGL.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib 0x92b4c000 - 0x92ba4fff libGLU.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib 0x92bb8000 - 0x92bb8fff com.apple.Carbon 10.4 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon 0x92bba000 - 0x92bcafff com.apple.ImageCapture 3.0.4 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture 0x92bd9000 - 0x92be1fff com.apple.speech.recognition.framework 3.6 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition 0x92be7000 - 0x92bedfff com.apple.securityhi 2.0.1 (24742) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI 0x92bf3000 - 0x92c84fff com.apple.ink.framework 101.2.1 (71) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink 0x92c98000 - 0x92c9cfff com.apple.help 1.0.3 (32.1) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help 0x92c9f000 - 0x92cbdfff com.apple.openscripting 1.2.5 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting 0x92ccf000 - 0x92cd5fff com.apple.print.framework.Print 5.2 (192.4) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print 0x92cdb000 - 0x92d3efff com.apple.htmlrendering 66.1 (1.1.3) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering 0x92d65000 - 0x92da6fff com.apple.NavigationServices 3.4.4 (3.4.3) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices 0x92dcd000 - 0x92ddbfff com.apple.audio.SoundManager 3.9.1 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound 0x92de2000 - 0x92de7fff com.apple.CommonPanels 1.2.3 (73) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels 0x92dec000 - 0x930e1fff com.apple.HIToolbox 1.4.10 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox 0x931e7000 - 0x931f4fff com.apple.opengl 1.5.3 /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL 0x93265000 - 0x93265fff com.apple.Cocoa 6.4 (???) /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa 0x93267000 - 0x9391dfff com.apple.AppKit 6.4.9 (824.44) /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit 0x93c9e000 - 0x93d19fff com.apple.CoreData 91 (92.1) /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData 0x93d52000 - 0x93e0bfff com.apple.audio.toolbox.AudioToolbox 1.4.7 /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox 0x93e4e000 - 0x93e4efff com.apple.audio.units.AudioUnit 1.4.3 /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit 0x93e50000 - 0x94011fff com.apple.QuartzCore 1.4.12 /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore 0x94057000 - 0x94098fff libsqlite3.0.dylib /usr/lib/libsqlite3.0.dylib 0x940a0000 - 0x940ddfff libGLImage.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib 0x940e3000 - 0x940f9fff com.apple.CoreVideo 1.4.2 /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo 0x94109000 - 0x945dafff libGLProgrammability.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib 0x9485d000 - 0x9486cfff libCGATS.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGATS.A.dylib 0x94873000 - 0x9487efff libCSync.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib 0x948ca000 - 0x948e4fff libRIP.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib 0x948ea000 - 0x94bfefff com.apple.QuickTime 7.3.1 /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime 0x94fde000 - 0x94ffbfff libresolv.9.dylib /usr/lib/libresolv.9.dylib 0x951a7000 - 0x9527ffff edu.mit.Kerberos 5.5.25 /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos 0x95e8d000 - 0x95e91fff com.apple.URLMount 2.1.7 /System/Library/PrivateFrameworks/URLMount.framework/URLMount 0x96d9b000 - 0x96d9bfff com.apple.vecLib 3.3.1 (vecLib 3.3.1) /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib 0x97315000 - 0x9731afff com.apple.agl 2.6.2 (AGL-2.6.2) /System/Library/Frameworks/AGL.framework/Versions/A/AGL 0x973fd000 - 0x97438fff com.apple.AppleVAFramework 4.0.13 /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA 0x97661000 - 0x976a0fff com.apple.AppleShareClientCore 1.5.3 /System/Library/Frameworks/AppleShareClientCore.framework/Versions/A/AppleShareClientCore 0x98649000 - 0x993c2fff com.apple.QuickTimeComponents.component 7.3.1 /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacOS/QuickTimeComponents 0x9960f000 - 0x99611fff com.apple.QuickTimeH264.component 7.3.1 /System/Library/QuickTime/QuickTimeH264.component/Contents/MacOS/QuickTimeH264 0x998df000 - 0x999a6fff com.apple.QuickTimeMPEG4.component 7.3.1 /System/Library/QuickTime/QuickTimeMPEG4.component/Contents/MacOS/QuickTimeMPEG4 0x9a1ab000 - 0x9a1c8fff com.apple.OpenTransport 3.0 /System/Library/PrivateFrameworks/OpenTransport.framework/OpenTransport 0x9fb14000 - 0x9ff69fff com.apple.CoreGraphics 1.258.77 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics Model: iMac7,1, BootROM IM71.007A.B01, 2 processors, Intel Core 2 Duo, 2.8 GHz, 2 GB Graphics: ATI Radeon HD 2600 Pro, ATI,RadeonHD2600, PCIe, 256 MB Memory Module: BANK 0/DIMM0, 1 GB, DDR2 SDRAM, 667 MHz Memory Module: BANK 1/DIMM1, 1 GB, DDR2 SDRAM, 667 MHz AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x88), Broadcom BCM43xx 1.0 (4.170.13.1) Bluetooth: Version 1.9.5f4, 2 service, 1 devices, 1 incoming serial ports Network Service: Built-in Ethernet, Ethernet, en0 Serial ATA Device: WDC WD5000AAKS-40TMA0, 465.76 GB Parallel ATA Device: OPTIARC DVD RW AD-5630A USB Device: Built-in iSight, Apple Inc., Up to 480 Mb/sec, 500 mA USB Device: Keyboard Hub, Apple, Inc., Up to 480 Mb/sec, 500 mA USB Device: Contour UniMouse Optical, KOOL, Up to 1.5 Mb/sec, 100 mA USB Device: Apple Keyboard, Apple, Inc, Up to 1.5 Mb/sec, 100 mA USB Device: IR Receiver, Apple Computer, Inc., Up to 1.5 Mb/sec, 500 mA USB Device: Bluetooth USB Host Controller, Apple, Inc., Up to 12 Mb/sec, 500 mA
When using the Grid Bubble Tool (from the Tool Set Menu > Dims / Notes), I like the idea of the Starting Marker, however, can one also add grid lines such as 1.4 into the line of column line makers? Or should I be adding this to the wish list? What have I successfully been able to label: A, B, C, D 1, 2, 3, 4 1.1 ,1.2, 1.3, 1.4 What have I not been able to do when labeling column lines: A, B, B.3, B.7, C 1, 2, 3, 4, 4.4, 5, 5.3 Also, interesting to note, that when one for instance sets the starting marker as A.2 then all the column lines are labeled with A.2 So how are people labeling the non-major grid lines?
I am wondering if there is a setting I am not aware of, which would cause the TRUE references to also export to the dwg's? Right now these simply do not show up in the dwg files, which makes effective consultant file exchanges impossible.
Back when using import referencing (in 12.5), I used to have a file for the structural grid and separate files each floor plan. To check alignment I had all floor plans referenced into the structural file and the respective floor plans above and below each 'active' floor referenced into the plans. Now using Design Layer True Referencing (in VW 2008). I am, for instance, only able to reference my structural grid file into each floor plan, but then not able to reference any of said plans into the structural grid file, because I get the following error message: 'The selected file cannot be referenced, because that would cause a cycle of design layer viewport style references'. How are people approaching this issue from a Work Flow point of view??
If you are using Design Layer Viewport Referencing you can check the 'Black & White Only' box under the Advanced Properties in the Object Info box.
Class Override not working on Referenced files using NEW true referencing
One of my colleagues found the answer: Under Tools > Organization > Viewports go to the Design Layer Viewport (the one that has the reference file in it) and select Edit. Then select Classes and change the Fourth column in this window from 'Use Viewport specific class definitions' to 'Use document class definition' (it's an icon that either has a picture with corners or the VectorWorks logo on a sheet of paper). Now everything will be in color in the Design Layer, but the class overrides in the Sheet Layer Viewports will apply to all the layers, referenced and active.
