RickS - Lab 8
    86
Everything posted by RickS - Lab 8
  1. We are having trouble with Keynote Legend using the Database. The only way we can get it to appear is if we place them in the model space.While this works ok, it leads to problems in terms of scales and sheet layout??? We run Win XP with VW2008 SP2. Spent about 2 hours trying to figure out why the keynote legend wont show up on any sheet/VP/Annotation spaces, only to find out that it wont work at all......It seems to us that it makes the most sense to have this in the sheet/VP/Annotation as opposed to the model space. Just like you would put text or other notes in the annotation space. Is there somewhy to get it to work?
  2. Figured it out - Kind of??? Noticed a post regarding a SP2 printing problem and they said.... "We are in the process of investigating the printing problem on Windows. For now, if you turn of the GDI + Image option on the Display tab of the VectorWorks Preferences, you will be able to print. Gunther" Tried this in SP1 and was able to print Greyscale to PDF. Not sure what the GDI+ is or does????
  3. PC, Running XP with Adobe Acrobat 8
  4. Thanks, I've tried that, but it always comes out in color? Not sure if there is some sort of settings conflict or iterface issues?
  5. Does anyone know a way to create a PDF greyscale, without just checking the "Black&White Only" box in Document Preferences which looses the shading/fills? Want to create a greyscale PDF either through the PDF Export or with Adobe PDF printer (Windows XP). Even when I check the "B&W" under the Adobe PDF printer settings, the resulting PDF file comes out in color?
  6. Thanks, Have the upgrade, just have not installed it yet.
  7. Is there any way to copy an object from some reference point? Basically, if I select an object and want to copy it from a reference point of another object, can it be done? I have tried selecting an object and then holding down the control key and moving it from the point of another object, but it just ends up automaitcally selecting the other object and copying it instead.
  8. Yep, that is waht i am talking about. So i guess there is no way to have a leader automatically generated, oh well.
  9. Sorry, I should be more clear. I am talking about constrained or unconstrained line dimensions. So if i am dimensioning something like casework and i have a small piece that is 3/4" wide, when i pull the text outside of the dimension, there is no way that a leader is generated from the text to the line of the dimension? It does pull the line of the dimension out to be under the text, but with a bunch of smaller dimensions, it becomes unclear. I used to use Microstation and it would automatically create a small arc with a filled circle on the end that went from the text to the center of the dimension.
  10. doesn't work on mine? I am using the standard VW 12.5 setup. Architectural Dimensions Setting, when I pull the text out from the center of the dimension, it just moves the text and line underneath. There is no arc or leader created. Tried using other dimension standard also.
  11. New to Vectorworks. Does anyone know if there is an automatic way to have leader lines generated when you pull the text of the dimsion outside of the witness lines? I would hate to have to go in and draw little arcs at all the dimensions that the text is too big to fit between the lines.
