Does anyone know how to merge two or more similar data sets from separate worksheets into one worksheet and have the merged data be sortable?
I would like to combine a Windoor schedule with a VW schedule.
(I setup the combined Windoor/VW schedule that comes with Windoor only to find that it is not interactive.)
Hi Tasmin,
In what way can "you get raw 3D geometry to work with the site model"?
I have tried to use the site model many times only to be frustrated by the lack of fine control and the fact that it does not accurately model in accord with the original topo lines (3d polys) it is based on.
Thank you in advance for any comments you may have in this regard.
digital,
What profile did you EAP to define the grade at the foundation? Why not just use a 3d poly?
I have tried many times to do what you show in your video, only to have the DTM do something unexpected that can't be rectified.
Thanks again. I still have not been able to get this to work. When the hole cutting channel cuts the end of the wall the plug-in windows go crazy. I ended up using an extrude along path and cutting out the doors and windows.
Hi Dieter,
Thank you for the response.
Should the original symbol be 2D or 3D?
Place 2 2D loci directly on top of each other in plan view? How does that help "find" (do you mean "place"?) the symbol in the wall?
Should the loci be 3D loci?
The 3D wall hole component will cut a horizontal channel in the face of the wall without cutting all the way through?
Can the reveal channel cut across door and windows in the wall?
Should the symbol in wall placement option be set to "on edge"?
Thanks in advance for any further clues on how to get this to work.
The restart did it. Thanks Farookey & maarten!
Farookey: That is one very useful script! Surprising that such a simple and useful command is not included in VW out of the box.
Sure:
Open VectorScript Plug-in Editor; select New; Enter name for plug-in and choose type(I tried both Command and Tool); hit OK; open VectorScript Editor and paste script text; hit OK, OK; use the Workspace Editor to add the command to a drop down menu; choose command from the drop down menu and it does not work.
Any clues regarding how to create a VectorScript Plug-in using a script and the VectorScript Plug-in Editor would be greatly appriciated. I followed the steps provided in the help dialog but it did not work. The script works fine when run simply as a text file but does not work when made into a plug-in with the VS Plug-in Editor.
I am sure I am missing some simple step not included or clearly stated in help.
Thanks in advance.
