mjm
1,270 -
Posts posted by mjm
this is the way
7 hours ago, line-weight said:
Well, I'd never realised this either - it has never occurred to me that it would make a difference whether you're in a SL or DL when you access something from the RM. And why would it?
It probably explains many cases where I've got confused about what's going on when I'm trying to edit a hybrid symbol definition.
And trying to symbol edit from SL is just a disaster.
This issue has been driving me insane for years. IMO, when I enter symbol edit mode, no matter DL or SL or RM, they should all 1-click me to symbol edit mode.
- 1
19 minutes ago, Tom W. said:
It looks like in the older file you are editing the symbol from a Sheet Layer whereas in the newer file you're editing it from a Design Layer. You really want to be in a Design Layer when editing a 3D symbol.
It['s breathtaking to me that I have to EXIT SL, then enter DL, THEN enter symbol edit mode if I don't want things to go haywire.
Backing out to DL then Symbol Edit mode is extremely frustrating.
4 hours ago, frv said:
If not for free, a dedicated render app compared to VW is so much easier and quicker in the overall workflow that the price does not matter.
I tried Enscape and even though the quality is not fantastic I was able to have a project rendered in less than an hour (rendertimes just seconds) even though I had zero experience with Enscape. I would love to see Enscape in a vieuwport.
VW managed to slow down Redshift to rendertimes as they where in the previous century. In C4D Redshift is interactivly rendering while modeling. VW could streamline VW by improving shaded view and hidden line further and skip all other renderoptions and 99,9% of users would not mind.
I depend on the redshift renderer in RW. Make it faster / better, do not deprecate.
- 2
4 hours ago, digitalcarbon said:
ok thanks. I may have to go to the web site. @Pat Stanford do you have a link?
@mjm thanks but now I have another problem.
I applied one of these fonts to my spec sheet and now I need 2 sheets if I use these new fonts.
Currently using Times New Roman.
So that's the thing with mono-spaced fonts, they mostly take up much more space. Some variants might offer a 'compressed' version. Maybe look over here as a starting point.
- 1
All fixed width fonts on my MBP show a version ion both your lower case 'I' and your lower case 'l'
Andale Mono
Monaco
Menlo
SF Mono
are all available on my machine - however I DID cheat and use Font Book.App😃
definitely not alone in this regard
- 1
6 hours ago, Pat Stanford said:
Remember that the memory in the M series is shared between the CPU and the GPU, so when you start rendering you are really reducing the amount of memory available for non-graphics tasks.
Do you usually run with just VW open? Or do you have a bunch of other programs as well. If others, then think really hard about getting more memory.
This also applies to multiple drawings open, near as I can tell. I render thru renderworks alot. The shared memory pool is where I missed the bus
Hello @Darcy—I bought a MBP M1 Max, 32 GB ram. he mistake I made was the 32 GB ram. I should have gotten the 64GB ram option, this due to my renderworks needs.
2D drawing, you're probably fine with 32GB, but things sloooow way down on big render
- 2
23 hours ago, Tom W. said:
Ah right I think I saw another post about this. Yes must be Windows specific. Everything gets squished to one side rather than spread out evenly across the full width (which is what happens with me). Not good.
I'd really like to be able to justify right/left , up/down the toolsets in their containers
- 2
@VIRTUALENVIRONS—gorgeous
5 hours ago, VIRTUALENVIRONS said:
Hi Chame
Not sure what 5V means? Could you please explain?
I was thinking about this today. I decided to make one where the connecting splines are also curved. See below. If you notice, the sphere is completely spherical, no straight lines.
I am a little busy tomorrow, but could make a video on my methodology later this week.
@VIRTUALENVIRONS: look here for 5V Geodesic definition
- 1
6 hours ago, Kevin Allen said:
All in one App is important Renderworks needs love.
word
- 1
In Apple apps like Pages and Numbers, there's a keystroke for that: command+option+shift+V.
Works a charm!
- 1
On 10/17/2023 at 12:03 AM, bjoerka said:
yes correct. but the main problem is that most of these elements are part of symbols and so someone has to manually go through all symbols and edit these.
and inside the symbol it is not possible to change these elements from screen plane to symbol definition. it always swaps back to screen plane...
@bjoerka Ouch. Sorry to hear that
If I understand, these may be objects made of other objects, some, at least one of which, should be screen plane. I've had to go into edit mode on those items and then use the magic wand set for only "plane" in the 'other attributes' section. tedious but gets it done eventually
7 hours ago, klinzey said:
I noticed that the fixture that you are using in from Robe. Robe updated their GDTF to use the newer glb/gltf for the 3D geometry which is not supported in Vectorworks 2023, it can only read 3ds based geometry.
The best thing to do is to to select a Vectorworks symbol.
With he light selected press the Replace Lighting Device... button in the OIP.
Select the appropriate symbol from the Resource Browser and click Select.
Uncheck the "Use GDTF Geometry" option.
You will still be able to maintain the link to the GDTF and the GDTF file will be exported when you export to MVR but it will show the 2D and 3D geometry from the Vectorworks symbol.Great info @klinzey. Any idea when VWX will update their GDTF importer to include the newer glb/gltf types?
- 1
I cannot believe how often it gets in the way!
Ouch. That also got me a few versions back & I have been much better about remembering @ install to immediately go to VW prefs & set my autosave prefs.
4 hours ago, JustinVH said:
Hello all,
I just wanted to give a follow up to this thread. The ETC Source 4 LED Series 3 library has been completed and it will be released in the September 2023 Premium Library in the US International version of VW2024. This library will feature both the Lustr X8 and Daylight HDR versions with all of the standard barrels and Zooms, the EDLT barrels for 19-50°, and the XDLT barrels for a total of 46 new fixtures. All of the weights have been updated to include the combined weight of the LED engine, specific barrel for lens, and specific lens tube as well as updated photometrics based on publicly available data on the ETC website. The power fields in the LIR are also updated to match the different wattages between the Daylight and Lustr versions and the new EntEquipUniversal record has been added for use with the new VW2024 Equipment List feature.
I would also like to point out there the lens tubes are drawn in their maximum forward position so that the symbol is taking up as much space as possible to make spacing decisions when hanging. There is a faint grey dashed line showing the minimum distance as well as there have been users who requested that information so they know the full distance the lens tube can move. If after viewing these symbols there is a large consensus that this grey line is not needed it can be removed and the library re-released in November 2023. Thank you all.
Justin
WOW and thank you @JustinVH!!!
17 minutes ago, E|FA said:
Don’t forget to vote on the related Wishlist item:
O -THAT done as soon as the poll came out, AIR
Unified view?
in General Discussion
Posted · Edited by mjm
Or save a copy as…
& make sure your autosave is set
