Okay, I understand. It makes no sense to me that a lighting device is indellibly linked to a focus point, and can't be panned and tilted at will, and I'd guess I'm the zillionth spotlight user to say that. In my case, with 50 lighting devices that I want to focus straight out from their vertical hanging positions, I'll have to create 50 focus points, then go thru each unit 1 by 1 and assign them to their matching focus points 1 by 1. It's painstakingly slow and wrought with problems like which editing window lets me use a pull down menu the contextual "edit" dialog box) vs. having to remember and type out the name of each focus point (like in the object info palette).
So my "problem" has evolved into a "suggestion". I'm using 2010, waiting for our friends at ESPvision to give the green light to update and not have their tools choke.
1) unify any and all palettes, modal dialogs, windows, other places you specify a focus point for a lighting device to both a text field and a pull down menu of existing focus points to select. Right-clicking a lighting device and choosing Edit in the Visualization palette produces a modal dialog box that does not include either the field or the pull-down for focus points.
2) in palettes and modal dialogs that contain the focus point pull-down selection menu and the manual focus buttons and sliders, allow the user a pull-down selection of "manual" to break the reference to any focus point and enable pan and tilt slider use. The application can create a "private focus point" that's bound to the device(s) selected and manually focused, and updated whenever changes are made with the sliders.
3) allow the user to create focus points numerically a) in relation to the light to allow "artistic" look creation rather than 1-for-1 focus point creation for every unit to create graphic lighting looks. Example: Focus point "all up", relative to the unit = 0 deg. pan, +60 deg tilt.
4) add "show/hide beam" to the contextual menu for a lighting device.
5) add "focus light" to the contextual menu for a lighting device, pop up dialog with unified text field + pull down menu + numeric entry field + sliders as discussed above.
6) (and in my mind most important) unify single/multiple editing across all selections/dialogs/palettes/etc.
When I'm done beating this file to death I'll put it up for you to look at. I'm having a myriad of problems with it anyway.
Thanks for reading
