higgins
53 -
Everything posted by higgins
Hi all! I bought an external screen for my laptop to increase my productivity. The problem is, scrolling doesn't work on the external screen! In every other app, scrolling works, but not in VW. Not having mouse wheel zoom is dreadful! Any ideas? VW2008 Win7
Are complex line types finally available in VW2010?
higgins replied to higgins's topic in General Discussion
Oh well... =( I've tried the repetitive unit thing and it is an utter horror. I much prefer using "copy along path" but both of those methods are IMO a major waste of time. -
Hi! My country's standard planning symbols/line types are all based on AutoCad and MapInfo. Does VW2010 finally have a way to add or design new line types, such as zig-zags, lines-with-borders, letters/symbols on lines at regular intervals, etc. Thanks!
Thanks for the reply, but to test it, I drew a bunch rectangles inside one another, made them 3d polys and elevated them to a small rectangular hill... When I modify that, I get Cut Volume 0.0000 Cu M. Still no good.
Hi all! Okay, I have a very small and simplistic site model and I need to model a pond there, so, I thought to try my hand on the pad and fence tools... I can get the contours to change pretty much as I like, but for cut & fill volumes I get a confusing message. Okay, my lowest pad is below the lowest contour line that I have, so the contours aren't perfect, but I get the same error when I simply build a small elevation on the model, so, this can't be the issue. What am I doing wrong?
I'm amazed, but the first method works! How the heck does it work that out on a plain .png raster? I've no idea, but it's awesome! =D The second method didn't work for me though.
Hi! How do you import raster images in scale? Say, I have an aerial photograph and I know it's scale is 1:1136. How can I accurately get it into my .vwx file in scale? VW2008, Windows XP
Hi! I've created a polyline road and sent it so surface, and then set it 20 cm higher so it wouldn't have "gaps" in it. The road is perfectly visible with OpenGL rendering, but if I render with Renderworks it disappears. If I pick Fast Renderworks, only parts of the road are visible. What's going on? I thought it might be something I've missed with textures as I'm new to Renderworks, but the issue still remains if the textures are taken off.
Hi! Is it possible to make a video out of your 3d model using VW? What add-on program(s) would one need to do that? I'm using Windows, but I'm sure any Mac specific programs would also be worth mentioning for other people.
Hi all! Why Roadways and Extrudes don't shape themselves to fit the Site Model the way 3d polygons do? I can emulate Roadways with 3d polys, but what with Extrudes? I try to emulate a stone fence with an extrude, but it just don't fit the site model as it hangs there in the mid-air and below the ground in some places.
Same issue with the massing model. If styles are assigned to the walls/roof, no rendering occurs. This means I can only set texture via class, and this also means that I cannot put texture on the walls... How can I solve this?
I think it was a mistake to set classes for paving and curbs while using the object from ployline command. It renders now fine when I set those to "none".
Straight roadway renders and so does curved, but not NURBS. It basically stays as wireframe, but some weird lines are added. What am I doing wrong? Straight and curved combined is no good, as sending them to surface creates "steps".
Hi all! I think I must be missing something essential here. I cannot seem to change the side the road turns. It always turns to the right and I have to use mirror tool to reverse the turn. There's got to be an easier way... And when I put the curve on the end of a straight road, and then need to adjust the length of the curve (by adjusting the sweep) it always uses the other end as fixative point. What am I doing wrong? How can I determine the way curve is bent? And how can I determine the fixative end of a curve?
So the regular polygons are okay? Do you know if the bug is fixed in VW2009?
Springing off from strategy change thread: Any more information on that? Where is the wrong displayed and where is the correct area shown? How can I make sure that the area is truly correct? Is the bug fixed in VW2009?
Another dispute in my company... Upgrade VW or switch to MicroStation/AutoCAD. Do newer VW reference .dwg directly? The issue is that importing .dwg liberates lines from their standard form.. a lots of lines are marked like... ----E--------E---- for electricity for example and since VW doesn't support such, it creates problems. Has this issue been fixed in 2008/2009?
Do we also have complex line styles now that we can apply via attributes palette? *crosses fingers*
Thanks for quick replies! I sure wish we could enter the group as well... or better yet. Choose the roof type from the options as we create the models.
This is an awsome tip! But how do you connect the roof back to the building, so the object becomes a massing model again? Plain grouping is no good since you can't change attiributes afterwards, send them to surface etc.
Replacing objects and general site modeling?
I got 3d points from one surveyor, so that's good, but I think I have to do the other site manually. Is there a keyboard shorcut for choosing next object/locus and jumping to OIP? -
Might be you were looking for this: http://download2.nemetschek.net/www_misc/2008FeatureMatrix.pdf
Hi! Surveyor provided me a dwg file where all surveyed points were circles. Heights are on the side as text. Can I replace all circles with 3d-locuses with some command? Using VW 11. And any convinient way to assing the height without having to select them by mouse, move the cursor to OIP and typing the relevant number there? Like... some keyboard shortcut for choosing next object/locus and jumping to OIP? Finally. How can I explain to an AutoCAD using surveyor in his terminology, what form of data I need for best results in VW site modeling? I'm relatively new to 3d site modeling, but a net of 3d loci seems the best so far (I've had no luck with modeling from horisontals).
1:500 1:2000 World coordinates. That's my main problem. There doesn't seem to be (at least when imported) any 3d objects when I import "all 3d". Okay, there is a single object off the others, at the height of 144,1 m, but I belive it's there by error. Hmm... I'm not sure what you mean by that. Could you elaborate? Perfectly. Was one of the first things that I tried... Separated 6 from 156 and it worked. I think I resolved my issue. I imported the file as "all 3d" whili I should have done it 2d. I bet it was the "convert to polygons" command I applied to 3d ploys that messed the file up. I imported the file in "all 2d" separated the horisontals on a separate layer, composed them, converted into polygon from polylines and it seems to work now! I only have to make a pdf first to zoom in so I could see the actual heights in another window when applying them. But what's the difference in convering in wireframe or hidden line mode? Can it be done in VW 13?
Hi! I'm trying to create a site model with VW 11 using 2D Polys to 3D Contours command from dwg imported contour lines, but the instant I launch the command, VW zooms out to the print area so I cannot even see the lines, not to talk of the values written next to them. Then, as it wasn't bad enough, it places a single contour (chosen randomly?) and offers to delete the original polygons. Polygons get deleted no matter what I pick and only a single contour is made. Any help? :crazy:
