drmdzh
    169
Posts posted by drmdzh
  1. I am trying to create a standard orthographic projection theatrical drafting from a 3D object. So I created a viewport of the front elevation on a new sheet layer. The Design layer is in 1:24 scale and the viewport is in 1:24 scale, however, when I try to dimension the object, it gives me true scale in the dimension.
    1. How do I get the dimensions to be in scale?
    2. Is creating viewports in a new sheet layer of 3D objects the best way of creating standard orthographic projection draftings.
    thanks
    David
  2. I am rendering using "fast renderworks with shadows". I have several image props in the model but they lighting I am using is not effecting them at all. Should lighting effect image props? I have checked the "Cast and receive" buttons in the image prop texture editor.
    thanks
  3. I am designing a set where I wanted a light source inside a cellar, making the whole cellar glow from inside and light coming out small barred windows.
    I have lit the set generally with some spots at low level, and they are casting nice shadows everywhere. I put a point source of light in the cellar to give it a radial source, but the whole set now lights up, as if there were no walls or anything in the way of the light source. I checked "Cast shadows" in the light source but it doesn't help... what gives? Do point sources ignore objects for some reason?
    thanks
  4. Thanks all. Here's the object file. I've rendered it in OpenGL. I used the polygon and rectangle tool to make the 2D objects, so I'm pretty sure they are not open. Then extruded. They will only appear in wireframe (even in the other document I took them from where everything else is rendered fine)
  5. Just upgraded from 12.5 to 2009. Haven't used the program in a year (have been designing costumes)but now back to it.
    I have a REALLY simple question. It used to be that I could draw a polygon with the 2d polygon tool, or rectangle, etc and then extrude and I'd have a nice solid object. Now however, I only ever get a wireframe when I extrude. All of my stuff from 12.5 is rendered with textures and everything, but I can't seem to get anything but wireframes now. What changed? What do I need to do now to convert a 2d polygon into a solid object? What is extrude for, if not for that?
    very confused, thanks in advance.
  6. I am trying to make an 1/8" cut-out of this bridge shape. I traced over an image and as I did each part, I extruded 1/8".
    Now I need to make it all one piece. But when I select all and "Add solid" I get a "cannot be computed" error.
    I've also tried to convert copy to lines (or ploys) and then extrude from that. No success.
    Any help would be greatly appreciated.
  7. OK, I found a way to do it, but I don't understand why.
    I took the same file I posted, Convert to Lines, Create Polygon from Inner Boundry, Extrude. Got a solid.
    If I Convert to Lines, COMPOSE, then either Create Polygon, or not, then extrude, I get a shell.
    Why was composing making it into a shell, rather than a solid?
  8. OK, I'm obviously missing something. I keep having the same probelm over and over again.
    I create a shape in 2D. Then no matter how I stitch and trim, convert to (whatever - I've tried everything), compose, decompose, group, etc, etc. I can't make a solid object out of it. When I extrude it comes out as a shell.
    This is a simple seat cushion. How can I make it a 3d seat cushion.
    Conversely, how would you have gone about making it. I used polygone tool, arcs, fillet tool, trimmed. This is obviously incorrect.
    David
  9. So how would I go about making them solids?
    I used extrude to form the wall. Then I tried doing the "Extract Curve" - Extrude along path thing, just like in the tutorial to create the top of the wall. I turned the extrude into a nurbs curve while I was doing that I think, nothing I tried could make it work. I managed to extract the curve, but couldn't extrude along it. So I traced the top line of the wall and extruded along that.
    I have read the entire book, worked my way through the tutorials, some of which don't even work (see my other post) and still find that almost everything I try to do doesn't work. I have never been as frustrated and angry with something as much as this. It is driving me crazy and the book really doesn't explain things, like the answer you just gave me. It WAS a solid, I converted it to try to do something else, can I convert it back?
