Caslo
    5
    Never
Reputation
0 Neutral
Personal Information
  • Occupation
    Designer
  • Homepage
    www.scottyrv.com
  • Location
    Mt Pleasant, PA, USA
  1. Caslo
    Training
    We are looking for a trainer to come to our Western PA location for training. Any advice??
  2. Caslo
    Help!
    I have Vectorworks 8.5 for Windows. The company I work for builds commercial trailers. I am unable to use some of the commands and tools because of the design of our trailers, and I am having a few difficulties getting results that my employer and I want. Listed below are the ones I have been unable to figure out. 1. When I insert symbols that I have drawn, into a drawing I am working on, it sometimes comes in invisible. The ?ghost image? is there until I get it into the place I want it and hit the ?enter? key. After that, the symbol is invisible. By accident I have found they become visible again when I use the ?create stair? tool. Do you know why it happens this way? 2. I drew a floor plan with a second story floor that I inserted as a symbol on its own layer. I did a layer link on the layers, but when viewed in 3-d, the second story frame is on the top of the wall where the roof should be. When viewed in the ?front? view with the layer link layer turned off, the floor frame is seen where it should be. On a separate floor plan with a similar problem, the walls looked to be at least 3? above the floor frame. I have changed the ?Z? & ?delta Z?, and neither floor frame nor the walls have changed where they are. These are the only two floor plans I have attempted to draw. 3. I have also drawn up our steel frames with axles and tires to put underneath our trailers. But when I try to pull the frame symbol into a drawing, the whole frame comes in as an ?arc?. Unlike in question #2, ?create stair? hasn?t helped. Do you have any ideas as to why this has happened? I have added texture to my walls and rendered it with QuickDraw 3D Interactive, everything looks fine. I try to print it out, but nothing prints-except for 2-d objects like the border. Everything prints when I use the ?Solid? rendering (except for, of course, the textures).
  3. I am having problems with the texture showing up on the screen. I can add textures, but when 3d rendering all the items look black. If I zoom way in I can see the texture lines but it is still dark. I need to use the exterior siding and the interior wood paneling, both are almost black???????? This is PC not MAC. Thanks
  4. We are located in south western PA, I would like to have somebody to come to our manufacturing facility and do some instruction for the use of this software. We are doing well with the 2D but would like some pointers on 3D, rendering, texturing etc. HELP!
  5. I have Vectorworks 8.5 for Windows. The company I work for builds commercial trailers. I am unable to use some of the commands and tools because of the design of our trailers, and I am having a few difficulties getting results that my employer and I want. Listed below are the ones I have been unable to figure out. 1. I need to add a ?degree? symbol in my text for some drawings. 2. When I insert symbols that I have drawn, into a drawing I am working on, it sometimes comes in invisible. The ?ghost image? is there until I get it into the place I want it and hit the ?enter? key. After that, the symbol is invisible. By accident I have found they become visible again when I use the ?create stair? tool. Do you know why it happens this way? 3. I drew a floor plan with a second story floor that I inserted as a symbol on its own layer. I did a layer link on the layers, but when viewed in 3-d, the second story frame is on the top of the wall where the roof should be. When viewed in the ?front? view with the layer link layer turned off, the floor frame is seen where it should be. On a separate floor plan with a similar problem, the walls looked to be at least 3? above the floor frame. I have changed the ?Z? & ?delta Z?, and neither floor frame nor the walls have changed where they are. These are the only two floor plans I have attempted to draw. 4. Because of the design of our trailers- wheel wells and baggage doors, among other things- I am unable to use the ?Create Walls? tool, and must draw all the walls. I draw them using the ?Rectangle? tool for the studs & plates, then I extrude the whole frame to the depth of our framing (2 1/2?). After drawing around the framing using the ?2-D Polygon? tool, I ?cut out? openings for the windows and any storage doors from this polygon. I then extrude the polygon to 1/8?, using that as a basis for my interior ?paneling?. I ?duplicate array? it to have one for my exterior ?siding?. I am unable to get the texturing to work on this base. I use the ?Object Info? palette to add the image-based texture, then render it using the ?Quick Draw 3D Interactive? rendering. What am I doing wrong? 5. I have also drawn up our steel frames with axles and tires to put underneath our trailers. But when I try to pull the frame symbol into a drawing, the whole frame comes in as an ?arc?. Unlike in question #2, ?create stair? hasn?t helped. Do you have any ideas as to why this has happened?
