w.wolf
    3
Reputation
0 Neutral
Personal Information
  • Occupation
    Architect
  • Location
    Munich, Germany
  1. Still having the problem I posted some time ago (before this area was created): Some sheets do not allow creating a pdf file - and I cannot understand why. For another sheet of the same document: it works perfectly. What I do: having choosen the sheet, in the printer menu I choose "Acrobat PDF 8.0." What happens: instead of opening the window that allows me to choose the folder the pdf should be saved in, the small printing window appears for several minutes, but no file is generated. What I tried: I tried various combinations of page-formats, but this is no help. I tried from both computers (one using Acrobat 8 prof. and the other Acrobat 7 prof.. Same result. So I think it must be some problem with the sheet. Someone with the same problem? Would be great to get some help. Thanks in advance. W.
  2. thank you. will do so asap. Running OS 10.4.11. no troubles yet.
  3. Sorry to disturb, but I have a problem I never had before and don't find the solution myself: I am trying to print a sheet with the printer Menu, choosing as printer: Acrobat PDF 8.0. I do not get the save to: menu but the spall printing window appears, but no file is generated. As soon as I try to print from the normal layers, it works. Already tried various combinations of page-formats, but no success. Anyone some idea? Thanks in advance. W. PS: Still using VW 11 on a Macbook C2D, Acrobat Professional is 8.0.
