MSLD
  • Content Count
    81
Everything posted by MSLD
  1. I'm having issues with the 2018 SP3 titleblock. I've create a field that is a pulldown and defined the choices, but when I go to use that field, it gives me a check mark next to a blank value. Editing the field shows the pop-up values, but they never appear in the titleblock. Anyone else having this issue?
  2. MSLD
    Wall reshape
    Brilliant! Thank you
  3. MSLD
    Wall reshape
    I have a wall style made up of several components. When I want to reshape the wall to fit the cathedral ceiling, the reshape tool only adjusts the siding component, not the whole wall. Similarly, if I use the "Fit walls to object" walls with a horizontal top extend to the roof correctly, but for walls that slope, only the external component (siding or bricks) is extended. How do I resolve this?
  4. Thanks. Used an XML editor to modify, and it worked great.
  5. Is there a way to edit the list of saved Custom Naming Schemes for publishing? I have several custom names used on specific files, but it seems the naming scheme is universal. Is there an xml file I can edit to delete unwanted schemes?
  6. Is there a way to use worksheet/ reports to modify title block information? I often have files with 100+ sheets, and would like to have a way to modify title block information on specific sheets quickly. Using worksheets, I'm able to change values, but it's not updated on the drawing until I open and close the title block settings. Is there a way to force the update?
  7. We're using dropbox to host a project file, with the working files, xml files, and lightwright6 files saved locally. Every hour or so, vectorworks will quit. No hanging, no crash report, it simply quits. I've got the lighting layer checked out, an no one else is working on the lighting layer. Frequently, when restarted, lightwright exchange is turned off, and I have to re-build the connection to the xml file. Any ideas?
  8. Love the "Edit Class Names" in Oz. What would it take to get it in the US? Symbols having embedded classes can be useful, but there are always different ways of categorizing objects. Rather than deleting all the classes in 2019, we need a more efficient way to rename and work with large blocks of classes
  9. Yes, please. Now that vectorworks has class information on all lighting symbols, cables, hoists, etc. I find I spend an inordinate amount of time cleaning up drawings. A rep plot from a theater may have started in Autocad, used in vectorworks for the 2015 season, then added new moving lights (and classes) in vectorworks 2017. I'll find classes for Rigging-Hoist-label, Rigging-Label, Motor-Name, (all for the same thing). I recently purchased an upgrade from Spotlight to Designer just so I could get the class mapping tool. A search and replace for parent and child names would be great, as well as a more efficient way of merging classes. Until there are class naming standards for the theater like they have for Architecture, we'll have to spend a lot of time doing cleanup.
  10. Here is a file. It couldn't import it. I restarted vwx, and could then import it. The file is tiny, so I don't see how memory is an issue. SFC4-LSE.pdf
  11. Is anyone else having problems importing PDFs? Frequently 2017 will say it can't import a PDF, or the PDF is corrupted. I restart vectorworks, and it imports with no problem. Not sure if it's a memory problem, a graphics card getting too tired, or what.
  12. Is there a way to set a hierarchical view in sheet layers? For drawings with over 100 sheets, it's a pain to scroll through everything. Is there a way to minimize non-active sheet layers?
  13. Noticed an issue with the callout tool. I've placed a callout in a design layer. When it's in a viewport on a sheet layer, it's fine. However, if I used the viewport advanced properties to scale the text, the callouts scale and move. I won't argue if this is a bug, a feature, or it's supposed to work this way. Callout Issue.vwx
  14. What is the best solution for dealing with the same type of instruments that have different wattages? If the default for a S4 leko is 575w, if you have a combination of 575w and 750w, the instrument summary won't work. At one point someone suggested duplicating the entire ETC library for 575w, 750w, 77V lamps. It seems there should be an easier way. Any suggestions?
  15. MSLD
    Lightwright6
    I've been using LW6 6.0.4.103 beta and VWX16 and it seems to play nicely. I set up my address format as universal (universe/address). The dimmers are now only for dimmers and power. Moving lights use the Address field. You can set the universe in the Universe or the Address field, and it transfers correctly to/from vwx.
  16. Yes please! It's a pain when I get a rep plot from a venue and try to drop in new lights, or take a 2015 touring plot and update it. Everyone has different naming conventions, and deleting and re-naming classes individually can add hours to a project.
  17. Yes please! It's a pain when I get a rep plot from a venue and try to drop in new lights, or take a 2015 touring plot and update it. Everyone has different naming conventions, and deleting and re-naming classes individually can add hours to a project.
  18. Yeah, it's just annoying that they force us to upgrade from spotlight to the designer edition because they don't want to let Spotlight users have class mapping.
  19. Yes, I support using classes extensively. Unfortunately the names VWX has chosen are not what I would use, and when you bring in elements from different drawings I end up with classes: Rigging-Hoist, Rig-Hoist, Rig-Motor, Rig-Motors, Motor-Hoist, ALL FOR THE SAME THING! I then have to manually delete classes to reassign to the proper class. When are we getting Class Mapping?? Don't give us tons of classes without the tools to work with them. Michael Sharon Lighting Designer Los Angeles
  20. What I'm trying to do is to have saved views or rendered sheet layers where i can show different gobo looks without having to select and change the gobos in the lights. If you apply a class to the light fixture, it won't take the texture as a gobo. I have made projection 'screens' with stacked images in different classes which works, but it doesn't make use of the flexibility of the Plug-in.
  21. Is there a way to assign classes to textures? I have lighting symbols that use specific textures as gobos. Is there a way to change the gobo by changing the class? I'd prefer not to have to duplicate instruments (as that screws up LW) Similarly, is there a way to change the projector/ TV image using classes?
  22. Does anyone know of a listing of the spotlight preferences? I'm trying to make a basic script, e.g: Setpref(11,true); to turn on layer colors I want to be able to turn on and off the 'modify the lighting device color' but I don't know what preference # it is, and can't find a listing in the VS guide. Anyone know?
  23. Does anyone know of a listing of the spotlight preferences? I'm trying to make a basic script, e.g: Setpref(11,true); to turn on layer colors I want to be able to turn on and off the 'modify the lighting device color' but I don't know what preference # it is, and can't find a listing in the VS guide. Anyone know?
  24. I've noticed when I have a rotated plan and use the align tool, objects are aligned not in the orientation of the screen, but in reference to the unrotated drawing. Anyone know how to rotate the drawing to 45deg and align objects as they appear on the screen?
  25. Yep, same problem. It behaves if I quit and restart, but eventually misbehaves. Tech is aware of the problem, but no idea when they will fix it.
