neilmaggs
13 -
Reputation
0 Neutral-
hi katie i am missing the sktech style in the sketch menu and i don't know how to get them back or find them in the resources browser. Also i have made a 3d model and need to find a way to move the ground plane to be coincedent with the ground level of my model so that i can see the 3d when i go to perspective view. - how do you do that? ta
Hi All, I got Vectorworks architect on my work version of 11.5 and so have the sketch function there on my home comp i only have fundamentals/renderworks on 12.5. no worries will add on.
um....what are the design series products then? I have the sketch function on my copy of VW11.5....
yes i have fundamentals.
Hello, I can't seem to access my sketch styles (careful, certain etc etc) in VW 12.5 and VW 11.5. I can access them on my work PC but not my home PC. Any clues? Do they need to be 'loaded' from somewhere? They are not coming up in my menu. Ta Neil
hello, problem solved. bought a different mouse and VW works fine not sure what problem was with logitech mouse. thanks n
"The mouse speed stays slow while you are drafting in VW?" yes. mouse also slow down when VW starts up before i can start drafting. "Earlier you said you had no other programs running. I am now reading that you minimize the window and go to another program all is well." sorry that was unclear. when i minimise screen and go to desktop mouse is normal speed. if i close VW and open another program such as photoshop mouse is normal speed. "What other program(s) are you running?" none when VW open. "It definitely sounds like a mouse driver conflict of some sorts. Did you recently update all the drivers at once, or a few at a time?" updated mouse driver only. reinstalled quicktime _________________________
"So you only see this lag during the launch of VW, and only on one of two tested desktops with the same mouse and mouse drivers. You've also tested using the same mouse on the laptop and do not have the problem." yes "Is this correct? I'm sorry, the information has been a little hard to follow for me." sorry will try be clearer "Once the launch of VW completes, the mouse speed resumes to normal speeds, correct?" no - the mouse is slow but only within the VW CAD environment, when I minimise the VW window and go to another program, the mouse is normal speed" "When you notice the lag, are you just moving the mouse around on the screen or are you trying to flip to another window, or open another program? " the mouse is slow on the VW start up screen and once the drawing environment is open, if I minimise the window the mouse returns to its normal speed.
Logitech Click! Optical Mouse Although now installed software on a third computer and mouse works fine on that one. it seems just to affect my home PC.
Laptop has a trackpad but works equally well when USB mouse from desktop is plugged in. Logitech Click! mouse. But have been using trackpad. No other programs running except firewall/antivirus software. both computers have 1 GB Ram. its a bit strange that vw 11.5 used to work fine on desktop until installation of vw 12.
Let me restate problem: VW 11.5 works fine in desktop and laptop computer. I install VW 12 in laptop. Mouse moves slowly in desktop for both 11.5 and 12. Then install VW 12 on laptop, both versions works fine on laptop. No other programs are affected on desktop. Mouse starts slowing down in CAD environment from moment i start up VW, but works fine outside of VW CAD environment.
no. i have noticed that the mouse slows down while VW starts up. program works fine on laptop so i am sure the installation of VW12 has changed a setting somewhere.
hi i have wv11.5 on my desktop pc. i upgraded to vw and when i did this i get a problem that the mouse slows down a lot when it is over the CAD environment (when in VW - its fine outside of VW). i installed vw12 on my laptop to see if the problem occurs but it didnt. but vw11.5 and vw12 run fine on my laptop but now both versions run slow on my desktop. i have updated quicktime, my mouse drivers and my graphics card software but the problem is still there on my desktop computer. i have tried uninstalling and re-installing the software but that doesn't help. any clues?
