Vince Oles
32 -
Reputation
0 NeutralPersonal Information
Occupation
Architect
Location
Salt Lake City, Utah
Thanks all for the advice. I transitioned software and hardware at the beginning of the year and did not set back-up files properly (Rookie error). These were invaluable tips for me and hopefully others. As an added note....when I imported the pdf survey and scaled it, it affected my other design layers as well as all sheet sizes. It was a mess! I had fortunately sent out dwg files for most of the drawings earlier to consultants and was able to resurrect the project fairly quickly. Finally, the floor plan design layer showed a portion of the plan at the correct scale and the other at a larger scale....that's when I knew i was in serious trouble!
Thank you! Will give this a go and see if I can get back to normal!
I imported a site survey drawing into an existing project file. In doing so, I scaled the pdf only to realize... too late, that it affected all my design layers and sheets! I then went to a back up file and corrupted this one as well. I have looked in Time machine for a back up file to no success. Apparently, my VW files are not being saved there. Any help in trying to save me from having to start from scratch will be greatly appreciated!
I'm using VW 2019 SP6 and recently updated to Catalina OS. I was working on a residential project Detail Sheet and one of the Detail Viewports had the red update box around it (None of the other 15 Detail viewports showed this update box). In addition, the particular viewport linework was fuzzy, thick and pretty useless. All of these detail viewports were selected from building sections on a design layer. I tried adjusting some of the attributes when Poof, computer crash. I restarted and opened the file, there was Nothing! in the Design Layers or Sheet Files. This was about a 65MB file and about 95% through Construction Docs. Fortunately, I recovered a back up file. My question is, what would have caused the entire file to be deleted. I've had many VW crashes over the past yeas but never lost the entire project. Thank you in advance for any insight! Vince
Font selected is Arial. Same issue with other fonts. Also, if I save as pdf, fonts will reappear. I sent file to tech support.
The dimension class is visible in the viewport OI box. Dimensioning directly on the sheet layer has the same issue...no dimension showing in the vertical direction. The Text rotation box is set to the default "Aligned". If I switch to "horizontal" the text will appear but it's a bit awkward looking for a string of vertical dimensions.
I'm dimensioning a floor plan viewport in Annotation mode and the horizontal dimensions display ok but vertical dimensions show only leader lines and blank box where dimension should display. I checked settings in Class Organization...seems to be ok. Thanks in advance for any suggestions!
Thanks to taoist + Peter...worked out great ( the video was helpful in showing you need to select the path + object before the extrude along path button comes to life) and taught me a new tool to play with!
I have a cornice (3-d polygon profile) that I want to extrude onto different wall planes in a model. Push-pull only allows taking the profile to the corner. Extrude tool is non functional for this operation. Thanks in advance for any suggestions.
Thanks Benson and Kevin! Not sure what "fixed" the selection issue but is now working. BTW I was able to select and highlight the object but it did not show in the OIP.I didn't get the icon Kevin mentioned. I checked layers, classes and different project files and kept getting the same negative results. Perhaps the restart helped? I'll verify the Rectangular Selection Mode should this occur again. Thanks!
I just upgraded to SP3 and noticed that clicking on an object does not show in the OIP. I restarted and was able to get objects to show for a short time and then nothing. Any one else having this issue? Vince Oles iMac 5.1 Intel Core 2 Duo 2 GB memory Mac OSX Snow Leopard VW 2011 Designer SP3
I'm not able to change wall fill colors in a viewport. I've changed the Class Attributes in the OIP for the Viewport to the color I want. This changes the icon, indicating that the class definition has been changed to the selected viewport. Hitting OK gets me to the Viewport Class Properties box. I have tried the Import and Embedded Design Layer Viewport settings with no success. Thanks for any suggestions! Vince Oles iMac 5.1,OS-X 10.6.6 VW Architect 2011
Called Tech support. They sent me the following link to fix: http://kbase.vectorworks.net System: Mac OS X 10.6.4, VW2010 Designer/Renderworks SP4 R2 (Build 126481).
When I try to set up a model I get the following error message, "There was a problem with the LayerNameStds worksheet. This procedure cannot run without it". I've checked VW Preferences but to no avail. Thanks for any suggestions. Vince
I found it. There's a small arrow on the bottom of the Classes Attributes dialogue box. Clicking on this brings up a menu of 4 items. Selecting the "Make All Attributes Class" turned the arrowheads off.
