lesterk
  • Content Count
    7
Community Reputation
0 Neutral
About lesterk
  • Rank
    Greenhorn
  1. never mind i found the script here: http://techboard.nemetschek.net/ubbthreads/ubbthreads.php?ubb=showflat&Number=133627
  2. can you please explain how you did that? I can only make a shortcut to the preferences, but not a 'zoom line thickness' toggle alone.
  3. thank you! i was putting in 'IDClass' as a guess Is there a list of all the parameters for door/window to be used in a worksheet?
  4. Please don't tell me I have to select EACH AND EVERY DOOR OR WINDOW, one at a time, in order to get the ID class to be on door-spec or window-spec??? It cannot be done in the Obj Info palette (Why is it missing from there??) and selecting more than 1 door or window and changing it under settings -> ID class will only change it for the last door or window selected. If I could figure out a way to get the ID class listed in a door or window schedule, I could change it from there, but so far, no luck.... using VW2008 SP3 w/ architect on Mac any suggestions?
  5. i resaved the dwg file in 2000 format instead of 2004 format and it imported fine. still, this needs to be fixed ASAP
  6. no, neither app was renamed
  7. I have this problem when importing a DWG file in 2008 service pack 3. I cannot do it into 12.5 either! can someone please resolve this once and for all??? I am on a mac using tiger
