1,890 -
Posts posted by Tamsin Slatter
Hi Lee
As you're based in the UK, I recommend you get this file over to the UK tech support team via the support form in the Service Select portal. They will take a look and get the file to our engineering team if necessary.
Emily, this is a manual process for us, so is handled during office hours by your local distributor.
Hi Lisa
Could you please send me the files, and I'll have a look for you?
I recommend that you keep Site Modifiers on a separate layer, if not more than one separate layer. That means that you can easily control and select them, but also experiment with different design options. Within the Site Model Settings dialogue, if you set the Use Site Modifiers on option to Visible layers only (or there is also an option to choose specific layers that are able to update the model), you will find that you can apply different sets of modifiers to the site. It's also a great option for trouble-shooting.
It's so cool Mark! Thanks for sharing. And I'm really pleased that your 3D printer is not printing plastic too.
- 1
It looks like the Drawing Label that is automatically created when you create a viewport (unless you uncheck the box on the Create Viewport dialogue).
To edit it, double-click on the geometry in the viewport and choose to edit Annotations. THis is where you should add dimensions and other relevant notes, but also where you'll find the Drawing Label.
- 1
Think of the design layer as a physical horizontal plane running through your building. If you're working in 3D, you can attribute height to this plane.
The design layer of an object determines WHERE it is, whereas the class determines WHAT it is, and optionally, what it looks like.
- 2
Hi Bruce
Classes are not actually associated with layers. They are completely independent elements. So, an object sits on a layer but is also a member of a class. But there is no relationship between a class and a layer.
So, you might want to put the floor and ceiling on separate layers, for physical separation from everything else, but keep the walls and cabinetry all on the same layer. But put your walls in one class and cabinets in another (you could also break down the different elements of the cabinets into classes, depending on how detailed you need them to be (handles, doors, tops, sides, etc.)
So, in summary, I would use fewer layers and more classes, and then saved views to control what's visible at any time.
Put the plants for that area on their own design layer.
Edit the worksheet, and edit the criteria (right-click on the row header with the diamond symbol).
Click more choices to add another selection criteria that filters the report to Layer = <Layer on which the plants are sitting>.
Alternatively,
On the design layer, draw a polyline around the plants in question (make sure it is large enough to include any tags that are displayed as part of the plants).
On the Object Info palette, at the bottom, there is a Name field. Give your polyline a friendly name.
Edit the worksheet criteria (as described above) and add a filter for Location IS WITHIN <Friendly Polyline Name>
- 4
Hi Bruce, no, an object can only reside on one layer and be a member of one class.
Just now, neal-2002 said:
No, I’m done with 2020....I’m back to using 2019 and ain’t moving till spring....doubt I’ll bother with next years VSS either..
Fair enough, but we would be happy to look into this for you and may be able to resolve some issues.
On 10/30/2019 at 5:36 PM, neal-2002 said:
ive had the same issue with missing parts in open gl rendered elevations!!
and viewports moving together too!!
VW sort it out - ive just paid 3K for this mess!!
Neil, did you ever send us the files so that we can investigate this?
You need the Quantity column, not the Count column.
1 hour ago, Michelvh said:
Tamsin -- Thanks for keeping an eye on us out here. I already have an open case but if you'd like to review my case history make sure you have plenty of time on your hands.
You're welcome. I am in the UK, and I'm afraid your case history will be with our US tech support team. Have you reported this latest issue to them?
- 1
Login to the student portal, using the account you set up last year and then request the extension from there (if you can't remember your password, there is an option to reset it on the login page). You'll need to include an image of your student card that shows your are still studying. Then, we'll review and extend as appropriate.
student.myvectorworks.net
Thanks for clarifying these points Vlado.
I don't have an exact date for you... but I *think* it will be this month... But don't shoot me if I'm wrong!
- 1
Hi
It looks like you are selecting the 3D from the 2D elevation library - the images are the same, but behave differently. Instead, you need to use the images from the 3D Image Props libraries.
Good luck!
Manually align the top two tags to have the distance that you want. Then select all the plants, run the command again, and it will use the distance between the top two as the uniform distance between them all.
- 3
Thanks for sharing Neal. You just beat me to it.
Glad you have a workaround with a combination of the OpenGL render. You can remove the colours from the OpenGL render and increase the quality too, so might be worth experimenting with that too.
I'm afraid Spotlight does not support the import of Shapefiles.
Thanks Neal. The team has your file and is doing some testing. I have a feeling this may be something to do with the way the Maxon engine handles the artistic edges, but we will come back and confirm for you.
If you remove the sketchy edges from the Renderworks style, you will get a 360 panorama without the issues you are seeing.
QuicktimeVR functionality was discontinued by Apple in Quicktime v 7 and that is why it is no longer available in the Vectorworks software.
- 1
Thanks @Pat Stanford for taking this up on the night shift!
It depends on the settings within that style - each option within a style is set to By Instance or By Style. You could edit the style, choose the options you want, and then set them to By Style. Then apply the style. The settings are fixed by the style and not changeable. Leave things you want to be able to change on each Sheet to By Instance.
- 1
Renderworks Camera Projection
in General Discussion
Posted
Lisa
Let me show you Cameramatch one day soon...
