Content Count
1,737 -
Calendar
Everything posted by Tamsin Slatter
And... the other advantage of using 3D polys as modifiers, particularly for curves, is that you can run Simplify 3D polys on them, to reduce the vertex count and avoid creating an unnecessarily complex site model which takes forever to calculate.
Actually, there is no such thing as a contour site modifier. Under that name, it's really just an open Pad. So a 3D Poly does just as well and yes, the class trick us pure magic. Remember this when creating complex modifiers. The advantage of a 3D poly is that it each vertex can have a unique Z value, unlike a Pad.
To add to Bryan's excellent input... if you already have 3D polys that represent your proposed contours, you do not need to convert them. Simply add them to the Site-DTM-Modifier class and they will become modifiers. And yes, always use a Grade Limit.
It looks like you have Unified View turned off. Trying the View > Unified view menu item to turn it on. This will mean that when you change the view, all layers will change to the same view. As you are self-educating, have you discovered the learning materials available to you in Vectorworks University? You can create a free account, and run through tutorials that will take you from the basics right through to more advanced topics.
Thanks for helping out here Lisa.
I think I gave you some resources on this when we visited... if you can't find them, let me know and I'll get them to you.
I would recommend that all referenced files are using the same user coordinate system. So, for each file in the project, after importing, draw a circle with a radius large enough to cover the entire set of geometry. If possible, this circle should be centred on exactly the same place in the project. Then, run Tools > Origin > Center Drawing on Internal Origin. This will ensure that the same point in the project is positioned over the internal origin, across the set of files. Then, run Tools > Origin > User Origin. Choose Next Mouse Click is and type in the true X and Y coordinates for that point on the site. Click OK and click on the internal origin. This will overlay the world coordinates on the internal coordinates and will ensure that everything aligns when referencing. (Of course, you can delete the circles - they are just a convenient way of ensuring the the center operation is centering the same point in the project).
Yes, it's definitely available in Landmark, and is definitely in the Visualisation tool set. Could it be that you've migrated an older template forwards which won't have the new tools on it?
- 4 replies
- shadow diagrams
- sun paths
(and 1 more)
Tagged with:
Classes for Annotations on sheet viewport?
Tamsin Slatter replied to ArchiPam's topic in General Discussion
No such thing as a stupid question!- 6 replies
- annotations
- design layer viewport
(and 2 more)
Tagged with:
Michal, please send the project in to the UK tech support team, and we'll take a look for you.
When you put annotations in the viewport (or even directly on the sheet layer), they can be classed, just as objects on the design layer can. Just right-click on the viewport and choose Annotations. Then add dimensions and notes as if you were on the design layer. These annotations will be part of the viewport but can be classed as you wish.- 6 replies
- 1
- annotations
(and 2 more)
Tagged with:
Eric, the plants are placed using whichever preferences are currently set in the Plant Tool Preferences. Click the Plant tool, and then click Plant Tool Preferences. Here you can choose if you want to insert plants according to their style definition or according to an override value. Once these preferences are set, insert the plants. To avoid any problems in the future, set the preferences as you wish, and then save a template. Tool preferences are saved with the file, so this will mean all projects are set to your favourite way of working before you start. This can include tag preferences too (although I would advocate the use of Data Tags now for plant tags (and any other tags) as they are so flexible and the future.
Wall End Caps in Landmark
Tamsin Slatter replied to ScottLebsack's question in Wishlist - Feature and Content Requests
The Wall Cap tool is available in Vectorworks Landmark. Here's a link to the description in Vectorworks Help. The D beside the title denotes this as a Design Series tool, which means it is available in Architect, Landmark, Spotlight and Designer. http://app-help.vectorworks.net/2020/eng/index.htm#t=VW2020_Guide%2FWalls%2FCreating_wall_end_caps.htm&rhsearch=wall end cap&rhsyns= -
Hi Ellary This is a known problem I'm afraid, but the good news is that it has been resolved ready for the next service pack.
Georeferenced objects shifting between layers
Tamsin Slatter replied to lisagravy's topic in Site Design
With 2012 the georeferencing was more limited. With any geometry that spans more than a 5KM radius, you will find that any CAD system struggles with floating point maths. For this reason, we recommend that you keep the geometry close to the internal origin and set the user coordinates to match the real world coordinates of the site. With 2012 this is not a straightforward process. Later versions of Vectorworks include options in the Tools > Origin > User Origin command to set the precise coordinates of the site over the internal origin. There is also a command under the Tools > Origin menu to Center the Drawing on the Internal Origin (while preserving the real world coordinates). This would help you enormously, but with 7KM that will potentially cause problems. -
Object Properties not Updating after Selection
Tamsin Slatter replied to Michal Zarzecki's question in Troubleshooting
Michal THese problems make me think there is an issue with the configuration of the graphics card. I know we looked at this briefly when I visited. Look at the controller software for the graphics card and ensure it is set to allow Vectorworks to use the card. -
The only thing I can suggest, off the cuff, is to use Layer Import Referencing and bring in the layer from the other file, then delete the reference, choosing the option to import. BUT, I haven't tested this and I am just running to a meeting... will test later. -
VB-168438 (internal reference). -
Actually, I was a little hasty in that pronouncement. It seems that this IS an issue, and I will file a bug report immediately. I don't know that we can get this resolved in SP3 at this stage, but the good news is, there is workaround: Here's the workflow I would suggest: Edit Vectorworks Preferences, and on the first tab, uncheck Offset Duplicates. Create the copies using CMD+D/CTRL+D (shortcut for Edit > Duplicate) The duplicates remain selected. Change their design layer on the Object Info palette. I hope that helps. -
This is resolved in Service Pack 3, which is imminent... -
I'm looking into this Lisa (and have been since you posted... I just forgot the crucial bit of letting you know...). -
point clout not importing into coordinated space
Tamsin Slatter replied to axhake's question in Troubleshooting
If you still have access to 2019, it does import in the correct place there. From that point, you can centre the geometry on the internal origin and you'll be good to go. -
This is an issue I have reported to our engineering team - VB-167146. -
Here's my high level overview. Open blank document. Edit document georeferencing settings and choose the appropriate geographic coordinate system. If you are in the UK, the standard UK templates are automatically set to 27700 which is the geographic coordinate system equivalent to the OS British National Grid. On this dialogue, the coordinates at the top relate to the position of the file's INTERNAL origin, within that coordinate system. In a UK file, we set this to the Greenwich Meridian as a default. This can be changed. Import the DWG file, but use the checkbox This file contains georeferenced geometry. Click the Advanced button and take a look at the GIS tab - this will confirm that the DWG will be brought into the georeferencing settings set at the document level. Click OK and again to complete the import. The geometry will land in the correct place within the GIS system (as long as it was actually created in the correct place in the first place.) Use the Geoimage tool and draw a rectangle around the site. This will load the imagery associated with the site. Use the Geolocate tool and click on a location on the site to move the internal origin close to the geometry. From this point on, X and Y are no longer relevant, and you should use Easting and Northing instead. The GIS Stake tool can be used to report these. If you want the numbers on the User Coordinate system to match, use Tools > Origin > User Origin. Choose the option to Set the user origin to match the origin of the geographic coordinate system. Why might it not work? Your DWG is not created in the same coordinate system as the GIS coordinate system.
