Jack Helgeson
11 -
Reputation
0 NeutralPersonal Information
Occupation
Project Manager
Location
San Diego, Ca
Recent Profile Visitors
San Diego User Group
Jack Helgeson commented on administrator's calendar event in Community Calendar
We are all on new mac Pro computers. 48GB memory installed with AMD Radeon Pro 580X 8GB graphics cards. Jack
Everyone in office has this gray screen issue, is there any resolution for this?
Very cool! To bad we are still on 12.5.3. I was looking for the Visibility tool on the new version to import to see if it will work put I can't find the plug-in at all in the plug-in folder called Visibility. We have one copy of the new version so it doesn't do me any good since I'm on and older mac. Thank you Kevin
Why Doesn't Vector Works have a option to right click on a object/line/symbol and have the dialog box appear to have the class that the item that you clicked to turn off that class. The only way to turn off class is by the navigation box or the upper Class and Layer drop down menu boxes. This would solve the having to click the object to see what class it?s on and then go and find the class to deselect it from the drop down menu or Navigation box. Anyone have a plug-in tool for this or Vector Script? Blackjack
Katie I sent a DWG file that I exported with the missing items and a PDF file of what it should look like. I will also send the orginal file I just need to condense it first. Waylon
Anyone experaiance issues with exporting Sheet layers and it's missing a bunch of information? This only happens here and there but once it does it I can't get it to export all information unless I export from Model space. This have happend on one computer and then switch computer and there was no issue. I have tried opening the file from mutiple compters other times and they all will not export the information.
Anyone have issues with their viewport crop disapearing completly? I have a saved view to turn on all classes and layers so I know it's a Vector works glich. It only happens every once in a while. You end up having make a new Viewport. FYI everything I put in a sheet layer is on class none to solve miss placing items for sheet layers. Waylon
A question for those with corruption issues
Jack Helgeson replied to Christiaan's topic in General Discussion
We just started to experiance this issue. So when we open a file off the server and it says it's corrupt we save it to the desk top. Then while the first file you opened that says it's corrupt you have to save it again but as a copy to the local desktop and the file will be good. Just remember the first one that gets save will not be good untill you go under file on the menu bar and tell is to save as a copy. How this helps. Waylon
until
