Stacy
    26
Everything posted by Stacy
  1. I'm still working on VectorWorks 11 and am going to buy a new PC. I was wondering if i should maintain working with Windows XP or upgrade to Vista. Could anybody tell me if Vectorworks 11 will run on Vista and if it does will it be better than running it on Window XP? Thanx
  2. Stacy
    Animations
    Ok thanx for the tip. Will just make sure once i'm finished everything i'll start with the animations.
  3. Stacy
    Animations
    I have created an animation to show clients the general idea of the model of the house and i was wondering if there is anyway to update the video once i've saved it and done changes to the house or is it easier to create a new animation? I'm working on VectorWorks 11.
  4. Stacy
    Hatch
    I'm working on VectorWorks 11. Is that function only on VectorWorks 12 or will 11 have it as well.
  5. Stacy
    Hatch
    Is there a way you could convert lines to a hatch instead of creating it in the edit hatch function?
  6. Stacy
    Hatch
    How do you set a hatch Origin?
  7. Stacy
    Tables
    A table as in a spreadsheet. Thanx
  8. Stacy
    Tables
    I was wondering if VectorWorks offers the function of ready made tables, like inserting a door all you need to do is edit the number of rows and columns.
  9. Stacy
    Roof
    The roof that I'm trying to compute is simple. It allows me to create the roof but it doesn't allow me to edit certain areas of the roof.
  10. Stacy
    Roof
    I keep getting an error message Could not compute roof, house drawing too complex to compute roof. All I'm trying to do on the roof is change part of the roof to a gable end with a 100mm overhang. I can have one or the other it won't allow both options.
  11. Stacy
    Memory
    No, I'm no longer having problems with the viewports. Thank you for all the help.
  12. Stacy
    Memory
    Yes I am on PC, sorry I should have specified that. The error message says, One or more viewports could not be rendered. One or more operations was aborted due to lack of memory.
  13. Stacy
    Memory
    The file that I'm working on is 4.5MB. I'm working on a Pentium 4, 2.8GHz, 1GB RAM, with FX 5200. The viewport DPI was set on 750 with the 3D resolution on low.
  14. Stacy
    Memory
    By selecting "wire frame" and then re-selecting Open GL doesn't clear the buffer I have to restart my computer. I have changed the settings to medium and will see if that helps. Thank you
  15. Stacy
    Memory
    I'm having problems updating viewports. When updating viewports rendered with Open GL, after the viewports have been rendered once or twice before they will no longer render due to what i'm told by VW is "lack of memory" but I can still update a viewport rendered with hidden line on the same drawing after VW has told me the viewport rendered with Open GL can't be updated. This becomes vey frustrating please any suggestions will be highly appreciated.
  16. Stacy
    Layer link
    Is there any possible way you could un-link a layer link?
  17. Stacy
    Import
    How do you import a word document into a drawing? Thanx
  18. Stacy
    Rendering
    Why when rendering with hidden line, lines will appear where they are not supposed to be. Like a line will come up showing the height of an interior wall?
  19. Stacy
    Viewports
    Thanx, I restarted the computer and it hasn't given me trouble since.
  20. Stacy
    Viewports
    I checked the drawing and none of the classes were switched off. What else could cause the viewports to delete themselves?
  21. Stacy
    Viewports
    I was setting up a sheet layer and organising the viewports and while doing this one of the viewports deleted itself. It continued to randomly pick a viewport and delete it.
  22. When rendering an image with unshaded polygon option in a viewport some of the wall lines and roof lines from the opposite side of the view show through. Like showing a view of the front of the house walls from the back view of the house will show through.Why is this? Do you need to have Renderworks for the drawings to render properly?
  23. If you have an exsisting drawing how do you import a Template file or even just a sheet layer into the drawing?
  24. Stacy
    Scales
    Yes some of the viewport scales were changed in the Object Info Palette.
