bob cleaver
Content Count
141 -
Posts posted by bob cleaver
I am trying to add a worksheet with hatches in the images column so I can ad a description of it in the following cells.
I placed the worksheet on the design layer and I am using hardscapes with hatches as the fill.
The worksheet does not scale the hatch correctly and seems to show it at 1:1 scale in the worksheet cell instead of showing it at the layer scale.
Any help is appreciated
We use the category fill in on the plant definition to label, tree, shrub, etc and then sort the database for separation of plant types
We use plant definition Comment 1, 2, 3 for CA Native, Evergreen, WELO rating and add them to the plant list columns
We would love to read other workflows
All the best with the new machine
Please keep us posted on your findings
Nikolay- we were able to get the issue order per the letters in ascending order
Thank you
Thank you Nikolay
i will check the fix
bob c
I would guess the issue for 0 plants is right click the line in the worksheet and select 'show item'.
The drawing should select the item, highlight it, and the Object Info will tell you if the area is too small for plants.
While drafting or editing plant areas, small remnants are created.
You may have to use the 'select item' multiple times until all the small areas are removed from the drawing.
Someone may have a workflow that simplifies this
Nikolay-
I sent an email to premium tech support with a dropbox link to the file
Thank you
Alan, your work is incredible, thank you for sending the file
I am using Landmark and the title block is not showing issue data in chronological order and there is no clear editing process
Thank you
check the plant massing box in the object info palette
check the classes are on
good luck
So Jim W, VW Guru replied (below) that increase of VRAM is key to faster rendering
Regular RAM is important but maxes out at 32GB
Zoomer has the correct review of
It appears you can add an 8GB Vegas graphic card as an external component at $800 US, but I have not seen a 16GB card as mentioned below except as an upgrade to the new iMac Pro but the cost of $5,600 US-
BTW the base iMac Pro has a 8GB Vegas graphic card at $5,000 US
Good Luck
The following thread was from Mac Recommendations thread in the General Discussion area:
Jim W replies that's the way i'd go
So if given a choice between 64GB of RAM and an 8GB graphics card, or 32GB of RAM and a 16GB graphics card, sounds like the 16GB graphics card might be the way to go
That's the way I'd go!
Thank you, CipesDesign, I appreciate the quick response
I am able to add a hatch or tile to a hardscape, but the hatch or tile does not appear when viewing a 3D view.
I then added a polygon with the hatch or tile on top of the hardscape and it appears when in 3D views, shadows on these polygons show inconsistently.
Happy Holidays to All
I am hoping to add joint patterns to hardscape in 3D views.
Hatches do not work and I am not happy with the results converting hatches to textures.
What is the best way to add joint patterns to 3D ?
I have searched the forum without luck- there is probably a tutorial but I cannot find it-
Thank you
You can review the class attributes of the plant symbols and adjust them as needed- use the graphics of the plants as a study and improve them as desired. Think of them as inspiration and make them better.......
You can add graphics to these plant symbols and tie the new graphics to classes so you can adjust the planting when in schematic, design development or permit/construction drawings- also consider the 3D graphics of each plant symbol.
michaelk
The issue fixed itself ??
It is not recurring
thank you for your interest
BC
I am using drawing labels in symbols, imported from a VW2017 file. When publishing sheet layers that have viewports of the symbols, the drawing labels are resizing to an unreadable size. After several resizing the drawing labels in the symbols and getting the same results, I fixed the issue BUT I had to ungroup the drawing label in the symbol. I would like to have the drawing labels remain in the symbols.
AM I using drawing labels incorrectly ? Publishing incorrectly ?
I am using a worksheet from an upgraded 2017 file to 2018 version, and when I ask for edit criteria of a database line, VW crashes
A worksheet in 2017 that functions in version 2017, crashes Vectorworks when I convert it to 2018 and then try to edit criteria of a database in version 2018
thank you for the info
workgroup folder linked !!
BC
We are using VW 2018
The resource browser shows a Workgroup folder but does not show the contents of the folder we have linked using vectorwork preferences.
The link is to a dropbox folder that the office uses.
Bob C
It would be great to have a loop main feature for irrigation systems.
We use loop mains all the time and appreciate VW considering the adjustment to the main line.
There is a pressure savings when a loop main which provides better water distribution.
thank you
1
Benson-
Thank you for the vimeo tutorial for adjusting the bridging issue.
Fantastic use of VW tools to fix the bridging.
Once you get accustomed to the keyboard shortcuts for the 3dLoci, objects along path and 3d polygon, it should go quick
hatches in worksheets
in Troubleshooting
Posted
Thank you Eric
We had scaled the hatches using local mapping and this was part of the problem
So...
We scaled the hatches in the hatch edit dialog box and used world units and all is well-
