BJD ARCH
    5
    Never
Reputation
0 Neutral
Personal Information
  • Occupation
    Architect Developer Teacher
  • Hobbies
    Architecture Real Estate Macs
  • Location
    Brooklyn, NY USA
  1. Archken has posted a number of messages that contain graphics! how is this done????? ------------------ Bernard J. Doyle RA
  2. I used to run MiniCad for days at a time and not need to restart. Now I find that if I leave VW running overnight I get memory errors the followig day. So if there is a memory "leak" why can't it be plugged or failing that how about a ram purge feature? ------------------ Bernard J. Doyle RA
  3. I have to agree most strongly that the current wall join is very week in complex situations. NNA has apparantly Given up on the Y Join tool as it isn't even in the Workspace editor as far as I can see. I understand that the column command was created to alleviate this problem however while it works well for columns and Pipe chases or even intersecting different thickness walls it is too cumbersome for more typical join situations (Y or otherwise), since it is not easily reshapeable without editing group. I also would like to know why sections of wall disappear when joined to columns if they are touching the column. Surely this is not a "feature". ------------------ Bernard J. Doyle RA
  4. I have to agree most strongly that the current wall join is very week in complex situations. NNA has apparantly Given up on the Y Join tool as it isn't even in the Workspace editor as far as I can see. I understand that the column command was created to alleviate this problem however while it works well for columns and Pipe chases or even intersecting different thickness walls it is too cumbersome for more typical join situations (Y or otherwise), since it is not easily reshapeable without editing group. I also would like to know why sections of wall disappear when joined to columns if they are touching the column. Surely this is not a "feature". ------------------ Bernard J. Doyle RA
  5. I have to agree most strongly that the current wall join is very week in complex situations. NNA has apparantly Given up on the Y Join tool as it isn't even in the Workspace editor as far as I can see. I understand that the column command was created to alleviate this problem however while it works well for columns and Pipe chases or even intersecting different thickness walls it is too cumbersome for more typical join situations (Y or otherwise), since it is not easily reshapeable without editing group. I also would like to know why sections of wall disappear when joined to columns if they are touching the column. Surely this is not a "feature". ------------------ Bernard J. Doyle RA
