Ride
353 -
Posts posted by Ride
Ok, following up on this thread. The data tag works perfectly. But here's a question - now that the bubble are separate lines, the tag has no fill. So if I use this over a woodgrain hatch, things start to look a bit messy. Any way to get a fill for the bubble?
Oops, I need to update my signature, will do it now. I'm on 2022 Architect with InteriorCAD. I can never get the per face texturing to work. Not sure what I'm doing wrong...
Can someone please explain how to apply a texture to a face of an object? For the life of me, I cannot get the grain directions in wood textures to represent what I actually want. In some cases, changing the rotation of the texture does absolutely nothing on one object, but works on another. It doesn't make any sense to me. Below is a screenshot of a bunkbed that I'm trying to model, but I need to get the grain directions right so I can provide this with my shop drawings.
Any help appreciated.
Yep. That did it! Thank you. I too spent a bunch of time looking, but couldn't figure out why mine didn't work. So in the end, something simple. But not so simple.🤦♂️
Happy New Year!
- 2
It is. Here is a file with the data tag. If you have a chance maybe you can take a look? I'm sure I'm missing something simple.
Well I'm very grateful to have gotten this far. And TBH, it's unlikely I would ever have a finish tag that long. But it never hurts to ask!
Appreciate the help. This will be a big time saver for me.
Wait! I got it. Helps if you actually read the instructions. Apply the constraints to the text, not the bubble. Which is great. But last question (I think). When you input a long text note, the bubble ends get elongated. Is there a way to constrain those but adjust the middle portion of the bubble? See attached:
I work in architectural millwork, doing shop drawings, and I'm trying to create a data tag for our finish notes. I have attached an image of a typical finish note/bubble we use. I can create a data tag easily enough, but I don't know how to make the bubble automatically adjust around the text. What I have works fine *most* of the time, but say I have a longer note (such as WDV-01) that some designers use, it runs outside the bubble. Is there a way to make the bubble adjust to text? Or is there a better tool for this?
Any help appreciated! Hope everyone has a good holiday season...
1 hour ago, AlanW said:
@RideHi, I draw a 3d Polygon then extrude along path. Make sure you move the object not the line as it extrudes down centre of object, by positioning the object edge to the line it will be easier.
Not sure why the left piece sits out different.
HTH
Yes, that works well too. Thanks. Though I do have trouble selecting either the NURBS curve, or the 3D poly after I draw it. Not sure why. My problem originally is I was trying to use 2D tools for this, which work fine as long as you're working on the actual working plane. As soon as you veer off things don't work, obviously. I need to spend more time getting to know the 3D toolset.
2 hours ago, Tom W. said:
Can you not just use the NURBS Curve Tool + draw the path as a single object in 3D?
When I use the NURBS curve, all the vertices are curved. It won't let me put a value less than 3 in for the radius. What am I doing wrong? There must be a way to draw this in one go, in 3D.
Hi. I'm trying to draw a small trim around some cabinets, and a bench seat. The trim is a simple 1" square profile, and I would like it to follow the red line shown on the attached screen shot. I feel like I've done this before, but I can't seem to get it to work now. What layer/working plane do I need to allow me to draw the path of the trim, and then extrude along path? I've tried setting the working plane to the face of the doors, but as soon as I try to draw the path back to the recess of the bench seat, things fall apart.
Do I need to draw each section individually, and them combine, convert to Nubrs?
Well maybe I spoke too soon. It works on the design layer, but my in my viewport the lines are back. Will work on this some more.
11 hours ago, Tom W. said:
Yes both wall styles have components but I just realised the offending one didn't have 'Core' checked! When it's given a core it joins properly without a line.
Yes! This worked for me too. Thank you all. So helpful.
9 hours ago, Tom W. said:
Does using Component Join in T Join Mode get rid of the line?
Ah ha! Yes it does. I have never seen that type of 'join' before. I only tried it on one instance, but it worked. I use simple walls with only one component as I don't need to show wall construction (this is for millwork shop drawings). Could there be something in my wall construction that is making that line persist?
Either way, happy to have a solution for this. It was getting really annoying. Thanks for the help.
6 hours ago, P Retondo said:
This has always been a problem. Sometimes the line appears, sometimes it doesn't. I have never been able to figure it out.
Well that's unfortunate. I've been trying to figure this out for a long time, and now I know I'm not the only one. It makes my drawings look messy with all the extra lines. Is this better in 2022? I'm not using that much these days - even though I have it. It has some weird graphic issues going on with viewports. But that's for another post.
4 hours ago, jeff prince said:
"uncapped" vs "capped" Join Mode perhaps?
No, I'm using uncapped mode. Thanks for the reply.
Any updates to this? Though it wasn't a cabinet object, but a solid that I modelled. They were nightstands, so there was one on each side of the bed. One rendered properly, but not the other, this in shaded view, in a viewport. It rendered fine in the design layer. This is using VW2022, SP3.
I haven't updated my signature yet as I'm still using 2021. I have 2022, but so far I don't like it at all. Lots of hatch scaling issues in viewports, and every dimension I place takes 1-2 seconds to register before I can carry on dimensioning.
applying texture by face
in General Discussion
Posted · Edited by Ride
Also, where did you find your plywood endgrain texture? I like that one a lot better than the one I'm using...
