dontevenjoke
    159
Posts posted by dontevenjoke
  1. I am getting used to the heliodon tool and the 'set sun position' view. Is there a way to have the local sun position set to light the building so it is at local angles and can be adjusted as in the helidon tool (Heliodon tool is an Australian Add-On I think??).
    Thanks for any feedback...
  2. Newbie question - What is the most efficient way to produce reflected ceiling plans? I am thinking create a VP, turn off unwanted item and 'annotate' the ceiling details into the VP? Is there a better or standard way?
  3. I am having crashes which cause my workspace to crash, the OIP takes up the whole screen etc. The modname is vectorworks.exe and the ofset is 002c2fbb. I am using an old version of Quicktime (7.0.2) as I found the newer one was causing a different corruption. Has anyone had this problem?
    Thanks,
  4. Why does renderworks have the stack layers command. Isn't a given that if I want to see a number of layers in 3d I'd want them to be stacked? Or, is there a reason I may want to have them unstacked? Is there a VS or PIO that makes the toggle automatic, or a setting that would toggle stack layers to 'on'?
    Thanks
  5. I have set up a file and find that when switching between iso and top/plan the new view has zipped away and I need to reset origin to 'find' it again. I'm guessing the origin is set incorrectly and I am asking how to reset the 3d origin to match plan view...
    Thanks
  6. If you mean deleting VW program for a complete reinstall and you are using windows xp go to:
    Start > Control Panel > Add or Remove Programs > Vectorworks
    > Remove
    This will uninstall all VW programs.
    If this is not helpful because you are on a mac etc. list your operating system (i.e. XP, vista, mac etc) and the version of VW your using.
    Hope this helps,
  7. I'd actually forgotten the word 'ignoramus'. It's a good one. Although the plural is 'Ignoramusi'.
    LOL
    No harrrrd feelings and there,there, big fellah. And greetings from Down Under.
    I think I am the only Aussie ignoramus that PetriDish will have to ignore. (And.he.is.not.seeing.this.entry.anyway.as.he.is.visiting.his.sister.and .has.just.found.out.he.can.ignore.aussies.and.californians.)
    Anyway, PetriDish, I come in peace, and all is forgiven.
    Best Regards, Simon
