57 -
Everything posted by carch
We have an HP DesignJet 800ps. Using os X v11. Our line weights seem to be very light. i.e. black (darkest) cyan (very light). when printing we select "turn of color" from the print menu. (this seems to not matter, color or b&w). When turning on the black and white (from file menu) the print is draker but you lose the line weights. Is this a printer issue or vectorworks issue. can someone help us. Oh, yes we have ink.... [ 03-15-2005, 07:16 AM: Message edited by: carch ]
We have an HP DesignJet 800ps. Using os X v11. Our line weights seem to be very light. i.e. black (darkest) cyan (very light). when printing we select "turn of color" from the print menu. (this seems to not matter, color or b&w). When turning on the black and white (from file menu) the print is draker but you lose the line weights. Is this printer issue or vector works issue. can someone help us. Oh, yes we have ink....
Yes Resource Browser>Files&Folders>VW11file>Worksheets>Doors If i open the this file i see my door schdule. thanks for all your help. chris
how/way does this work... under the resource browser (within the file) i went to the worksheet changed door to doors.. what does this mean and how does it work? will this affect my door schdule? if so how can i fix it? thanks chris
this is an odd question. i have one VW11 file that will not let me use the door tool in the object tool bar. All the other tools work in the object tool bar. can any explain this.... thanks chris
In my resource brower my FAVORITE has turned grey. Meaning i can't access my vectorworks default resources. can anyone help. thanks chris
We are running VW 11. For some reason after we add a tag to a window or door we cannot change the size of the tag in the object info. No no matter what number you put into the scale box the tag always stays the same. Anythoughts. thanks chris
Can you take a vectorscript 9.5 or 10 and convert it to vectorscript 11? If so, how? thanks chris
help...recently i recieved a dwg file from autocad 2005. when importing into vw 10.3.xxx. my door openings dimension and scale to 36'-0" in width. they should be 3'-0". the file has been converted to auto 2000 file. what do i need to do to fix this problem. help... chris
is there anyway to open a dgn file in vectorworks 10 thanks
Thanks for your help. The problem i'm still having is this. I have created a detial in drwg A. (as recommend above / mannual). I quick vectorworks and restart the aplication select File> create blank documnet or an existing drwg. Go to my resource window and look for the detial. I can't find it. Where does the detial go? If I open drwg A (the drawing the detail was created in) then i can see it. Do I need create some kind of remove subfolder. i hope i'm not makeing harder than what it needs to be. Again thanks for your help. chris
we have a small library of details. to access our library we open past projects and do the old copy and paste. we currently are using v 10 with v 11 on the way. How can we create a library of details that sit in our resource window, which can be used for any drawing/project? Do we need to worry about scale? Thanks for the help. chris
Does anyone know how to explode a traced bitmap? Thanks Chris
Hello, i'm trying to modify my 00_Arch_Sheets file. which i can do, but it only effects Arch B sheet size. How do i get it work for all Arch sheet sizes. More about the the file: when i open the file, 00_Arch_Sheet i see two layers with two sheets Layers Catalog Page layer 1 Sheets Sel Nonplot Unzero Arch B horizontal and Arch A vertical. Is this correct? Help Thanks Chris
Anyone Recommend an A1 Printer for VW/MacOS X
carch replied to Martin Spenceley's question in Troubleshooting
martin, our small firm (3 computers) just purchased the hp 500ps. It looks great but we were falsely adviced. HP sales said it would work but the tech dudes tell us there is NO support for os X. Are you having any luck with microspots X-rip. We are thinking about sending it back. The designjet 800 is to much $$. thanks chris -
i'm having a problem with VW running sluggish as more information gets added to the file. What are my options. i'm running both mac(os 10.2 the lastes and seems to faster than my windows machine) and windows 2000. both machines are greater than 600 mhz and my ram is greater than 512mb in both. I don't know if this is a hardware issue or a software issue. help me run faster. thanks chris [ 10-25-2002, 01:22 PM: Message edited by: carch ]
can anyone help with creating pdf files with vw 9.5 and os x.1. Maybe it can't be done? thanks Chris
i'm looking to create plot files with vectorworks 9.5.0 (ox 10.1.3). Or the bigger option is to purchase a plotter. Can anyone recommend a plotter. We are small firm will all apple computers running os 10.1.3 and vectorworks 9.5.0... thanks for you time.. Chris
is it possible to create plot files with vectorworks 9.5.0... If not is there 3rd party software [ 03-07-2002: Message edited by: carch ]
this might be old hat. i hate snapping to a grid. so how do you completely turn it off. I have been to the page menu...... thanks chris
We are looking to buy a plotter for our mac system. our os is 9.0.1 and we are using vw9.0. Do we need mac plot software. What plotter is working out best. I'm also in the market for a print server. I'm trying to see what everyone is using and the most stable. your imput is much better than the write ups. Thanks Chris ------------------ jennifer bloomer|robert segrest architecture christopher c evans 630 milledge circle athens georgia 30606 Tel/fax 706.543.7561 http://www.bloomerseg rest.com c_evans@bloomerseg rest.com [This message has been edited by carch (edited 07-12-2001).]
My firm is getting ready to purchase a couple new computers, macs. Apple is preinstalling os X on all computers. Is anyone using os X and vectorworks v9.0. If so how is it preforming and more. Thanks for your help. chris ------------------ jennifer bloomer|robert segrest architecture christopher c evans 630 milledge circle athens georgia 30606 Tel/fax 706.543.7561 http://www.bloomerseg rest.com c_evans@bloomerseg rest.com
i have been doing some troubleing shooting myself and have discovered, when opening a v8.5.2 file into v9 is when i have my printing problems; arrow heads get all crazy, text is a mess along with hatching. I have recently started a couple of new projects in v9 and the printing seems to be doing fine. I'm using the epson 1520 printer with a g4 mac. does anyone know if vectorworks is ready for osX? i'm not sure if i am....... I just want to use my dual processors.....
I see we all are having some problems with V9...I also have been exporting my files back to 8.5.2 to print. Does anyone know if Nemetschek is working on these problems.
Is anyone having problems with v.9.0 and printing or just v.9.0 in general.
