Content Count
32 -
Community Reputation
13 GoodAbout Donald Ward
Rank
Greenhorn
Personal Information
Occupation
Training Manager at Vectorworks Inc.
Homepage
kbase.nemetschek.net
Location
United States
Recent Profile Visitors
1,294 profile views
Hi Alex, We would be happy to assist you. Email us training@vectorworks.net Thank you, Donald Ward
Joining multiple lines simultaneously?
Donald Ward replied to archdaly's question in Wishlist - Feature and Content Requests
For this example it can be done but you need to use a vertical line, which is still fewer clicks than connecting each one. First mode of the connect/combine tool see the tool tip to the right of the Tool Modes. I hope this helps. -
str started following Donald Ward
The other option is you can set your background to black Tool > Options > Vectorworks Preferences > Display Tab > Black Background or turn in on in the Quick Prefs settings in the upper righthand corner of the drawing window. I hope that helps.
@Matt Overton Yes, once you create an account for the Vectorworks University you can complete different levels of certification during the trial version of Vectorworks.
There is new content as well as existing workflows that still apply
Hi Alex, When in the Organization dialog box click on the 'Stacking Order' column header and then you should be able to drag and drop layer stacking order. If a different column header is selected it will prevent you from using the drag and drop function. I hope this helps.
Eat Sleep Design
Donald Ward changed their profile photo
I work with the snap to grid option turned off and type in the exact distance that I want using the Floating Data Display bar (tab key). You can always change your snap increments by double clicking on the snap to grid option in the smart cursor cue settings. Depending on the complexity of the design you may need to use a combination of techniques to get the desired look. I hope this helps.
Also when moving objects in 3D use the 3D selection tool instead of the 2D selection tool. You will be able to snap to points in 3D more accurately.
Hi Jim, I recommend contacting technical support by phone: 410-290-5114 or by email: tech@vectorworks.net. They would be able to assist you better because there are several questions needed to be asked in order to narrow down what setting could be turned on or off.
There are several different scenarios which could be related to unexpected snapping behavior it would be difficult to list them all. In my experience the culprit is normally a smart curser setting is on or off in the snapping palette (formally known as constraints palette), but every case can be slightly different depending on the project or the end users computer setup. I recommend contacting technical support by phone: 410-290-5114 or by email: tech@vectorworks.net. They would be able to assist you better because there are several questions needed to be asked in order to narrow down what setting could be turned on or off. I will however list a few troubleshooting techniques. 1. Make sure 'Snap to Grid' is turned off and 'Snap to Object' is on in the snapping palette. 2. Make sure you are in a Top/Plan View then go to View > Align Layer Views to make sure all of your layers are in the same view. Example if you are working on a layer in Top/Plan view and trying to snap to objects on another layer that is in Top or custom view you may get unexpected snapping behavior. 3. Check your tool modes and make sure you have the correct mode selected for the tool that you are working with. 4. Zoom in on the area you are working in. The closer you zoom the more accurate you'll be. The snap loupe command can also be used for this "Z" Key (2009 and up). 5. For jagged lines make sure Anti-aliasing is selected in the VW Preferences under the display settings. Tools > Options > VW Preferences. 6. Pay attention to your smart cursor cues as VW is giving you visual feedback on where your cursor is located on screen. It is important to know how VW sees your cursor location vs. how we as humans see it on screen. 7. Layer scales if you are working on a layer set to 1/2" = 1' and trying to trace or snap to objects on another layer with a different scale you will get unexpected snapping results. 8. Also in the VW Help refer to Setting Snapping Parameters and Interactive Preferences (Note the difference between the Selection Box vs. Snap Box). Note that at the bottom of these Help articles there are additional links leading you to articles to help further explain these settings. Before configuring the snapping palette you will want to have an understanding of these settings or else you will get the unexpected snapping behavior and waste more time in frustration than reading first. I hope this helps.
There is a new stair tool in VW-2010. http://download2cf.nemetschek.net/www_movies/2010/New-Stair-Tool.mov
File > Export >Image File
Why does Vworks 2010 not show page breaks
Donald Ward replied to B.Balemi's question in Troubleshooting
When you go to File > Page Setup what is showing in the Horizontal and Vertical fields. If this is set to 1 & 1 then you will not see page breaks even if this option is checked. You will have to change your Printer Setup options. -
Class structure: More than 2 subclasses
Donald Ward replied to Christiaan's question in Wishlist - Feature and Content Requests
Hi Christiaan, Sorry the link was intended for vectormax and not a solution for the class structure.
