jeremyb
117 -
Everything posted by jeremyb
Further to my last post - I have found the answer in 3D Modelling:3D Reshape - easy to do in a 3D view such as Right Isometric - in case it helps any other struggler.
I need to draw a boundary wall the top of which slopes up from 1000 to 1830 over about 2M length. Is there a way to draw a wall with a sloping top like this? Also, I cannot find how to break a wall - assume this is possible?
Michael Thanks for your help. After a bit of trouble I have done as per your second suggestion and it seems to have worked. Thanks. Jeremy
I have created polygons with a solid colour infill. When I extrude these to show as 3D objects in 3D view they lose their colour fill when viewed in normal 2D Top/Plan view. Is this supposed to happen, it is a bit irritating?
I can't find any information on how to do this, can anyone help and tell me how it's done? Thanks
Yes I was, unchecked it and boundary appears. So thanks for that. Don't know how that happened. What is unified view anyway?
I have set Page Boundary Visible in Page Set Up, but it is not appearing? Is this a bug or am I missing something? Page prints correctly, but I need to see the page boundary on the screen. Any ideas?
I have turned on Drawing Grid, page size set to A2. But the grid does not fill all the page, it's only a square smaller than my page size. In fact it stays same size whatever page size I set. Can't find a way to enlarge it? See screen grab. Any ideas?
Thanks Tamsin, file emailed over to you. Jeremy
OK, I have now found the Select Similar Tool. I have changed preferences to Same Symbol Name, but when I select a group of plants (one which I know has more than one occurrence) I get an error message to the effect that I can't select an object with these parameters???
Is it possible to view all occurrences of same object, ie select one plant and then highlight/select all other occurrences of the same plant? I mean in plan view not on a plant list.
It would be very helpful for me to be able to highlight every incidence of a particular plant or group of plants on a planting plan? This would apply to any object used more than once I suppose. I think that this should be possible but I cannot as yet see how to do it.
Ray. Thanks for quick reply. I am new to the world of Mac, but apparently video drivers are automatically updated, you cannot download the drivers manually, so I assume all is ok there. I have also run utilities and updated permissions. All to no avail. Any other ideas?
I have posted about this before but did not get much response, so am trying again. When editing 2D plant symbols VW crashes suddenly with an error report, this happens when I press the Exit button, about 50% of the time. Possibly it is due to corrupted symbols but they seem to work fine before editing, and it even happened with a newly imported plant object symbol. This is driving me nuts and really shouldn't be happening, so I would dearly appreciated it if someone to point me in the way of a solution. iMac 2.8GHz Intel quad core i7, 8 GB RAM, Radeon HD4850 graphics card
I am trying to move my page boundaries and have set up my page size as A4. All I get though, when I try to move the page, is a small white rectangle with arrows on each side and which turns red when I left click. Command works fine with other files. What am I doing wrong? When I print the page is blank. However, when I open my only Sheet Layer, then the move page option starts to work???
I have just invested in an iMac and am running VW2010 with SP4.I have beset by constant crashing this morning, which seems to be happening mainly when I edit plant 2D attributes. I thought macs were meant to be stable?!
I am also experiencing crashing when I edit plant 2D attributes. Did you manage top get to the bottom of the problem?
Pat. Yes they are on different layers, nut I have changed the layer stacking order and lay and behold it has worked. Thanks very much. In my ignorance I didn't realise that the layer stacking order did any more than organise the layers neatly. Wiser and happier now!
I have a survey layer with boundary walls. When I Place Plants on my Planting Plan layer they sit under, to the back of, the walls. No matter what I do I cannot bring them to the front. Any ideas anyone as I can't find any settings that say that the walls should always bi inth front???
What Apple Mac to get for VW2010 with renderworks
jeremyb replied to jeremyb's topic in General Discussion
Thanks for all your advice. Think I am going to take the plunge and buy an iMac like yours Peter. Ooerrr! One other question, how do you do backups? I would want to backup to a different hard drive, suppose I could do this over an eternet connection to a hard drive on my pac, but what do you guys recommend? -
Long time pc user but having just used VW on a mac I loved it. Can anyone recommend the a)minimum and b)ideal spec desktop machine that I should get, if I take the plunge to convert. I would like the option to upgrade (does this mean a MAC pro?). And should I get quad as opposed to Dual core, and how about RAM and video cards? I dont mind spending a bit more to get a machine which lasts a while. Any advice happily received. Thanks
How to create a section drawing using Stake Object tool?
jeremyb replied to jeremyb's topic in Site Design
Thanks for this, Ian. However my DTM views as a series of contour lines joining only some of the stake objectsin 2D, but is an unreadable series of vertical lines in 3D, I realise that I am doing something, probably a lot, wrong, so any more help much appreciated! -
I have used the Stake Object tool to mark level data points on a survey. I now want to be able to view these 'side-on' as a section showing the various levels in this (sloping) garden. Surely this is possible, but I can't for the life of me find out how to do it. I am a relative beginner, now using VW2010 (no little investment) and I just wish thyat it was a bit more intuitive and easy to use.
how to change dimensions of object by dragging corners in 2010
Thanks for replies. I have found the answer - I did not have Contraints Snap to Points toggled on. Simple as that. Doh!
