Hi All
I've been having problems when trying to create solids from extruded polylines. It seems as the the resulting extrusions are not closed, ie. the end faces are missing (not closed) Am I doing something wrong or missing a step in the process?
Also, in trying to create solids from these polylines, I also run into problems where I cannot subtract one solids from another. Even though the two solids are intersecting properly, its like the solid to be subtracted just disappears.
Each solid involved in the subtraction process, is made from extruded polylines. And are created by Intersecting the extruded front and side view polylines of the required solid. (This is the process that I have been using to create solids, to get around the unclosed solids problem stated earlier)Does anyone have a way to fix this or a better way to do this process?
I work for a Environmental Graphics firm creating interior and exterior signage. Our company is fairly new to VW, and the way we have been using VW to create our signs is to import our AI files in the DWG format into VW, and using the extrusion of polylines to create our solids.
If anyone can help with the two issues mentioned above, we would greatly appreciate it.
Thanks
-AussieAussie
