OneWorld
    8
Reputation
0 Neutral
  1. Wow that worked thanks! I have used this program for more than 10 years, but I have not used these functions before. I must say, that was not the most intuitive way to do what should have been fairly simple. Selecting a row to sort a column seems a bit backwards to me. Thank you again for a quick and accurate response. This place is always a treasure trove of useful information and helpful people.
  2. We are trying to create a door schedule suing the Door Schedule plug-in. We usually do them manually. Our plans are 1/8" scale and we have a viewport on another sheet we are using for a large scale plan. This is causing the Door Schedule to read our doors twice and we are getting duplicate doors. Also, I can't get the doors to sort at all. The little bar graph buttons aren't doing anything. I select the row and they don't sort. How do you set which row the the Schedule sorts to? Thanks!
  3. Wow, thanks for that. This was making me nuts. That was not the most obvious thing to do...
  4. Thank you, but how do I learn to set them up in the first place? I am trying to create a door schedule from the info that is set in the doors in my plan. How does this work?
  5. Hello. I used to generate my door schedules the old school way (using the worksheets as a chart and manually filling them in). I would like to do this the smart way and have the door information from the door drop into a schedule automatically. I know this is a newbie question, but how do you do this? I have tried to piece it together reading the manual and I'm not finding this particularly obvious. Is there a tutorial somewhere? An aside - I have a format for a door schedule that I like, is there a way to customize this information so that it fits our office standard schedule?
  6. I thought this board was moderated. Will someone please help?
  7. I currently run VW Architect. I recently purchased RenderWorks. I entered the serial number and it showed that Renderworks is enabled. However, none of the RW functionality is showing up. I also notice that when I go to About VectorWorks, it does not list RenderWorks. I called technical support twice today and waited for 25 minutes before dropping into voice mail. How can I get RW turned on?
  8. I just bought RenderWorks after already having installed VW Architect. I received a new SN which appeared to unlock the RW functionality in the SN window. But when I go to select any Renderworks options, they are grayed out. What did I miss? I tried reinstalling VW from the DVD and still nothing. Help!
