45 -
Hi all, corroborating most of the points above, I'd like to make three brief points relating to the 3 different roles that I fulfil doing my job as an architect and VW user: In my practice I am at the same time the Principal/owner and the head VW user , and in my spare (?) time I am a trainer and proselytiser to colleagues in other practices. Principal - I have always found that the uniqueness of VW is in its model buildup methods and usability concepts, which are the closest thing there is out there to the way an architect's mind works from a sketch to a weathering detail. That is why I have been using it since 1985. Running a practice, although it is difficult to find 'Vectorworks proficiency' at the top of a candidate's CAD experience list, I have trained many fine younger colleagues (even from scratch) that have gone on to become better than me at it and have even spread the word. Admittedly it can be a bit steeper learning curve than someone who is revit proficient entering a revit office. but we all know that every office has a different set of protocols and standards that make it adjusting to a system always an initially difficult task. VW user - I am delighted every year by how well VW is maturing and encompassing new flexibities and astounding resources as well as capabilities that are well beyond what we dreamed of when there was only one undo! It is also interesting how VW has managed to 'complicate' its arsenal without over-complicating or dramatically altering its core interface, unlike products like Word or Photoshop that have become all but unintelligible to me. However, as a daily user that delights in navigating through the many features of VW, I am deeply disappointed with the small step back that the new tools have taken with 2020. Many names fro this iteration have been adopted in the posts above, from Fisher price, to Cartoon, to DIY, I understand that the they may work better for a dark mode, but in my opinion, the new tool icons just don't work! You don't change something that has served you so well. I'm sorry, but they are proving a hindrance and a nuisance in my work, the clip tool looks like a tubular section. I wish it were possible for Nemetscheck to address this and revert back to an different set through an update. Trainer - lastly, as a trainer, I am now in a bit of a more difficult position when approaching colleagues. Especially when doing training/promotion in larger practices that have an established and very serious ACAD or revit core of engineer-sympathetic outlook toward CAD in general. to come up and show these new cutesy-carttony icons while I show the magic of what VW does, well, it is frankly quite embarrassing... thanks
I agree with the previous posts, it's like the palettes have been 'cartoonified' by some strange stroke. the other day it took me 10 minutes to identify the offset tool!
it works! Thank you very much Jim. in a roundabout way, I had to 1) delete the end wall cap, then 2) show the wall cap line, 3) apply the render and finally 4) reinstate the end wall cap. this way I have a 2D 3D correct representation... there's always a way with VW
Hello, I have a query regarding the way caps, I can't seem to show the texture of a wall cap in any realistic render mode. I attach an image for clarity, the wall caps are shown by the arrows but appear with no texture... any suggestions welcome Manfredi
manfredi changed their profile photo
thanks Bcd, how're you keeping? I'll send them over forthwith
I have some old but suddenly really important files generated with Minicad 7 that I need to urgently open up with my VW2013, any suggestions greatly appreciated
I have a problem with the space tool: I set up a space and relative label, then for the sake of page space I moved the labels ( a slightly edited Space Tag 1 in this case) off the main page so I can then show then on a separate viewport or in a column on the side of the page. All is fine for a few work iterations and then if I either go into the design layer or close the file - this is totally random - the space labels change scale, either halving or doubling in size. The only way to get them back to the regular scale is to go into the settings and then immediately close them... I had this problem on another file and I worked out it might have been the fact they were on a different viewport (in both the files I work on a 1:100 design layer with relative sheet layer). So I re-worked the DL to have the space labels neatly around the model and it seemed to work. Suddenly a couple of days later the problem presented itself again. I have discussed this problem briefly with my good friend BCD, and at his suggestion I tried a few view changes and viewport edits, but the problem seems to be in the way the DL behaves if you get in or out of it from diverse viewports in the SL. any suggestions?
That was helpful, and although a bit convoluted, it is still manageable if you only deal with it once. Just another question: can you tweak the decimal places in the area field? example: my units are metros with 3 decimals on the normal dimensions, but on the space tool I'd like to have just one decimal after the point in the area calculation, can it be altered? thanks
thanks to all, it looks like the third party option is the simplest, and if it become justifiable I might invest in it Regards Manfredi
thanks bcd, but with 9 panes it is rather tedious, because it decomposes it into a lot of 3D polygons. worth a try though... might aactually build them myself and allow room for adding new panes later
I've been trying to make folding sliding doors with the custom door tool. Folding sliding doors are usually an odd number of folding concertina-type doors that slide away neatly to the side walls. The door tool allows me to make bi-parting glazed leafs that fold away, and they're quite good. Any number above two is not permitted, and the only way to get the nine-leaf unit that I need is as a window object, but this won't show as open, which I require for the presentation. Is there a way 1) to edit a custom door arrangement (not that I can see) 2) to decompose the window object and treat it as a symbol or 3) do I have to go back to creating a symbol from scratch? Thanks to anyone who can help Manfredi
got it thanks, I hadn't checked the attributes button as per Wes's second screenshot two posts ago on this thread... doh!? Thanks for this guys m.
the viewport shows everything as it should, but the actual section appears colourless or not as a proper section, if you know what I mean... not too thick and with no shading or colour within it.
I don't know if I'm missing something - I just upgraded to VWA2011, and I can't seem to see the components in a section viewport. I've tried switching all the usual display buttons on, and I've checked that my line thickness is showing and my sheet layers are not black and white only, but nothing happens. I've tried tweaking the section style line thickness and colour, but nothing happens either, the section looks white with max .35 wide lines, even no matter what rendering I apply to the viewport... This happens both on new files with a couple of walls as test, and on previous files that worked until a few days ago in VW2008 Can anyone help? is this a bug? Thanks
