go2greece
102 -
Posts posted by go2greece
I have decided to go with a rabbits foot for virus protection.
Does it come with an anual update?
peter
we had a virus on system os 6 >mandelbaum. it was 1988 or 1989.
since that day nothing ever more.
we use intego x4.
peter
just out curiosity.
if i am traveling to helsinki/london/madrid/rom trying to buy any version of VW, they will not sell it to me because i am from abroad. or is is that they will not sent it abroad.
or is it a license matter of NNA.
according to european right (market) this could not be.(if it is good or bad is another story)
as i said just out of couriosity.
ps. petri . i know that you are independant an as free as the wind
peter
i think you can buy a international version in finland (since you live in europe).
go to ultirender.com or ask petri
peter
Hi Peter (go2greece),
- When you were having these problems, were you running 12.5.1.65397?
yes i was running the latest version(12.5.1.65397)
- When you were having these problems, were you autosaving with or without the backup folder feature?
without the backup folder.
Did you ever try autosaving with the backup feature set the opposite way?no.
- Do you get the feeling that your FAT32 disk was involved in the problem? Or did in not matter where the files were getting saved?
let me put this way, since i am switched of autosave and i am not useing the FAT32 for reference files or objects files i am fine. at least no corrupted files
- When you originally describe this as a "crash/corruption" problem, did crashes always precede your corruptions? Or are the crashes and corruptions (at least potentially) two separate problems?
the corruption happend twice after a chrash and one without any prior chrash. GUNTHER(NNA) has the chrash log
forgot to say one disk was FAT32(backup) all other disks are mac_format
kalispera
peter
What, because you have a backup now, or because files are not being corrupted now?
the option >autosave is unchecked as backup in a separte folder
since i am saveing manual (a comand i almost forgot) on a local disk everything is fine
peter
YES,
firewire HD> 2 in row
usb hub > dongle, printer, dongle, scanner
BUT,
i was able to reproduce the chrash/corruption without any USB/FW connection
since i switched of autosave > no problem
peter
go2greece
Thanks Katie, Thanks Ray
kalimera
i was working today on my XPsystem and suddenly this message>
Details: Rule "Default Block Bla Trojan horse" blocked communication.
Local address: All local network adapters(1042).
Process name is "C:\Program files\VectorWorks 12.0.0\VectorWorks.exe".
has somebody any idea?
or is it just the date 13th or is it this stupid Norton?
as a matter of fact vw works as usal ...
katie i sent the log files.
same effect on default file and other files.
does not happen on VW 12.5.1 on winxp_pro.
and it does not happen if i save manual before.
peter
yes.
>verify disk permission and repair
>>> i am using the mac disk utility no other
>> two firewire disks are connected
> one internal (2 partition)
last but not least > i am working on a recoverd file, which was corupted by the old 12.5.1 updater (i guess)
kalispera
peter
same here. latest update (yesterday)
>>> VW chrashes when i create(try) a new class.
>> this does not happens after i save before manual
> if you want the log file let me know
Date/Time: 2007-01-23 15:34:29 +0200
OS Version: 10.3.9 (Build 7W98)
Report Version: 2
Command: VectorWorks
Path: /Applications/VectorWorks 12.0.0/VectorWorks.app/Contents/MacOS/VectorWorks
Version: 12.5.1 (???)
PID: 418
Thread: 0
Exception: EXC_BAD_ACCESS (0x0001)
Codes: KERN_PROTECTION_FAILURE (0x0002) at 0x0000001d
Thread 0 Crashed:
0 com.apple.QD 0x9604dd20 DisposeGWorld + 0xc4
1 net.nemetschek.VectorWorks 0x001ab7f0 abo
petr,
why you need a geotiff in your drawing?
what information you need from the geotiff?
do you need it as a referenced background?
peter
we have a workaround here in greece.
the geotiff willbe imported into a programm called DEM2TOPO (FREEWARE) which requires a IDL VIRTUAL MACHINE (RSI will sent it for free). DEM2TOPO exports the GEOTIFF into DXF, SHP and MP. the rest is import into VW 12.05(which is not free).
VW places the DXF on the grid of the transformed GEOTIFF according to the used datum (WGS 84 or...)
kalispera kai kali xristugenna
go2greece
not her in greece!!!
work in booth dirctions on any media.
go2greece
kalispera
the greeceguys are very pleased.
it works. at least on a mac.
go2greece
sorry i was not online
so go back to work
it works now .....
go2greece
instalation error: series B
mac os x 10.3.9
the following error log:
An undetermined "socket error" has occurred attempting to connect to the Internet.
Exception Type: socket.gaierror
Exception Value: (7, 'No address associated with nodename')
Exception Stack:
File "InstallerScript.pyc", line 1087, in GetAndInstallUpdates
File "/System/Library/Frameworks/Python.framework/Versions/2.3/lib/python2.3/httplib.py", line 718, in request
File "/System/Library/Frameworks/Python.framework/Versions/2.3/lib/python2.3/httplib.py", line 740, in _send_request
File "/System/Library/Frameworks/Python.framework/Versions/2.3/lib/python2.3/httplib.py", line 712, in endheaders
File "/System/Library/Frameworks/Python.framework/Versions/2.3/lib/python2.3/httplib.py", line 597, in _send_output
File "/System/Library/Frameworks/Python.framework/Versions/2.3/lib/python2.3/httplib.py", line 564, in send
File "/System/Library/Frameworks/Python.framework/Versions/2.3/lib/python2.3/httplib.py", line 532, in connect
anyone with a idea!!!
go2greece
greek fonts did work in Mini Cad under Macos 8/9
unicode is not proper implemented into VW12.
thats why it not sells here in greece!
it would be great to have unicode support in VW12.5 and....
peter
go2greece
this is a "open font type" otf
which works on macosX unicode (language greek)
Hiragino Kaku Gothic Pro W3
the export to winXP produce some mistakes (sigma)
go2greece
ps. it would be a great recomandation to implement unicode into vw
one my wishlist is the unicode support in vektorworks texttool (non roman, latin fonts)
go2greece
καλό απόγευμα από την Ελλάδα, έτσι πρέπει να μοιάσει με
for the rest of the world
good afternoon from greece, this is how it looks like
but vw can not do it proper or let me put it this way it should be on the agenda for the next update to implement a working unicode text support.
not only for greeks.
thank you very much jan15, you where a big help.
great knowing that experts are around (10000miles away )
go2greece
kalispera, hello from greece,
thank you jan15,.
are you working on a XP machine? or mac?
symbol(TT) ain't work proper on vw12 macos ( not at all)
it seems that i am on a long odysee to get this font issue solved.
is anyone her on this forum working with greek fonts?
win or mac
how does vw work with non roman or latin or japanese or china fonts?
go2greece
rotating working plane in 2D
in General Discussion
Posted
ROTADE DRAWING from Vectorbits (http://www.vectorbits.com)
peter
