go2greece
102 -
Everything posted by go2greece
ROTADE DRAWING from Vectorbits (http://www.vectorbits.com) peter
Does it come with an anual update? peter
we had a virus on system os 6 >mandelbaum. it was 1988 or 1989. since that day nothing ever more. we use intego x4. peter
just out curiosity. if i am traveling to helsinki/london/madrid/rom trying to buy any version of VW, they will not sell it to me because i am from abroad. or is is that they will not sent it abroad. or is it a license matter of NNA. according to european right (market) this could not be.(if it is good or bad is another story) as i said just out of couriosity. ps. petri . i know that you are independant an as free as the wind peter
i think you can buy a international version in finland (since you live in europe). go to ultirender.com or ask petri peter
A question for those with corruption issues
go2greece replied to Christiaan's topic in General Discussion
yes i was running the latest version(12.5.1.65397) without the backup folder. no. - Do you get the feeling that your FAT32 disk was involved in the problem? Or did in not matter where the files were getting saved? let me put this way, since i am switched of autosave and i am not useing the FAT32 for reference files or objects files i am fine. at least no corrupted files the corruption happend twice after a chrash and one without any prior chrash. GUNTHER(NNA) has the chrash log -
forgot to say one disk was FAT32(backup) all other disks are mac_format kalispera peter -
the option >autosave is unchecked as backup in a separte folder since i am saveing manual (a comand i almost forgot) on a local disk everything is fine peter -
YES, firewire HD> 2 in row usb hub > dongle, printer, dongle, scanner BUT, i was able to reproduce the chrash/corruption without any USB/FW connection since i switched of autosave > no problem peter go2greece -
Thanks Katie, Thanks Ray kalimera
i was working today on my XPsystem and suddenly this message> Details: Rule "Default Block Bla Trojan horse" blocked communication. Rule "Default Block Bla Trojan horse" blocked communication. Local address: All local network adapters(1042). Process name is "C:\Program files\VectorWorks 12.0.0\VectorWorks.exe". Local address: All local network adapters(1042). Process name is "C:\Program files\VectorWorks 12.0.0\VectorWorks.exe". has somebody any idea? or is it just the date 13th or is it this stupid Norton? as a matter of fact vw works as usal ...
katie i sent the log files. same effect on default file and other files. does not happen on VW 12.5.1 on winxp_pro. and it does not happen if i save manual before. peter
yes. >verify disk permission and repair >>> i am using the mac disk utility no other >> two firewire disks are connected > one internal (2 partition) last but not least > i am working on a recoverd file, which was corupted by the old 12.5.1 updater (i guess) kalispera peter
same here. latest update (yesterday) >>> VW chrashes when i create(try) a new class. >> this does not happens after i save before manual > if you want the log file let me know Date/Time: 2007-01-23 15:34:29 +0200 OS Version: 10.3.9 (Build 7W98) Report Version: 2 Command: VectorWorks Path: /Applications/VectorWorks 12.0.0/VectorWorks.app/Contents/MacOS/VectorWorks Version: 12.5.1 (???) PID: 418 Thread: 0 Exception: EXC_BAD_ACCESS (0x0001) Codes: KERN_PROTECTION_FAILURE (0x0002) at 0x0000001d Thread 0 Crashed: 0 com.apple.QD 0x9604dd20 DisposeGWorld + 0xc4 1 net.nemetschek.VectorWorks 0x001ab7f0 abo
petr, why you need a geotiff in your drawing? what information you need from the geotiff? do you need it as a referenced background? peter
we have a workaround here in greece. the geotiff willbe imported into a programm called DEM2TOPO (FREEWARE) which requires a IDL VIRTUAL MACHINE (RSI will sent it for free). DEM2TOPO exports the GEOTIFF into DXF, SHP and MP. the rest is import into VW 12.05(which is not free). VW places the DXF on the grid of the transformed GEOTIFF according to the used datum (WGS 84 or...) kalispera kai kali xristugenna go2greece
So long and thanks for all the non-compatibility?
go2greece replied to Petri's topic in General Discussion
not her in greece!!! work in booth dirctions on any media. go2greece -
kalispera the greeceguys are very pleased. it works. at least on a mac. go2greece
sorry i was not online so go back to work it works now ..... go2greece
instalation error: series B mac os x 10.3.9 the following error log: An undetermined "socket error" has occurred attempting to connect to the Internet. Exception Type: socket.gaierror Exception Value: (7, 'No address associated with nodename') Exception Stack: File "InstallerScript.pyc", line 1087, in GetAndInstallUpdates File "/System/Library/Frameworks/Python.framework/Versions/2.3/lib/python2.3/httplib.py", line 718, in request File "/System/Library/Frameworks/Python.framework/Versions/2.3/lib/python2.3/httplib.py", line 740, in _send_request File "/System/Library/Frameworks/Python.framework/Versions/2.3/lib/python2.3/httplib.py", line 712, in endheaders File "/System/Library/Frameworks/Python.framework/Versions/2.3/lib/python2.3/httplib.py", line 597, in _send_output File "/System/Library/Frameworks/Python.framework/Versions/2.3/lib/python2.3/httplib.py", line 564, in send File "/System/Library/Frameworks/Python.framework/Versions/2.3/lib/python2.3/httplib.py", line 532, in connect anyone with a idea!!! go2greece
greek fonts did work in Mini Cad under Macos 8/9 unicode is not proper implemented into VW12. thats why it not sells here in greece! it would be great to have unicode support in VW12.5 and.... peter go2greece
this is a "open font type" otf which works on macosX unicode (language greek) Hiragino Kaku Gothic Pro W3 the export to winXP produce some mistakes (sigma) go2greece ps. it would be a great recomandation to implement unicode into vw
one my wishlist is the unicode support in vektorworks texttool (non roman, latin fonts) go2greece
καλό απόγευμα από την Ελλάδα, έτσι πρέπει να μοιάσει με for the rest of the world good afternoon from greece, this is how it looks like but vw can not do it proper or let me put it this way it should be on the agenda for the next update to implement a working unicode text support. not only for greeks. thank you very much jan15, you where a big help. great knowing that experts are around (10000miles away ) go2greece
kalispera, hello from greece, thank you jan15,. are you working on a XP machine? or mac? symbol(TT) ain't work proper on vw12 macos ( not at all) it seems that i am on a long odysee to get this font issue solved. is anyone her on this forum working with greek fonts? win or mac how does vw work with non roman or latin or japanese or china fonts? go2greece
