go2greece
102 -
Everything posted by go2greece
creating a flat pattern for a frustum (a truncated cone)
go2greece replied to PAR's topic in General Discussion
hello all, is think its time that there is a competition for the most original and unconventional use of VWs. categories could be >>> puppet houses, food design, miscellaneous and and and the winners get a coffee mug from NEMETSCHEK peter -
Tips for converting Vectorworks file to later version
go2greece replied to Christiaan's topic in General Discussion
translation for non-germans layerplane-screenplane ged?ns >>>complicated course of action that prevents a problem-solving -
Bruce, yes, i think it is a bug. i got the same result. double click, very slow does this uncontrolable behaivior. i could repeat this with polyline and 2d-polygon. i think the 2d-reshape(move handle) was done like this> click the vertex >drag the vertex>click at new location. if you slowy double click at the same location of the handle VW gets confused:-0 peter
bruce, do you have checked in your preferences >>>EDIT>>>click drag drawing? i can reproduce this behavior only if >>>click drag drawing is switched on. peter
we are working years with .OTF fonts (DIN.OTF, DINPRO.OTF). never ever had any issue withit. we use them in templates, reverences, pdf dwg export and import. i can not tell you if VW is designed for .OTF peter
Thanks Petri for the link, horst vielen Dank fuer die info the funny thing is, the best way to understand a structure or a system is to build it as a mock up with cardboard or balsa wood at least for me. peter ps.
i am doing right now a small mock up out of toothpicks. as a matter of fact my structural engineer here on the island have not any idea of what and why (but hes good in what we do for bread and butter) peter
this is what i want to do with VW. my main issue is to create a 3d grid any ideas...? peter http://img834.imageshack.us/img834/1654/ppdraft03.jpg
I have to design and built a geodesic dome with a diameter of approx.10m and a height of of 5m. the constructionmaterial shall be wood. i have done in my life airports and museums but never such a construction. so any ideas where to start ??? how to do a 3d grid how to do the workshopdrawings >>> each element or ??? any ideas? peter
thats a nice one from AIGIOS VASSILIS thanks peter
hello, we created a VW file with all our officestandards, such as hatches, images, walls, standard details and finaly our settings for dimensions. we created a dimensonchain with this settings in our drawing and made a >create symbol of this dimenson. this >officestandards< are added in the resource browser >>>browse drawing. you can make this also a favourite in your default drawing. if you need the settings of your dimensions (officestandards) you place a simbol of your dimensonin your drawing. done peter
bump... no mod.? peter
done with vw http://www.archdaily.com/76944/caac-paredes-pino/ nice work
bruce, why don't you create from >>>toolset >>> rect. grid and than you align your objects to this grid peter
thanks bruce, the command > create polygone creates more segments did you try to do it with nurbs? i think that would do it much better
your cut out piece is a polyline. try to convert in a polygon or us more vertex. http://img641.imageshack.us/img641/4369/picture7dn.png
petris's proposal is much more elegant i have to admit peter
DEXIE, i have once imported 96 squarekilometers with a 5 by 5 grid so dont worry . first> the comma separated coordinates have to be imported and transfered into 3d points ( if you have difficulties with VW try DL-02 from sierra-soft , which should be free> creates a dxf file of the points). i would split the VW file into hand-able portions like 100mX100m > create a master-file and reference the parts before you do so check the DATUM of the Emap WGS84 ..... it looks like your point are somewhere in africa CHAD??? peter
comme dit ?l?gamment peter ps. have also a look >>> http://www.touchcad.com/
we do it with sketchup>export 3ds in VW > import 3ds islandmoons way is more elegant http://img19.imageshack.us/img19/3676/picture4de.png islandmoon how do you create this nurbs sphere slices? ps. the overlay function from GOOGLE EARTH would be nice in VW
for(i = 0; i < 100; i++) for(j = i; j < 100; j++) some_function(i, j);
good!!! if it is available here in sunny greece i will buy it....
kool aid just out of interest, how looks your posted wall in >top/view peter
thanks p will try it with this plug in greetings from greece
you can find this in your user manual Resources in Favorites For quick access, the Resource Browser can store links to VectorWorks files that contain resources that you use frequently. You can then import resources from a Favorites file into any VectorWorks file and not have to search for the file again. Remove the link when the file is of no further use. Favorite files are remembered for future sessions. Use the Files menu in the Resource Browser to create, use, and manage your Favorites list. Alternatively, add files (or aliases or shortcuts to the files) to the appropriate Favorites folder manually. Making the Current File a Favorite To make the current file a favorite: In the Resource Browser, select Add Current to Favorites from the Files menu. The file is added to the File list under Favorites. The file must be saved to be added as a favorite. Making an Unopened File a Favorite To make an unopened file a favorite: 1. In the Resource Browser, select Add New Favorite Files from the Files menu. The standard Open dialog box opens. 2. Select the file to make a favorite, and then click Open. The file is added to the File list under Favorites. The file must be saved in the same version of VectorWorks as the current file to be added as a favorite. Multiple files can be selected and added as favorites at the same time; alternatively, press Ctrl+A (Windows) or Command+A (Macintosh) to select all files at once. Opening the Current Favorite To open the current favorite: 1. In the Resource Browser, select the favorite file to open from the File list. 2. Select Open Current Favorite from the Files menu. The file opens. Importing a Resource from a Favorite To import a resource from a favorite file: 1. In the Resource Browser, select the favorite file to access from the File list. The file name is displayed as the current file in the File list, and its resources display in the resource window. 2. Select the desired resource from the resource display window. To import the resource for future use, select Import from the Resources menu. To use the resource immediately, double-click it to activate it, or select Apply or Make Active, if applicable, from the Resources menu. (Alternatively, drag the resource onto an object or to a location in the current file.) Once the resource is placed or applied in the drawing, it is added to the Resource Browser for the current file. Multiple resources can be selected and imported at the same time. Refreshing Favorites from Disk To update the resources from all favorite files: In the Resource Browser, select Refresh Favorites from Disk from the Files menu. All current favorite files are reloaded into the Resource Browser, to reflect any changes that occurred since they were loaded when this VectorWorks session began. Revealing the Location of the Current Favorite To reveal the location of a favorite file: 1. In the Resource Browser, select the favorite file to reveal from the File list. The file name is displayed as the current file in the File list, and its resources display in the resource window. 2. Select Reveal Current Favorite from the Files menu. Either Windows Explorer or Macintosh Finder opens to the folder that contains the file. Removing Favorites To remove a single favorite file: 1. In the Resource Browser, select the favorite file to delete from the File list. 2. Select Remove Current Favorite from the Files menu. The file is removed from the Favorites list. To remove all favorite files: 1. In the Resource Browser, select Remove All Favorites from the Files menu. A confirmation dialog box opens. 2. Click Yes to remove all favorites. All favorite files are removed from the Favorites list. Adding a Favorite Manually To create a favorite manually (not through the Resource Browser): 1. Place the file that you want to appear on the Favorites list (or a shortcut or alias that points to the file) in one of the following folders. Favorites Folder Effect on Favorites Lists [user]/Libraries/Favorites The file appears only in your Favorites list ([user] is the user data folder specified in your VectorWorks preferences) [Workgroup]/Libraries/Favorites (VectorWorks Design Series required) The file appears in the Favorites list of any user who has the workgroup folder set up in VectorWorks preferences The file is added to the File list under Favorites. 2. In the Resource Browser, select Refresh Favorites from Disk from the Files menu. Only files that are in your user Favorites folder can be removed with the commands in the Resource Browser. (See User Folders Preferences for more information.) Files that were placed in a workgroup Favorites folder must be removed manually.
