kmoore1
172 -
Never
Everything posted by kmoore1
quote: Originally posted by JoshuaGill: My platform is Windows 2000 ME. The VW version is 9.0.1. The last program that was installed was RenderWorks 9. I open the file using the File command. So far it only seems to be one file. I created the file using VW 8.5.2 and I tried and opened the file once in VW 9 and when I tried to open it again, I got the same message. Once I couldn't open it in VW 9.0.1, I tried to reopen the file in VW 8.5.2 and I received the same error message. Since you opened the file in 9.01 It converted it to a v9 version of the file and should have defaulted to using a new name. You might be able to try re-opening the original 8.52 file if it still exists. VW 8.52 won't be able to open the v9 version of the file which may be why you're seeing the error there too. It sounds like this file is corrupted in some way. If you could e-mail it to me I'll see if we can open it here. I would also suggest that you run some of the system disk utilities like chkdsk, scandisk, defrag, and antivirus software to make sure that this isn't a sign that a hard disk is going bad or that a virus or worm has infected your machine. ------------------ -- Kevin Moore --------------------- Product Manager VectorWorks SpotLight ---------------------
quote: Originally posted by JoshuaGill: When I try to open one of my files, I get a dialog box that has a title of "Microsoft Visual C++ Runtime Library" and the body of the box says "Runtime Error! abnormal termination" Can you tell me what I need to do to open this file? Can you give me some more details about your platform, O/S, machine configuration, VW version, etc? Are you double clicking on the file in the O/S or are you opening it from open command in VectorWorks? Is is just the one file or is it a bunch of files? Recent changes to your system? (new software, hardware, etc)What is the reported size of the file in the system? All of these things could be contributing to or causing a problem. I'll need some more info to diagnose cause of your problem. TIA "Doctor, it hurts when I go like this." "Then Don't Do That!" ;-) ------------------ -- Kevin Moore --------------------- Product Manager VectorWorks SpotLight ---------------------
quote: Originally posted by jomer: When drawing Strand Iris untis even though they draw as two three or four compartment channel floods you canonly enter informataion for one compartment. I guess I could use a user defined field to allocat the extra channel and colour but it is worth noting as a problem that needs to addressed. The same seems to happen with the imperial symbols. Thanks In order to work with these as multicircuit units you'll need to look to the cyc parts folder or strip parts folder in the strand library and insert each of the component pieces of the unit. (one for each circuit) Once you've done this you can then convert these to a multicircuit unit which will then behave as a single multicircuit unit but will allow you to enter three or four or whatever sets of information. There is a brief description of this process on page 4-8 of the SpotLight User's Guide. HTH ------------------ -- Kevin Moore --------------------- Product Manager VectorWorks SpotLight ---------------------
quote: Originally posted by bruce johansen: mac 8600/200, os8.6, vwsl 9.01. i've imported a dxf from autocad2000, everything is there. question 1:since the objects depicting lamps are just objects, i must convert them to symbols.example: there are 9 pc2k's. select 1 and create symbol and name it, no sweat.select an other, but you can't give it the same name. so you end up having 9 names for 9 identical lamps.now u must declare each of them individually, lighting ins.and fill data fields. now the rest of the plot has 54 pars,36 lekos, 17 s4 pars, 30 pc1k, etc...IS THERE SOMETHING I DON'T UNDERSTAND? Currently there isn't a good way to get from the groups you're getting from autocad to symbols / instruments in SpotLight. If the groups have record information attached your best bet may be to export the data out to a text file and use an external program like excel or Lightwright to massage the data a bit to include a field for the symbol name. Once you have the symbol names filled out for the instruments create symbols in SpotLight from one of the groups. (i.e. create a pc2k symbol and enter pc2k as the symbol name for all those instruments.) You can then import the data file into a basically empty file or into an empty layer in the file. This will give you instrument objects with symbols and data attached and you'll just have to drag them into place on the plot where they belong. I think this process could be made a little bit easier if you wanted to delve into the world of VectorScript a little bit. I'll add this as a wishlist item for SpotLight. ------------------ -- Kevin Moore --------------------- Product Manager VectorWorks SpotLight ---------------------
quote: Originally posted by tgrabowski: Where in the preference dialog in the control to turn this off? I can't seem to find anything that controls this column. Was it somethnig that was changed in 9.0? (Still waiting on UPS for the upgrade). Thanks This column can be turned off under the Worksheet preferences. Click the little downward pointing arrow button in a worksheet and choose Worksheet preferences. Turn off the option to "show tabs" and the row and column headers won't be printed out with your paperwork. HTH ------------------ -- Kevin Moore --------------------- Product Manager VectorWorks SpotLight ---------------------
quote: Originally posted by Cosmo: Trying to print on an HP Deskjet970cxi w/ HP driver 4.2. G4 OS 9.1. If I try and print VW crashes with an error type 11. If I set the print parameters in the HP print dialogue to Post Script only, it just prints the text. You might try running with as few extensions as possible to see if that works. At one point I had a subtle extensions conflict of some sort that made my mac unstable and it took me forever to look at my extensions because all of the extensions seemed to work fine. The problem always seems to be in the last place you look ;-) HTH ------------------ -- Kevin Moore --------------------- Product Manager VectorWorks SpotLight ---------------------
quote: Originally posted by tgrabowski: The column I was trying to resize is the leftmost column that has the swquential row numbers in the worksheet window, the one before column A I think this width is set automatically. You can turn off this column in the worksheet preferences dialog. Which is found under the little arrow button on the worksheet window. Kevin Moore ---------------------- Product Manager VectorWorks SpotLight ----------------------
quote: Originally posted by ArenaLights: I am using versin 9.01 I am using the external ID as the manual says . the program counts throught the lights and then a message saying that all lights were not updated, and the ones that were not updated would be selected. Each unit on the plot was selected. Probly a stupid mistake, but I have tried a few things and still have been having trouble. . It may be that you didn't get the external ID field and UID Field matched up when you first imported data into Lightwright. You can view the external ID field in LW by adding that as a column in the worksheet view. If these values are blank then the UID from SpotLight didn't make it into Lightwright. HTH Kevin Moore --------------------- Product Manager VectorWorks SpotLight --------------------- [This message has been edited by kmoore1 (edited 08-16-2001).]
quote: Originally posted by tgrabowski: As to resizing the row number column (the leftmost column), it won't work in the worksheet window. If you embed the worksheet in the drawing, this column doesn't show but then you lose the ability to print it in pages. The row height is VectorWorks worksheets is automatically determined by the font sizes present in the row. If you want more space in a row you can add a column to the worksheet and select a cell in the row you wish to enlarge. Change the font size for this cell, and the entire row will grow. You can also select the entire column to resize all of the row heights. You can then shrink this new column down to zero column width so that it won't appear on either the drawing or when you print. HTH Kevin Moore --------------------- Product Manager VectorWorks SpotLight ---------------------
The problem with inserting the Source 4 symbols from the object browser is the result of a bug in the object browser on windows. The degree sybmol in the name of the symbol is preventing it from working. Rename the symbols and they should insert just fine. This has been buglisted and will be addressed in a future release.
quote: Originally posted by litemike: i have spotlight 8.5.2, is anyone else out there having a problem with auto-renumbing, it's not doing it what so ever. This was a bug in the lighting position object in SpotLight 8.52. When auto-numbering it would always number from left to right no matter what sorting direction was chosen from the list. This has been adressed in SpotLight 9.01. Any files you have already created in 8.52 will be corrected when you open them in 9.01 HTH Kevin Moore --------------------- Product Manager VectorWorks SpotLight ---------------------
quote: Originally posted by ArenaLights: We just upgraded to version 9.0 and have run into a problem with the object browser and ETC symbols specificly. <SNIP> We tried to use various symbols from various libraries and have run into the problem continuously. We also tried it in the older version and did not have the problem. Please Help Thank You :-) I was able to duplicate your problem with the ETC library in SpotLight 9.01 for Windows, but strangely enough couldn't duplicate the problem on the Mac. I don't know of anything special or fancy about that library that should cause it to fail to be inserted from the object browser. I'll look at the ETC library and see if there is something that can be changed to make this work. In the meantime inserting these symbols from the resources palette as either instruments or simple symbols seems to work fine. Kevin Moore --------------------- Product Manager VectorWorks SpotLight ---------------------
quote: Originally posted by bruce johansen: 2-how do i get the x value of the position of a lamp on a pipe to print in a report so that my electrician can hang the dam lamps in the right places Create a new worksheet Click on the lefthand side of the ws on one of the row buttons and hold down. A pop-up menu appears that lets you choose whether row is a spreadsheet row or a database row. Choose database row. For the criteria choose 'Record' 'Lighting Device' is 'Attached' then click ok In the worksheet select column one of your new database row and enter: ='Lighting Device'.Position In column two enter: ='Lighting Device'.'Unit Number' This is the magic part, in column three enter: =XCENTER You might need to change the cell formatting of column three to get it to format as feet and inches or whatever. Chapter 16 in the User's guide has info on worksheets. Check out pgs 16-10 to 16-16 in particular for further details. HTH Kevin Moore ----------------------- Product Manager VectorWorks SpotLight <kmoore@nemetschek.net> -----------------------
quote: Originally posted by jtallen: Again i don't understand if it is a program you guys are creating it should mess up the labels from a program you also created. It is a lot of work to go through a 300 unit plot and correct the labels. Especially if i have the instruments oriented 4 different ways. Why don't you fix it so it won't mess the labels up!! Can you describe your migration process a little further for me. Did you start with the theatre lighting toolkit under VW 8.52? Did you use the SpotLight 8.52 menu command to convert a plot from 8.52 or did you use another method? Did your labels transistion correctly from VW 8.52 to SpotLight 8.52? Does merely opening your SpotLight 8.52 file in SpotLight 9.01 cause your labels to shift? Do you know if your user origin has been moved at some point? I'm not trying to pick on you with these questions I 'm just trying to see where the error was introduced into the process so that we can fix it. It is prefectly reasonable to expect the information to move forward without error and certainly without corruption. If you could also e-mail me all three of your files (VW 8.52, SpotLight 8.52, SpotLight 9.01) so that I can do some testing It would greatly speed up discovery of any underlying problems. TIA Kevin Moore ---------------------- Product Manager VectorWorks SpotLight <kmoore@nemetschek.net> -----------------------
quote: Originally posted by Eric Chenault: <Snip> However, I have a few issues with some of the new features not working quite right. Is this really the best place to post those (there haven't been many messages here), or is there an email contact directly to the SPOTLIGHT developers at Nemetschek? This forum is fine for discussing problems and issues. You might also want to check out our theatre mailing list.( http://www.nemetschek.net/support/mailinglists.html ) It is a little more active, and is not limited to just SpotLight discussions. Kevin Moore ---------------- Product Manager VectorWorks SpotLight <kmoore@nemetschek.net> ----------------
quote: Originally posted by psmith: The other thing is that the gobo projector tool seems to insert a solid disk in the light source, which means that NOTHING comes out Check your rendering settings to make sure they match what is presented in the manual. You must make sure that you are using raytraced rendering, that you have transparency turned on, and anti-aliasing has to be set to smooth edges and textures. HTH Kevin M. ------------ Product Manager VectorWorks SpotLight <kmoore@nemetschek.net> ------------
quote: Originally posted by DBarnes: OK, now I'm 17 instruments into a beginning plot. Assigned the instruments to the House Left Parapit. Now, I'd like to add the Position Summary to the plot. When I do, the summary doesn't show the instruments counted. Any ideas? I'm sure it's a small thing I've overlooked. Any Ideas? Thanks... Dave Make sure that your instruments have "House Left Parapit" filled out in their position fields. If you select the instruments you wish to assign and the position to assign them to, the assign to position command will automatically assign the selected instruments to the selected position. If you don't have a lighting position as part of the selection then you will be asked to enter a position name. If the name you type doesn't exactly match the name you entered for the lighting position then the position summary will not find any instruments on the lighting position. HTH Kevin Moore Product Manager Nemetschek N.A.
quote: Originally posted by lbmorse: I can't find any documentation on how to properly use the "Theater Seating..." function under the "Drafting" menu in 8.5. The theatre seating tool is fairly easy to use. Draw an arc that you want to place seats on. Place two locus points on this arc to define the ends of the row of seats. Now run the theatre seating tool. You should see a vectorscript message bar that will prompt you to do the following. 1) Select the arc you wish to draw seats on and then press enter. 2) Select the locus point for the counter clockwise end of the row of seats and press enter. 3) Select the locus point for the clockwise end of the row of seats and press enter. 4) you will then be asked if you want to create seats based on this data. Click yes and the seats will be drawn and the chair widths displayed for each seat. You can cancel the command at any point by pressing the spacebar. HTH Kevin Moore Product Manager Nemetschek N.A.
quote: Originally posted by DBarnes: Putting together my first large light plot. I'm excited. One small problem is that I've been using single cell cyc units and drawing 3 individual units so that I can number them with 3 separate circuits. Is there a way to make it into a 3 unit symbol with 3 separate circuit numbers? Or should I just continue on the single unit method. The best method for handling multicircuit units like cyc lights the method you describe of placing multiple single cells together on the plot. This is something we have addressed in our new lighting package VectorWorks SpotLight. http://www.VectorWorksSpotLight.net Kevin Moore Product Manager Nemetschek N.A.
quote: Originally posted by EHS: Why is it that instrument lables rarely fall in the correct position in relation to the instrument symbol? I understand that this has to do with the layer scale, but how can I correct this? If your labels are being uniformly offset from the instrument, then it is the result of the user origin being moved, or the move page tool being used. These bugs have been addressed by a patch to the theatre lighting toolkit. Visit our website and check the updates section for the update. HTH Kevin Moore Product Manager Nemetschek N.A.
quote: Originally posted by PerrinWoods: Recently I ran into the problem that when asking VW8 to create a schedule through the Theatrical Lighting Toolkit it creates a type 1 unexpected quit error on the Mac Platform. Is this something issolated to my computer, or is it a known bug with a fix coming out soon? This is a known bug and we are working to find a resolution to the problem. quote: I also have a question about importing from LW3. What are the settings needed by VW8 to import data. I have found it very easy for LW3 to rearrange incoming data, but the export to VW8 file never seems to be in the right format for VW8 to read correctly. Make sure you choose the options in lightwright to export field names as first record and to fill all blank fields with the dash "-" character. You also want to make sure that you are exporting the external ID field and that you are creating a tab delimited file. HTH Kevin Moore Product Manager Nemetschek N.A.
