Semtex77
15 -
Reputation
0 Neutral-
Hej Islandmon thanks a lot Islandmon that was a great help!!!!
-Hej Islandmon, wow it is a really an honour that you you gonna help me out in this case but take your time if you have serious tasks to fulfill. I don t want to bug you guys too hard with that but I hoped that maybe someone else had my issue before and solved it somehow. But thank you so much in advance -rDesign Thanks a lot for your research. Sounds good to me . I already found a lisp-autocad file but i don t have a clue either how to convert it into vector-script.
Hey Ron and Grant! Thanks for your answers I know it is a tough question, sorry. I hoped there might be already an script to built clothoids. I need this special kind of curve to get a smooth road because normal curves won t fit in this case and i need it in a parametric kind of way. Right now i try to figure it out via Javascript but i have no clue how VectorScript is being programmed. Thanks a lot for your tips
Hello, is there a way in VW to create a Cornu spiral in 2d? /w Regards
hi there, i had a few probs with the offset-tool composed a curve shaped polygon...used an inner offset and clipped the inner from the outer form. unfortunately the offsetted inner form isn t curvy anymore. it is just polyline and the accuracy of the curves is all gone. i just figured out if i offset curves one by one and compose it later on. i get a curved form but it takes ages to do this. thanks in advance semtex
Better Curve Shaping and Editing
Semtex77 replied to barnes2000's question in Wishlist - Feature and Content Requests
The Curveshaping is kinda awful in VW. Compared /w Illustrator it is really complicated. With Illustrator you can shape things really easy and even afterwards you can use the bezier handles to define the shape. would be great if vw could adope this fine tool. -
umm nobody has found an answer... i mean both using csg-objects. so it would be really nice using rhino when vectorworks reaches its limits so no-one ever tried it??
Interesting! Is it possible to built different shapes in Rhino and then reimport them in VW and vice versa? Or is the shape triangulated? /w regards semtex
good idea....i thought about that thanks a lot propstuff
Thanks for your tip islandmon!!! But what if I have one solid volume and wanna substract a dozen volumes from it in one click? Can I group them and then subtract the volumes? Thanks in advance
hi everyone...it always cost my nerves to extrude every single nurbs-shape which i have created in 2d is there a handy tool or way to multiple extrude nurbs in a sudden. or when i have created a solid and wanna cut out some volumes i need to click the first and second solid and click substract and so on till my workflow is completely stalled. there must be a way to macro this? /w regards semtex
Can someone tell me when 3d hatches will be available in VW? Archi-Cad and Autocad support this features even for a longer period of time. Has someone have had good results wrapping textures on solidobjects? I mean it seems pretty nasty to render this thingy out. Thanks in advance Semtex77
show/hide 3d elements with classes&layers
Semtex77 replied to Semtex77's topic in General Discussion
thank you all for your help and ur really quick answers!!! ...grouping objects makes sense to me but what about the advanced stuff putting them into symbols...I don t know about that but it sound very useful. I work most of the time with composing solid objects together? /w regards christian -
Hi everyone, I really have problems working in 3d...when the full scenery is kinda packed...to click one of these elements is almost impossible. But organizing them in layers doesnt work anyhow... does anyone know why or the reason for my prob? Thanks in advance Christian
Is it possible to fill 3d Objects with hatches (perspectively correct) within vectorworks?
