Hello -
I am working on a model in which I need to insert a series of small, focused uplights around the top of a leather banquette. I am not having much success - the overall lighting appears brighter with each addition, but it is diffuse, not focused, light.
I've been experimenting with both spotlights and point lights, with brightness in a range between 80 and 10 for each light, and with spread and beam values in a range between 30 and 10 degrees, without much luck. I thought the problem might be the uplighting itself, but the lights behave the same whether pointing up or down.
Any suggestions for ways to achieve the effect of small, focused beams of light? Or suggestions on uplighting?
Many thanks,
Elizabeth Thelen
Design Assistant
Interim Design
