I am having a reproducible intermittent problem with the label legend manager and custom title blocks. When I attach a record to a text field, the attachment does not stick. It will either go away, or attach to a different field in the record.
The most easily reproducible is to create a new label legend and select the first three fields and "focus." One of two things happens at this point:
a)'focus' goes away and is replaced by '_NNA_DO_NOT_CHANGE_'
or
b) four additional fields show up in the label layout screen with no observable text. If I select one of the empty fields and go to Tools->Records->Link Text to Record, it tells me that the field is attached to a Wall record.
I have tried every workspace, template and blank document combination I can think of with no change.
This is most annoying since VW tech support tells me this is not possible yet I, as well as a colleague just down the hall, can make it happen at will. This happens on two separate installs of Spotlight on two separate machines. The only thing these platforms have in common is the install DVD and C. Andrew Dunning's Screen Tool.
Is anyone else seeing something like this?
-bk
