klinzey
Vectorworks, Inc Employee-
2,550 -
Everything posted by klinzey
I think this was fixed in 2010.
Two things. You neent to use [] rather than () and you need to escape the single quotes. SetWSCellFormula(WSH,1,0,1,0,'=DATABASE(R IN [''JAMES''])');
Yes, All Lights take a direct path between point A and B with an even fade of the light if there are any intensity changes.
It's safe to change the name of the rendered light in the Visualization Palette. Just don't change the name of the Lighting Device in the OIP, it will get overwritten.
I have not heard of this problem before. If you can replicate the problem please submit the file along with your machine specifications (including Manufacturer, OS, RAM, Video Card, etc.) and exact version number to bugsubmit. http://www.nemetschek.net/support/bugsubmit.php
You will get this message if your are mixing old symbols with new symbols. The Light Info Record was updated (Things like a second beam, field angle and channel count were added) and if you use a symbol that has an older version of the light info record it wants to know which record format is correct. If you update the light info record on problamatic symbols you should not see the warning message any longer.
Yes. In order to render the light source you must assign it to a focus point.
Script to draw line with preset object name?
klinzey replied to Andrew Neilson's topic in Vectorscript
Andrew, Checking for a duplicate name is simple. In your case If GetObject(Date(2,2)) <> NIL then AlrtDialog ('Name In Use'); or put it in a while loop if you just need a unique name UniName := Date(2,2) While GetObject(UniName) <> NIL DO UniName := Concat(UniName,1); SetName(LNewObj,UniName); {There are better ways to do this but you get the point.} -
Try running the command in a new blank document. If it does not work you will probably need to contact tech support.
Vectorworks renders only static scenes. You can place a gobo (or any image texture) and have the instrument project it along with a color. If you want to rotat the instrument check "Set 3D Orientation in the OIP and set the rotation.
That's switching Tool Sets. You need to switch workspaces, Tools tab-->Workspaces. If a symbol has the "Light Info Record" attached and the Instrument Insertion tool is available in the workspace then it will be automatically activated. So the easiest solution is to switch workspaces or edit a copy workspace and remove the instrument insertion tool. If you are only dealing with a few symbols you can also activate the symbol insertion tool first and it will remain active while switching symbols.
Jeremy, If you created lighting positions and place the lights on the positions, when you change the height of the lighting position all the lights on the position will move. If you did not create lighting positions or did not place the lights on the lighting position you will have to select the lights and set the Z height by using the OIP (Object Info Palette) using the Move 3D command or dragging them in a 3D view. (Note: if your objects are 2D only then you will not be able to give them a Z value.) Depending on the version you are using you may have to continually select align layer views. If you are using a more recent version you should be able to enable "Stacked Layers" or turn on "Unified View" which will automatically align all the layers with each view change. (You can use the Flyover tool to move around the view.) There is only one drawing window available in VW.
Change to a workspace that does contain the instrument insertion tool.
PDFs exported from Educational versions are locked from editing. You can print or combine the PDF but you can not copy or edit the PDF because it is watermarked.
You probably have a bad font or a font that VW 12 does not like for some reason. Try deleting the font mappings in VW then try creating a a new label legend. I've seen this problem with several custom and hand letteering type fonts and the only way to fix it is to repair the original font or replace the text.
You can not specify a label legend based on the instrument. You can change the active label legend for the document using the label legend manager before you place the instrument or you can change them after insertion as a group using the find and modify command.
Text size inside PIO changes when inside a Symbol
klinzey replied to Assembly's topic in Vectorscript
If you want to know if you are inside of a symbol you can recursively call GetParent() till you reach a symdef or a layer. -
The number of instruments should not matter much. If you have the Lightwright data exchange turned it will take slightly longer to regenerate. You will see longer grgeneration times for instruments that have accessories, two-fers or are part of a multi cuicuit unit. Once one instrument is moved the other lighting devices associated with it must also update and there are some cases where this may happen several times in order to update all the related lighting devices.
Every time you move the instrument (either by a mile or a nudge) it recalculates.
This topic has been locked because the original poster is using an Illegal copy of VW.
katja, I can see from your screen shot that you are using the educational version. The educational version is limited to exporting to only the two previous versions.
In 2010 turn on "Unified View" or select "Align Layer Views" Both are available in the "View" menu.
Ken, To get rid of the "Personalize Your Copy of Vectorworks" message I think you have to enter something into BOTH fields.
Nemetschek North America and City Theatrical Establish New Partnership in the U.S. Columbia, Maryland (February 25, 2010)?Nemetschek North America is pleased to announce that a new partnership with City Theatrical has been established. This partnership will allow both companies to cross sell and market their products to professionals and schools focused on the entertainment and lighting design industries. Acting as a U.S. distributor partner, City Theatrical will sell Vectorworks? Spotlight and Vectorworks Designer software through their distributor network of more than 200 lighting dealers in all major cities. Nemetschek North America, in turn, will be able to offer their customers the product Lightwright? 5, a quintessential tool for tracking all aspects of selecting and arranging, numbering and comparing, assigning, and footnoting lighting paperwork. "The partnership between John McKernon's Lightwright and Nemetschek North America's Vectorworks is a natural fit," stated Gary Fails, President of City Theatrical, Inc. "The products complement each other and are both standards among lighting professionals. This partnership will make it easier for users to obtain both programs at one time and will strengthen the leadership position of both products." Nemetschek North America's U.S. Director of Sales and Marketing, Michael Pacylowski, is also looking forward to the new collaboration and explained, "This partnership will reinforce the Vectorworks Spotlight and Lightwright data-exchange solution as the gold standard in the world of lighting design." A manufacturer of unique lighting accessories and the winner of 30 product and business awards, City Theatrical Inc. has offices in Carlstadt, New Jersey and London, England. Products include the multi award-winning SHoW DMX? wireless DMX system, accessories for Color Kinetics?, AutoYoke?, and Lightwright? 5, as well as the world's most extensive catalog of theatrical lighting accessories. For more information, visit www.citytheatrical.com. Nemetschek North America is a wholly owned subsidiary of Nemetschek AG. A global leader in design technologies, Nemetschek North America has been developing CAD software for the AEC, entertainment, landscape design, and manufacturing fields since 1985. For more information, visit www.vectorworks.net. -- Lisa Lance Public Relations Specialist Global Marketing Communications Nemetschek North America Inc. Phone: 410-290-5114 ext. 719 Direct: 443-542-0719 Cell: 314-324-3882 Email: llance@vectorworks.net www.vectorworks.net On your desktop. Around the world. News about Vectorworks. http://planet.vectorworks.net
It's probably something with your machine. As soon as I regenerate the instrument in your file it's fine. Before you reinstall try deleting your Vectorworks user folder. There was a similiar problem in earlier versions on the Mac but we were never able to reproduce the problem in house.
