klinzey
Vectorworks, Inc Employee
    2,692
Posts posted by klinzey
  1. That returns the internal ID of the object.  The full list be available in the SDK.
    The basic values are here:
    https://developer.vectorworks.net/index.php?title=VS:Function_Reference_Appendix_D
    517 is a Solid Addition
    641 is TrussItem
    You may be traversing into the plug-in and finding the solid addition rather than the outer level TrussItem.
    The ID could change but it's rare.
    I usually use GetParametricRecord() and then GetName() to check the name of the record to see if it matches.
  2. They should be there, none were removed for Vectorworks 2025.
    Make sure you are looking in the Vectorworks libraries and not just the current document.
    Also try refreshing the resource manager.
    From the resource manager click the gear icon and select Refresh Libraries.
    • Like 1
  3. Form my past experience running ETC offline on the same computer as the Visualizer it still did not like having a manual IP address assigned in the ETC software. If I just let the computer and the ETC software grab IP addresses from the DHCP server all was happy in the world.
    I was even able to use the wireless connection between computes as you have setup as long as the DHCP service was running.
    • Like 2
  4. The one thing I have found with the ETC offline software is that it likes to be run connected to a network with a DCHP server. I had issues manually configuring the IP or just using the loop-back and default IP that gets assigned when there is no connection. Once I connected things to a router to serve up IP addresses, even if it wasn't connected to the internet, everything started working.
    As Brandon said it's best to just have one network connection operational. Don't try to have WiFi connected to the internet and a hardwired connection connecting to another machine running the console or visualizer.
    • Like 1
    • Love 1
  5. @James Narduzzo If you accidentally watermark your file because of this issue please contact technical support directly.
    They will want to know which file you imported the resource from to confirm the problem and to make sure no others have gotten by our testing.
    We have identified 4 files that have this issue. If you find any others please let us know.
    /Libraries/Entertainment/Stage/Rose Brand/Rose Brand Winch.vwx
    /Libraries/Entertainment/Stage/Scaffolding/Layher Allround Event.vwx
    /Libraries/Entertainment/Stage/Scaffolding/Layher.vwx
    /Libraries/Entertainment/Stage/Scaffolding/Ringlock.vwx
    • Like 2
  6. Yes. We have seen issues with Mac security permissions and Sequoia may be even more restrictive. Make sure you give Vectorworks permission to use the camera. We look all devices capable of providing video. The Vectorworks installer should automatically add the necessary permissions but there may be something new in Sequoia.
  7. There is one more step..
    Spotlight>Visualizer>Select Video Input>Capture Device and the Edit Screen Image>Enable Previs>Capture Device are used for identifying which objects are video objects and if the object will use a recorded video or a stream/capture device.
    The NDI stream is selected using Spotlight>Showcase>Select Video Source... once the object has been identified as using a stream/capture device.
  8. For Joshua Benghiat's plug-ins you will need a new 2025 version, you can not just copy the 2024 version to 2025.
    Typically Vectorscript and Python plug-ins can be copied from version to version.
    The more complex C++ SDK based plug-ins are required to be updated for every major version release.
    You can check in Josh's site but the plug-ins should also be shown on the Partner Product page when they are ready.
    From the Help menu in Vectorworks select Install Partner Products... This will show you the 3rd party plugins that are currently available you your version of Vectorworks.
    • Like 1
  9. Yes, schematic views can be placed, and usually are placed, directly to another layer.  It was done on the same layer in the video to show how editing one updates the other.
    The schematic view is generating a flattened view based on the relative position of lights on the truss.
    You can read more about how schematic views work here: Creating schematic views.
    • Like 2
  10. d&b audiotechnik speakers are in Vectorworks Libraries\Entertainment\Audio Speakers\Speakers db audiotechnik.vwx
    If you search in the Research Manager for d&b you should see the speakers along with some other d&b equipment.
    If you don't see them make sure you are online and you have the Vectorworks libraries enabled in the resource manager.
  11. When the speaker object can not find the speaker symbol it will revert to using the default speaker geometry.
    Did you import the Speaker object into a new drawing?
    If the speaker object is tilted and you import it into a new document it does not bring the speaker symbol into the new document.
    If the speaker is not tilted the speaker object will import the speaker symbol into a new document.
    We are planning to address this issue in a future version.
    • Like 1
  12. We recently met with Atomic to talk to them about their products among other things.
    They do not release 3D models to the general public, you can try contacting them directly.
    Some of the designs are just too easy to make a clone of their design once you have the 3D model.
    We are working with Atomic to investigate other options to provide users with their designs.
    • Like 1
  13. @Wood Custom cross sections are stored only with the file. There are not stored with the symbol or as a resource in the document.
    The cross section data is custom for the document and not necessarily specific to a symbol so there is not a good method of managing, identifying, or resolving conflicts like we can do with other resources.
  14. On 6/19/2024 at 11:32 AM, Chris J Clarke said:
    I'd also really like to see the data for the Sixty82 truss added to Braceworks. In particular the M29S range. Is it just that you're waiting for them to provide the info? Would it help if we emailed them and asked them to provide it as a customer?
    Yes, We are waiting from them to provide us all the proper data in the correct format. We have found that many of the companies have most of the data available but are missing a few critical pieces that allow Braceworks to preform the calculations.
    It's useful it you tell them you want them to provide the data to Vectorworks. Unfortunately, it does not help us  if you to obtain the data and give it to us. As a company we need permission from the manufacturer in order to distribute the information as part of Vectorworks.
