ShookLA
    2
    Never
Reputation
0 Neutral
  1. Yes you can turn on the Adjust Flipped Text option, BUT YOUR CALLOUTS WILL STILL BE BACKWARDS if you export the file as a DWG. I have experienced this problem annotating files for consultants & them complaining that all the text is reversed. Have not found a solution.
  2. Is there a way to select all the doors in a model and modify all the ID Settings universally. Right now I can only select (1) door-in-wall object at a time.
