mar schrammeyer
    387
Everything posted by mar schrammeyer
  1. I know, am just very frustrated with this upgrade
  2. Why the difference? I had a lot of trouble importing this texture from 2009 and then editing it because it showed completely black and not getting it right in open gl did not help
  3. I can create an wall end cap but how can I make the end cap follow the wall when I use fit to roof or just pull the wall up, it will react when I change the delta Z of the layer but that is a bit awkward I can select the cap then what
  4. ModernHomePrototype from NA Updated all plug-in objects etc. but VW2011 crashes when trying to update the cover sheet viewport not a good start
  5. I tried the human figure tool selected it & converted to lines, should be to scale
  6. the above is for a single dimension for chain dimension select chain dimension right click the witness line when the cursor has changed to a cross an editing window will appear
  7. I had that problem today I made a a new 3D-Model layer turned on all my mod-design layers set a camera view (everything okay) made a VP found the view several meters to high, the problem lay in the new 3D-Model layer z hight that was set to a hight instead of zero when I corrected the z height everything was fine.
  8. create your roof at required pitch then 3 gable ends and you can use your framing tool but it is no quicker
  9. did you update your references? they will show red in the organization window
  10. Just matched my iMac 3.06ghz 4G ram to my colleagues PC Intel 2duo 2.6 ghz 2G ram with Stans timer on final quality radiosity Mac 17.2 PC 14.7
  11. Set your different views and save as saved views
  12. not simple, use 3d tools create 1/4 globe lift shell = glass create contours where you want the muntins create profile for muntins extrude along path (contours) My computer dutch is non existing so see attachment in case you use different terms
  13. After opening a recent file, I found certain objects were not hatched anymore (shown correctly in the pdf which I had created) when reapplying the hatch I got the warning (The Hatch named "Cladding-Corr.Steel vert" that you are trying to import has the same name as a Dimension in the current document. What do you want to do?) I cannot find a dimension of that name of course so I had to import the Hatch with an altered name. The resource browser shows 2 empty places in the Hatch folder which I cannot delete. Did anyone else ever experience this?
  14. double clicking the recess will bring you in edit mode and then you will be able to edit the object you used to make the recess
  15. you could try to play with a texture called vertical stripe to be found under create new texture
  16. created with wall projection & recess sorry did not mean to steal your idea BCD noticed to late that you gave the same answer
  17. Sorry, ungroup roof but keep all roof planes selected and clip Clip tool will clip roof planes but not a roof
