mar schrammeyer
388 -
Posts posted by mar schrammeyer
select the dimension and alter font and size in text in the menubar
text default is set there
in VW 2011 symbols are scalable so you can scale a tree down or shrub up
You could make first an elevation viewport and then a section viewport of that vp see attached file
Your customized stuff should be parked in your home folder anything there will not be overwritten on a PC it should be something similar
We will have to wait for oz update, but is it properly fixed or is it still 700+ mb?
Hi reported this problem shortly after starting with VW2011 I was provided with a fix by the techies and OzCad which was a Cinema 4D QT agent to replace existing one it works but a QT VR object in 2010 would be 10-15 MB in 2011 it is 700MB + so I export back to 2010 to make the VR object if required.
I can provide you with the fix if you send me an email
(It seems that it occurs especially when Vectorworks and Cinema 4D are used together.)
If that is the case would unticking the prefs (Allow option-click in-place duplication) help
Check out 3D power pack in VW help
Set your 3D conversion resolution to very high in VW prefs
check if you are not doubling up somewhere, 2 walls in the same place or 2 layers.
Thanks for fixing my Export VR object bug
if you are working in 2D make sure you are also in top/plan in your VP
stick to it
The end caps corresponded to the layer thickness ignoring the sloping wall but indeed it is fixed in SP2 thank you
Is this end-cap farce fixed in SP2 ?
Convert your circle to polygons and it will work
Would that be quicker then this?
Ar what stage do you convert to 2D? Convert to lines/polygons is not greyed out for me.
I think if you give it a go you'll find it gives you exactly what you want I created a quick easily checked roof and it gave me the correct answers just try it
that is ginormous & ridiculous, I'll buy some more ram and see thanks Mike
when I try to open the file with QT 7 it tells me it is not a movie file and it is 0 kb, when instigating the export it does it in 5 seconds one render and finished, is there some new setting somewhere?
the export Quicktime VR object menu item is still there but it exports nothing, I can export the file to 2010 and I can export it from there but, if the VR object was scrapped why is the menu still there?
Thanks Benson, I was just extremely frustrated about the amount of time I spent on fixing that problem.
dtm pads and complex pathways: best practices
in Architecture
Posted
